Originally Posted by Dave9
Originally Posted by thastinger
Have often pondered how much fuel could be unexpended with starting batteries that weigh less than the FLA tech which comes in OEM SLA batteries. 10 years age I built a battery for my drag bike that was setup as 4S4P configuration and made from the original A123 26650 cells. It weighs 3.5Lbs, charges from standard alternator and has 750CCA but only for 5 seconds...and LiFePo4 batteries don't like the cold. It started my 5.4 F150 with ease and it weighs 70 Lbs less than the OEM battery...problem is lack of capacity...leave your headlights on for 10 min and your out of luck.
Practically no fuel savings at all. Even a light to medium duty truck lead acid battery weights around 46 lbs (group 65 for example is about the same weight as a 5.4L F150 uses, for the heavier "Gold" upper tier CCA batteries), so by the time you set up a much more expensive yet lighter weight battery safely, you'd maybe shave 35 lbs off... of a vehicle that weighs thousands of pounds, you're reducing weight by about 0.7% which based on EPA averages, would result in half that % in fuel economy improvement. EPA states around 1% improvement per 100 lbs.
So say you have a vehicle averaging 18MPG ("big V8" was mentioned in initial post), that approximate 0.35% improvement would result in about 18.06 MPG. At 12,000 mi/year the difference would be about 2 gallons per year, you'd save/make just as much money investing that money in a normal investment with an average return, instead of a lighter battery, or one time making a meal at home instead of eating out would take far less time than constructing such a battery and save as much money.
What's better for the environment? Driving something that gets a lot more than 18MPG.
Agree with about all your points, but on economy of scale spread over 100s of thousands of vehicles, cutting 55 or 60 Lbs from each will add up to a considerable fuel savings. Aluminium bodies pickups aren't the norm because anyone believes AL is stronger than steel pound for pound. I'm not intending to get into the carbon footprint of mining rare Earth elements as I believe that to be carbon negative effort, however, Ethanol as a fuel source is also carbon negative and we keep doing that. I'm not a tree hugger but FLA battery technology has severely lagged behind in technological advances over the years, they are too heavy for the capacity.
