What is high output AC?
by Fitz98. 07/18/19 12:45 PM
Killed my receiver
by Quattro Pete. 07/18/19 12:35 PM
I did it! Put Straight HD30 in the PSD...
by racin4ds. 07/18/19 12:34 PM
Bobcat S630 engine oil
by Spdfrk1990. 07/18/19 12:09 PM
737 max... what now?
by Tdog02. 07/18/19 11:46 AM
Picked up a Hyundai oil filter from WM
by mclasser. 07/18/19 11:29 AM
Mobil1 20w50 Vtwin in a tuff torq K61
by gman2304. 07/18/19 10:47 AM
4t outboard W rating question
by 1978elcamino. 07/18/19 10:27 AM
Top three based on known specs.
by sloinker. 07/18/19 10:24 AM
Harbor freight 25% coupon
by Fitter30. 07/18/19 10:11 AM
Going to try longer OCI.
by mctmatt. 07/18/19 10:06 AM
diagnosing a/c problem
by matrass. 07/18/19 09:49 AM
Any friends of StevieC here ?
by Kjmack. 07/18/19 09:29 AM
Oil change interval on 70 Chevelle
by 007. 07/18/19 09:20 AM
New to me 2018 Grand Caravan 3.6 weight questions.
by racinjason. 07/18/19 07:38 AM
Help With 6L80E Fluid & Pan Replacement
by Sierra048. 07/18/19 06:39 AM
Shaz, Grousebeater, RoyD, clonis, golddots
68699 Registered Users
88 registered members (2015_PSD, Alfred_B, 1WildPig, AirBull, 01rangerxl, 4WD, 4 invisible), 2,194 guests, and 30 spiders.
Topics292,030
Posts5,015,532
Members68,699
Most Online2,967
Mar 10th, 2019
Page 3 of 3 1 2 3
Re: Oil & Timing Chains [Re: ZeeOSix] #5126149
06/05/19 03:55 PM
06/05/19 03:55 PM
Maricopa Arizona
dave1251 Offline
dave1251  Offline
Maricopa Arizona
Originally Posted by ZeeOSix
J300 shows the bottom end of 20 weight range as 6.9 cSt ... so at 7 cSt it was ready to fall into the 16 weight range.
The exact CST was 7.26 even at 7.0 it is not a 20 grade.
don't use.
Re: Oil & Timing Chains [Re: dave1251] #5126152
06/05/19 03:57 PM
06/05/19 03:57 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
If he ran it much longer like some suggested, it would most likely have sheared into the 16 weight range.
Re: Oil & Timing Chains [Re: GaryPoe] #5126163
06/05/19 04:05 PM
06/05/19 04:05 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
I maintain two cars that produce a carbon/soot like substance in the oil filter. Both receive cheap store brand oil, usually synthetic, 8,000 mile OCIs, mixed driving in Toronto's climate and both engines are known for timing chain problems. Currently over 200,000 miles on each vehicle. I think this soot and timing chain wear concern is over stated. If the chain, sprockets and guides are well made they seem to last the life of the car.
No doubt after I post this, my engine will skip time and bend all the valves.
Re: Oil & Timing Chains [Re: ZeeOSix] #5126167
06/05/19 04:07 PM
06/05/19 04:07 PM
Maricopa Arizona
dave1251 Offline
dave1251  Offline
Maricopa Arizona
If he ran it much longer like some suggested, it would most likely have sheared into the 16 weight range. From lots of UOA data summarized on the Mustang boards, it shows that Motorcraft shears quite a bit, more than most oils.
At this point it starts to oxidize and thicken. Do we really want to start mental gymnastics on what may have happened? Because the point was false hyperbole was presented as fact and you are doing a commendable job of attempting to distract from the facts of the post which was the lube was serviceable at the time of the change and within grade. Contradicting the poster.
don't use.
Re: Oil & Timing Chains [Re: WobblyElvis] #5126183
06/05/19 04:20 PM
06/05/19 04:20 PM
TX & ON
ofelas Offline
ofelas  Offline
TX & ON
An oil/filter change BEFORE shearing out of grade is a timing chain’s friend thumbsup
R12 in the summer, Webasto in the winter, and cassette tapes all year.
Re: Oil & Timing Chains [Re: dave1251] #5126184
06/05/19 04:22 PM
06/05/19 04:22 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
[quote=ZeeOSix]J300 shows the bottom end of 20 weight range as 6.9 cSt ... so at 7 cSt it was ready to fall into the 16 weight range.
You mean like the "mental gymnastics" of claiming it starts to oxidize and thicken at this exact point. Fact is it sheared down to nearly a 16 weight (starts at 6.9 cSt) at way less mileage then some recommend using it to. If the OP wants to change it early because of that, then who's to say he should run it longer ... especially since they don't own the vehicle or pay for his oil changes.
Re: Oil & Timing Chains [Re: ZeeOSix] #5126445
06/05/19 08:32 PM
06/05/19 08:32 PM
Maricopa Arizona
dave1251 Offline
dave1251  Offline
Maricopa Arizona
It did not shear and we don't know if it would shear beyond 7.26 or thicken. You are good at throwing hypotheticals to support the outcome you desire but not accepting the fact of what actually happened.
don't use.
Re: Oil & Timing Chains [Re: dave1251] #5126450
06/05/19 08:34 PM
06/05/19 08:34 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
What do you mean it didn't shear. What was the KV100 on his new oil (show the source) since you seem to know it all. I know Motorcraft 5W-20 is 8.5 cSt, which if his started there it sheared down15% in 5K miles.
Page 3 of 3 1 2 3
