Topics298,346
Posts5,133,494
Members70,043
Most Online3,589 Nov 2nd, 2019
17 Honda Civic 1.5T 6MT, Amsoil 5w30, 7,913/35,096mi
#5121576
05/31/19 04:45 PM
parshisa
OP
OP
Posts: 1,215 |
Latest results for my Civic with SS 5w30 at 8K mi. Fuel dilution test wasn't ready due to lab's issues and will be done next week. Although I'm expecting fuel to be at 3-4%. Sodium and Silicon went up (virgin oil has 5 and 7 ppm respectively) - what's that about? Also, looks like aluminum slightly went up - any comments on that? Note: Car's MM was at 15% when I changed it. SHould've ran longer? Any thoughts and comments are welcomed ![[Linked Image]](https://www.bobistheoilguy.com/forums/attachments/usergals/2019/05/full-78246-33083-2019_05_31_17_38_30.jpg)
Re: 17 Honda Civic 1.5T 6MT, Amsoil 5w30, 7,913/35,096mi
[Re: parshisa]
#5121701
05/31/19 08:01 PM
oil_film_movies
Posts: 4,672 |
Yes, could have run it a little longer, around 2,000 more miles given the high TBN. And viscosity was hanging in there, looking like heavy-side xw20 oils at the end, which was your goal probably. Amsoil SS works well, low iron ppm, just the fuel dilution is there to wonder whether or not it's putting extra carbon on the pistons.
[Re: oil_film_movies]
#5121702
05/31/19 08:02 PM
parshisa
OP
OP
Posts: 1,215 |
What are your thoughts on increasing sodium?
[Re: parshisa]
#5121709
05/31/19 08:17 PM
oil_film_movies
Posts: 4,672 |
Na and no K means it's not anti-freeze coolant. Wow, in TX you're not getting salt on roads, which is what I've blamed slightly elevated Na on in the past, getting in via dust particles past the air filter..... Puzzling.
#5121710
05/31/19 08:19 PM
parshisa
OP
OP
Posts: 1,215 |
Yeah, there are 5ppm of sodium in VOA for this oil but where the rest is coming from is unknown...
[Re: parshisa]
#5121990
06/01/19 07:19 AM
JLTD
Posts: 3,030 |
If you're near the coast, salt air might contribute to sodium.
More aluminum (aluminium for our Euro and Aussie friends) plus silicon might mean a filtration issue so maybe check the intake and air filter.
I use the overseas manual to choose my viscosity.
Hers: 2008 Jeep Liberty 154k, SS 5w30/Amsoil Looking at options.
His: 2015 4Runner 60k, SS 5w20/Amsoil
[Re: parshisa]
#5122012
06/01/19 07:33 AM
addyguy
Posts: 14,906 |
Results are good, but I'd put a caution on these results - silicon is still relatively high for the miles, and aluminum is up.
No, it's not catastrophic at all, BUT it could be some excess dirt getting into the engine, causing some extra piston and bearing wear.
I guess I'm just saying what JLTD said above.
2010 Kia Soul 2U - 2.0L I-4, auto; 149k miles. Castrol Edge (black bottle) 5W-30; Fram TG 9688.
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles. Oil/filter TBD
[Re: parshisa]
#5122042
06/01/19 08:05 AM
ARCOgraphite
Posts: 13,907 |
Looks like easy 10 K oil in Texas.
Come on amsoil SS!
I would leave a jug of 18$ Wallwart faux syn special in that long NP up here the land of 2 seasons.
Q. Did you poke around the airbox during this time?
2019 VW Jetta S 6MT OCI#1 5885mi-Castrol Edge Prof? VW508+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
[Re: addyguy]
#5122046
06/01/19 08:09 AM
parshisa
OP
OP
Posts: 1,215 |
There’s an UOA for 10th gen civics on a different site and it looks like silicon values i’m getting are about the same or lower than average. I haven’t touched the airfilter since i changed it at 21K miles, so it’s been in use for around 15k miles now
[Re: ARCOgraphite]
#5122047
06/01/19 08:09 AM
parshisa
OP
OP
Posts: 1,215 |
No Sir. Had the filter swapped @ 21K and never touched it since. I guess it’s time to order new air filter
[Re: parshisa]
#5122221
06/01/19 11:03 AM
oil_film_movies
Posts: 4,672 |
FWIW, a sample of one, a friend of mine has an '18 Civic 1.5T, and the dipstick level is not rising. He's a mechanic, so when I spoke to him about the fuel dilution issue, he understood and said the level has been steady, even over a rough winter or two. Now I wonder what % of these things actually have over 2% fuel dilution, the level at which I would consider it a problem?
[Re: parshisa]
#5123695
06/03/19 05:42 AM
parshisa
OP
OP
Posts: 1,215 |
Here's the report update with actual measured fuel dilution ![[Linked Image]](https://www.bobistheoilguy.com/forums/attachments/usergals/2019/06/full-78246-33156-2019_06_03_6_37_47.jpg)
[Re: parshisa]
#5126118
06/05/19 02:25 PM
Matagonka
Posts: 588 |
Fuel dilution is a serious problem in these cars.
2018 Mazda 3 Touring HB 2.5
[Re: Matagonka]
#5126124
06/05/19 02:27 PM
parshisa
OP
OP
Posts: 1,215 |
[Re: parshisa]
#5127606
06/07/19 05:27 AM
Wildcard
Posts: 92 |
at 8000 miles that silicon doesnt look bad
2002 acura 3.5RL
