Originally Posted by Jarlaxle
Originally Posted by Pelican
I remember them well, great cars in a straight line, but give them a few curves and suddenly not so much, still, I miss them.
That's because GM chassis design, well...sucked. Flexy frames, horrible camber curves, dinky brakes, all standard!
My '66 GTO had drum brakes. Use them hard once and they went away until they cooled back down. The '67 GTO's came with front discs but the tri-power was no longer offered. Granted that the handling of the muscle cars was atrocious but that included all makes, not just GM. Big cast iron engines up front and a lot of understeer came standard with them all. If you wanted good handling you had to go with a small block Corvette, Z28 Camaro, or Boss 302 Mustang.
