BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
My Henry 22 Magnum Rifle (pics)
by tig1 - 05/29/20 09:04 AM
overfilled my crankcase by 3/10 of a liter - problem?
by tom in boise - 05/29/20 08:49 AM
Espresso
by buster - 05/29/20 08:34 AM
I didn't believe there were fake spark plugs.
by JustinH - 05/29/20 08:14 AM
New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
1/2 75W-90 1/2 75W-110 Can you mix equal parts
by jrommelt - 05/28/20 08:22 PM
Mazda b4000 to the junkyard
by HyundaiAbuser - 05/28/20 08:20 PM
2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Nail in tire, what would you do?
by Brybo86 - 05/28/20 07:44 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
110 registered members (928, 2015_PSD, 4WD, 53' Stude, 1978elcamino, 94astro, 9 invisible), 2,227 guests, and 31 spiders.
Topics306,011
Posts5,284,769
Members71,558
Page 1 of 5 1 2 5
GM 2.0 Turbo LTG oil consumption (2015 Malibu 2.0 LTZ) #5125601 06/05/19 05:44 AM
M
metroplex Offline OP
M
I'm working on a 2015 Malibu LTZ with the 2LT package that has the 2.0 LTG Engine (GTDI).
Original owner, claims she had the oil changed based on oil life monitor each time with Mobil 1 synthetic. Currently has 73,000 miles. I changed her oil and filter with Amsoil SS 5W-30 and an Amsoil Ea filter at 68,000 miles. The oil that came out at 68,000 was super black and about 3 quarts low. At 5,000 miles, her engine is about the same level low (on the dipstick) so I'm guesstimating 2-3 quarts low. But this is with Amsoil SS 5W-30. When I first changed the Amsoil, the dipstick oil still looked black. Usually after a new oil change, the oil is clear/amber. There is signs of sludge/coking on the dipstick as well.
The engine runs smooth and fast, but it also seems qualitatively hot. I can't touch the dipstick unless I wait like an hour after shutting off the engine. My other GTDI engines (Ford EcoBoost) don't have this problem.
I read about piston failures due to "misfire" on the earlier ATS's with the same engine. Supposedly the Camaro has a different LTG engine.
Any ideas?
I'm thinking about going to 10W-30 or maybe a 10W-40/5W-40 oil from Amsoil, or perhaps Rotella T6 5W-40.
Re: GM 2.0 Turbo LTG oil consumption (2015 Malibu 2.0 LTZ) [Re: metroplex] #5125606 06/05/19 06:14 AM
Char Baby Offline
Well as a rule, turbos do run )))HOT((( and not being able to touch the dipstick for an hour after the engine has been turned off IMO is normal. Maybe not the hour thing but, HOT just the same. I haven't been able to touch a HOT oil dipstick after an engine has shut down in ~50 yrs of tinkering/wrenching, I don't care what engine it was.
Dark oil is one thing(usually nothing more than dark oil) but as you mentioned, sludge is not good. And too, as far as what the owner(she) claims, remains to be seen unfortunately, its all you have to go on.
Do you know exactly how this person drives? I mean, she could be #e!! on wheels!
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: GM 2.0 Turbo LTG oil consumption (2015 Malibu 2.0 LTZ) [Re: metroplex] #5125611 06/05/19 06:22 AM
M
M
The oil that came out of that engine was jet black, and even with fresh Amsoil it was really black. There must have been a lot of carbon inside that engine. My Fusion Sport has about 5000 miles on its 5W-30 (Pennzoil Platinum) and when I compared dipstick samplings with the LTG, the LTG oil is noticeably darker at around the same mileage, not to mention at least 2 quarts low.
The LTG has a weird setup. The dipstick handle is black, not the normal yellow color, and has white warning marks indicating it is hot... but my Cobalt SS Turbo has the LNF, which is about a generation older than this LTG, doesn't get anywhere as hot as this engine and I can easily check the dipstick after driving or even pull the oil fill cap.
The person does drive fairly aggressively but I wouldn't say she keeps it in high RPMs on a road course, more like she gets on the gas a little more aggressively than most.
I'm going to see if they revised any of the PCV parts. The LTG seems to have at least 2 or 3 PCV valves.
Re: GM 2.0 Turbo LTG oil consumption (2015 Malibu 2.0 LTZ) [Re: metroplex] #5125614 06/05/19 06:29 AM
M
MParr Offline
M
It’s been consistently using oil and she is changing it based on the OLM. My guess is she hasn’t been checking the oil level between changes and adding as needed. People are creatures of habit and you probably won’t be able to convince her to check her oil and add oil when needed. Switching to a high mileage oil may help slow the consumption. Changing the oil every 5,000 miles may help in her situation. If she continues doing what she has always done, she will be looking at engine failure in the future.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2020 F-150 STX Super Cab 2WD 2.7 Ecoboost. FF & OE filter
Re: GM 2.0 Turbo LTG oil consumption (2015 Malibu 2.0 LTZ) [Re: metroplex] #5125615 06/05/19 06:30 AM
J
jbutch Offline
J
It's the first time I hear of such thing. Do you have a temperature gauge for the oil or the coolant in the car?
2015 Forester XT @ 104k km
Current fill: Pennzoil Euro LX 0w-30 with Fram Ultra XG7317
Re: GM 2.0 Turbo LTG oil consumption (2015 Malibu 2.0 LTZ) [Re: metroplex] #5125616 06/05/19 06:34 AM
Char Baby Offline
I was going to say change the oil even before 5000 miles while checking the level periodically.
Re: GM 2.0 Turbo LTG oil consumption (2015 Malibu 2.0 LTZ) [Re: metroplex] #5125621 06/05/19 06:42 AM
Snagglefoot Offline
I think there are some subjective readings here. The engine should be running at about 210 deg F. If you have a temp gun, you could get a few shots to confirm.The temp of the dipstick is a function of what is positioned next to the tube. Is the tube running past the metal cover over any of the exhaust plumbing? That would cause the tube to be hot and stay hot longer. Being that the oil is three quarts low would contribute to a higher oil temp for sure. This lady was not ever checking or adding oil and the engine loaded up with carbon. A few more oil changes will help with that. Thanks for the post. Interesting issue.
If you want the job done right......do it yourself.
Re: GM 2.0 Turbo LTG oil consumption (2015 Malibu 2.0 LTZ) [Re: metroplex] #5125645 06/05/19 07:20 AM
B
BigCahuna Offline
B
My wife has a 2011 Equinox 4 cyl, and it has the same consumption problem. it uses 1/2 a qt in about 750 miles. Doesn't matter who's oil or what weight. There's alot on it on the net about that motor and oil consumption. It boils down to bad engineering and design right from the factory. If you don't have it fixed under warranty, which they make you jump the hoops and play games with running back & forth to the dealer, to having them officially say it consumes too much oil, they act like they never heard of the problem and want you to pay to fix it. I'll never buy another GM product after this piece of junk.,,,
Re: GM 2.0 Turbo LTG oil consumption (2015 Malibu 2.0 LTZ) [Re: metroplex] #5125650 06/05/19 07:26 AM
V
Virtus_Probi Offline
V
DI engines produce soot, so the oil will tend to look dark pretty quickly.
I notice that my oil will look somewhat dark even after I take a brief "test drive" following an oil change and then check the level after a cool down.
Within a week or so it will already look pretty black on the dipstick. This doesn't happen in my daughter's port injected engine.
This engine had some Low Speed Pre Ignition (LSPI) issues, but the 1.5l DIT in other Malibus seemed to have much more severe problems.
I doubt that this engine has LSPI piston damage if it is running well, but when the Subaru FA20DIT was recalled for LSPI some weird things like severely eroded spark plug electrodes were found.
Sticking with dexos1 Gen 2 oils is probably a really good idea...Amsoil SS should be fine as it has passed the d1G2 LSPI tests even though it does not meet the standard as a whole.
M1 5W30 is a great choice for this engine IMHO, I have used that more than anything else in my DIT.
It does sound like this engine is suffering and I doubt the owner is going to take the initiative to monitor her oil level and top off...maybe you could suggest a 3000 mile OCI so it does not run quite so low?
Are you sure there is no coolant system issue if the engine seems to be running super hot?
My car can display oil temp on one of its screens, maybe if her car has this function you could set it up to display that for her and she could tell you what kind of temps she sees?
It would be a shame to see this engine die so early!!
2014 Forester XT, 114800 miles
Last Change;
Valvoline AFS 5W30
Tokyo Roki 15208AA170 oil filter
Subaru 16546AA10A air filter
Re: GM 2.0 Turbo LTG oil consumption (2015 Malibu 2.0 LTZ) [Re: metroplex] #5125662 06/05/19 07:56 AM
2
2004tdigls Offline
2
the motor is done because it has obviously been run way to low on oil for extended periods of time
Re: GM 2.0 Turbo LTG oil consumption (2015 Malibu 2.0 LTZ) [Re: metroplex] #5125667 06/05/19 08:03 AM
ls1mike Offline
I have the same exact car with just at 60,000. Why are you running Amsoil? Mobil 1 5W-30. No make up oil between oil changes which I do at about 5000 miles.
Amsoil is not a good choice for that engine. As discussed by the 2.0 turbo guys on different forums. They are adding oil.
The ATS problem was 2013 with some cracked pistons. You can read all about it on line.
What does super hot mean? How are you quantifying that? How long was it between the last oil change that is got so black?
Sludge and coking on the part of the dipstick close to the turbo? Yep. Mine has that too. The heat bakes it on there.
[Linked Image]
You can see the dipstick here.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: GM 2.0 Turbo LTG oil consumption (2015 Malibu 2.0 LTZ) [Re: BigCahuna] #5125670 06/05/19 08:06 AM
ls1mike Offline
Your wife's engine is a 2.4 which shares nothing with the 2.0 LTG.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: GM 2.0 Turbo LTG oil consumption (2015 Malibu 2.0 LTZ) [Re: metroplex] #5125671 06/05/19 08:10 AM
demarpaint Offline
She was 2-3 quarts low when you changed the oil. I wonder how long and how often she ran the engine 2-3 quarts low on oil? That to me is neglect. The engine could have a defect, but this seems more like neglect to me. A 40 grade oil might help assuming there isn't an engine defect.
God Bless Our Troops
Re: GM 2.0 Turbo LTG oil consumption (2015 Malibu 2.0 LTZ) [Re: metroplex] #5125673 06/05/19 08:14 AM
M
M
How is Amsoil SS 5W-30 not a good oil for the LTG? Serious question. If you read my first post, her Malibu would get Mobil 1 5W-30 from day one up to 68,000 miles and I noticed it was about 2-3 quarts low at the first oil change I performed. With Amsoil 5W-30, the oil consumption is about the same. She insisted on the Amsoil as she has used that in the past on her other vehicles, but for circumstantial reasons she had the dealers change the oil on the Malibu and they used Mobil 1 5W-30.
I have other GTDI engines, the LNF (precursor to LTG), SHO's 3.5 EcoBoost, two Fusion Sport 2.7 EcoBoost, and none of them produce soot like this in the engine oil. Yes, there is soot in the tail pipe tips but never the oil. Like I wrote above, I pulled the dipstick from my Fusion Sport 2.7 EcoBoost and compared the oil color/condition against the Malibu since we both have similar miles on the oil. It was pretty much night and day, and keep in mind both are GTDI engines.
I'm going to check/replace the PCV valves (looks like there are 3 or 4 of them on the LTG). I'm considering a thicker synthetic oil, but I'm not sure if that would help.
Re: GM 2.0 Turbo LTG oil consumption (2015 Malibu 2.0 LTZ) [Re: metroplex] #5125675 06/05/19 08:16 AM
demarpaint Offline
That's a good idea.
Page 1 of 5 1 2 5
