Can I safely use STP Oil Treatment in my car
Originally Posted by ragtoplvr
I have a 91 dodge Dakota 4cy 5 speed that will not quit. It does use oil. If you run anything other than 5/10W30 in it there is a lifter tick that last for a while after starting. If you try to use XW40 or HM oil in it to cut the consumption the lifters DO NOT like it. But 10W30 and STP 4CY , no tick, oil consumption cut in half. It is NOT sitting on the bottom of the pan. It is doing something. I may be one of very few, but for me it works
Rod
All it did was thicken the viscosity and weakened the additve pack.
It's not a miracle cure, but it CAN quiet down noisy engines. I just added it to my Soul that has a clattery valvetrain at start up. Dulled the noise a bit, but is still there.
I'd try a HM 5w20 or 5W30 and a different filter. If that doesn't help Schaeffers #132 will accomplish what you're trying to do, and it is considered a much better product than STP by many on Bitog.
Originally Posted by JC1
As others have said, skip the STP. I would try a different oil. What is currently in the sump now?
I'm just using Carquest conventional 5w-20. Black jug.
I would try a 40 grade oil.
I agree, put a heavier weight oil in there. STP's not doing any appreciable thickening of the 5W20 towards the goal you have. In days gone by it was additional zinc the STP provided. I don't believe it provides enough ppm per volume to do anything worthwhile in terms of that anymore. Pure feel good for the owner, car doesn't know.
I'm currently running 5w-20 which is what is specified. Looking at the old maintenance logs in the owners' manual, the previous owner used 5W-30 a lot. Interesting
There may well have been a reason why the previous owner chose that weight. Go back to that weight and note any changes -- is the sound better, or worse?
