2008 Acura TL Timing Belt/Component Kit
by BAJA_05 - 11/12/19 02:06 PM
Installing decals and emblems in cold weather
by atikovi - 11/12/19 01:39 PM
Skyactiv 20,000 mile OCI with Oil Analysis
by thegameq - 11/12/19 01:23 PM
Stihl KM110R Carburetor Adjustment
by henni - 11/12/19 01:10 PM
Mix and match wheel cylinder brands?
by RocketUSA - 11/12/19 12:45 PM
Changing spark plugs based on age and not mileage
by Hootbro - 11/12/19 12:44 PM
Lug bolts failing
by Ndx - 11/12/19 11:43 AM
Fram cartridge filter
by Bettez88 - 11/12/19 11:34 AM
Long Term Hemi Redline 5w30 vs PUP 0w40
by burla - 11/12/19 11:26 AM
This Could Very Well Finish Off Remington
by billt460 - 11/12/19 11:01 AM
Check out the paint job on this BMW
by zzyzzx - 11/12/19 10:32 AM
New label on Castrol edge at Walmart
by mazdamonky - 11/12/19 09:14 AM
HEPA Filters
by Passport1 - 11/12/19 07:20 AM
Outlander Plug-in Hybrid EV
by Snagglefoot - 11/12/19 03:30 AM
Slick 50
by rrretiree7 - 11/12/19 01:19 AM
Need Spring Compressor OTC 6494?
by Wolf359 - 11/12/19 12:48 AM
2009 Accord V6 terrible MPG
by JEL01 - 11/11/19 11:04 PM
How to fix exhaust broken at the flange?
by slacktide_bitog - 11/11/19 10:53 PM
Bugs Bunny
by red7404 - 11/11/19 10:40 PM
Scuder, Jasonrmcc, Capacc, allofoil, RDY53
69838 Registered Users
105 registered members (53' Stude, 928, 4WD, 2dogs, 1978elcamino, 28oz, 10 invisible), 2,302 guests, and 19 spiders.
Topics297,314
Posts5,112,921
Members69,838
Most Online3,589
Nov 2nd, 2019
What causes High Pressure in AC System #5125064 06/04/19 11:32 AM
N
NICAT Offline OP
N
Hi.
AC compressor was leaking. Took it to repair shop.
When i went to get it i was suprised that they have removed 2 sensors on it and closed the holes.
They claimed that those sensors were too bad, are common point of the leak, and are unnecessary. To proof it, they told that new compressors for the same model cars do not have those sensors.
I made some research. There are total 3 sensor on the AC system.
One sensor on hose (low pressure sensor). If there is no freon, it breaks the circuit.
And 2 Sensors on the compressor. One is High pressure sensor (ON/OF sensor. it increases fan speed if there is high pressure) and the other is Ultra High Pressure sensor. Which breaks the circuit again in orter the save AC (or may be prevent freon leak through the valve)
Actually without those sensors AC can actually run. But without any protection. We can make Fan run at its maximum speed all the time at the cost of fan life.
I am planning to buy replacement Compressor. it is 70$. They will install it for free. But since it is summer, it is difficult to find one.
So i want to use this for a while.
The question is, Is there anything that i can do in order to reduce chance of high pressure ? What causes High Pressure in AC System ? Higher RPMs ? or when AC runs for a long period of time or Stop-&-Go Traffic ?
Regards.
Re: What causes High Pressure in AC System [Re: NICAT] #5125078 06/04/19 11:46 AM
K
KrisZ Online Content
Online Content
K
As you noted these sensors are mainly there to protect the system. There are variatey if scenerios where the system can run high pressure, like the evaporator coil freezing up in high humidity, low wet bulb temp situations.
If your condenser doesn't get proper airflow, due to fan failure or something physically blocking it, the system will run higher pressures.
If the system is overcharged, it will run higher pressures.
I'm sure there are other scenarios as well.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: What causes High Pressure in AC System [Re: NICAT] #5125079 06/04/19 11:46 AM
B
bullwinkle Online Confused
Online Confused
B
High engine RPMs, combined with high ambient temperatures, usually in stop & go driving. Often combined with a bad fan clutch, overcharged system, or bad electric fan/switch, & a dirty condenser. How hot does it get in Azerbaijan? 35C or so?
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: What causes High Pressure in AC System [Re: bullwinkle] #5125082 06/04/19 11:48 AM
N
NICAT Offline OP
N
Hi. Thanks for detailed explanations smile
It is 45C Max. Average in summer is 41/42 (afternoon)
Re: What causes High Pressure in AC System [Re: NICAT] #5125103 06/04/19 12:11 PM
W
WobblyElvis Offline
W
You want to make sure the condenser coil is clean and free of bugs/debris. This will help keep the pressure down and run more efficiently.
Re: What causes High Pressure in AC System [Re: NICAT] #5125104 06/04/19 12:11 PM
DoubleWasp Offline
Consider that they are performing a modification that may reduce the life of the fan, and that when it fails there will be absolutely nothing to stop the system from going ridiculously overpressure.
the real question is, why don't they have it on the newer models? Is it perhaps because they use a compressor with a pop off valve that protects the system, and a fan management system that negates the need for a fan pressure switch? perhaps the newer model has a fan management system that automatically kicks the fan up high simply from electronically sensing compressor activation?
this is the way that it is done on most vehicles, so it is important enough to know why these changes were made and how the system works on the newer models.
If they were really smart, what they would do is eliminate the 2 sensors that you mentioned, and then replace your low pressure switch with a trinary switch to manage all three functions from a single point. That would leave you without all of the extra connections and still maintain all of the functions that you described above.
Re: What causes High Pressure in AC System [Re: NICAT] #5125106 06/04/19 12:16 PM
Chris142 Offline
Not enough air flow over the condenser and over charging will both create high pressures. No air flow can cause the pressures to go ballistic I just a few seconds.
Your ac shop are absolute idiots! Pull your car from them and get it fixed properly. Do these dummies even have an ac machine or are they still charging with small cans?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: What causes High Pressure in AC System [Re: NICAT] #5125107 06/04/19 12:16 PM
M
mk378 Online Content
Online Content
M
When it does go ridiculously overpressure, either the relief valve will open if it has one, or some part (usually the high side hose) will burst. Either case will cause loss of most or all of the refrigerant. The relief valve doesn't always close properly. If someone is working under the hood at the time, a bursting hose is a personal injury risk.
Cross that shop off of your list of places to use.
Re: What causes High Pressure in AC System [Re: DoubleWasp] #5125115 06/04/19 12:29 PM
N
NICAT Offline OP
N
It is because, on the hose, in my model there is 2 pin sensor. Low pressure sensor. ON/OF. it breaks the circuit if there is no freon.
But in newer models there is 3 pin sensor on the same hose. which gives clear information to the ECU about the pressure in the system. So ECU knows if the pressure is Low, High and Too High.
So one sensor+ ECU does the job of 3 old sensors smile
This sensorless compressors misleaded the shop.
Re: What causes High Pressure in AC System [Re: NICAT] #5125121 06/04/19 12:40 PM
M
Online Content
M
If you're saying the original compressor didn't have sensors because the car has a 3 wire sensor somewhere else and it's integrated with the ECU, then buying the wrong compressor and just leaving the extra sensors unconnected would be OK.
It doesn't seem that you're saying that though.
Re: What causes High Pressure in AC System [Re: WobblyElvis] #5125124 06/04/19 12:42 PM
B
berlyn Offline
B
+1
Re: What causes High Pressure in AC System [Re: mk378] #5125127 06/04/19 12:42 PM
N
NICAT Offline OP
N
Yes it is clean. i cleand it myself by removing all the bugs one by one smile
They were just compressor rebuilders.
Not charging.
Surprsingly even the most famous charging shop in the country, told me "Dont worry. they have done the right thing" smile
It has relief valve. But as you stated, it may not function properly all the time.
Re: What causes High Pressure in AC System [Re: NICAT] #5125187 06/04/19 01:33 PM
L
Linctex Offline
L
I do not envy you.... it must be difficult finding a good mechanic in Azerbaijan
Re: What causes High Pressure in AC System [Re: Linctex] #5125192 06/04/19 01:46 PM
A
AC1DD Offline
A
@NICAT
Best bet for good service would be in Tbilisi, Georgia. Have you thought of that? It's not that far from you.
Re: What causes High Pressure in AC System [Re: Linctex] #5125195 06/04/19 01:55 PM
N
NICAT Offline OP
N
In my bmw, there was fluctuating rpm problem.
Too much work done on the engine, transmission, tons of money was spend. In the end it turned out to be wrong oil level in the gearbox. They didn't know about ZF's oil change guide. They believed that they should fill as much oil as they could.
Actually the main reason is that, if a kid is very bad at school, (not always, but most of the time because of low IQ) His parents find some mechanics. So their son can learn and have some practice near him. And become a mechanic in the future.
So due to Natural Selection :), Most of the mechanics in the country are the ones who were very bad at school.
