Is my transmission fluid overfilled? Scion xB '10
by puredata - 08/22/19 02:38 AM
Which are you?😂
by Mad_Hatter - 08/22/19 12:21 AM
The Fatal Flaw...
by Mad_Hatter - 08/21/19 10:58 PM
early OCI because of HIGH REVVING
by tahoe_hybrid - 08/21/19 10:38 PM
API diesel / gas ratings
by KiwiBiker - 08/21/19 10:18 PM
For the XOM fans!
by Marco620 - 08/21/19 09:43 PM
I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
oilq, Nesss, Robto, Chaparro_trucker, KiwiBiker
69027 Registered Users
17 registered members (80Boxcar, Bailes1992, 4WD, bonjo, dieselguy67, CATERHAM), 613 guests, and 22 spiders.
Topics293,636
Posts5,043,861
Members69,027
Most Online3,532
Jul 30th, 2019
Plug wires replacement interval #5125000 06/04/19 11:13 AM
Z
zmelli Offline OP
Z
I own a 1996 Acura Integra with the B18 non-vtec engine. 130K miles runs perfect. Original plug wires. I was thinking about changing the wires but don't want to waste money. On the other hand, I like to replace things before they fail. Any thoughts on this?
06 Acura TSX 6-Speed/GC 0W40/OEM Acura Filters
91 Honda Accord/Castrol 0W40/Micro T7316
93 Honda Accord 0W-40Edge/Micro T7316
96 Acura Integra SE
Re: Plug wires replacement interval [Re: zmelli] #5125003 06/04/19 11:16 AM
J
Jimzz Offline
J
They use to be done every 100k. But the last several generations I have seen then go 150-200k without major issue.
I would change them the next time you do the timing belt/spark plugs unless its running poorly.
yup
Re: Plug wires replacement interval [Re: zmelli] #5125004 06/04/19 11:17 AM
slacktide_bitog Offline
You might as well replace them. Usually you replace the plugs and wires at the same time smile
NGK makes a good set of wires. They are numbered and come in a nice blue color smile
Just be glad you have the 96+ non-VTEC with the PCV valve on the valve cover. The pre-96, and all years for the VTEC, have the PCV valve behind the engine and it's hard to get to mad
Re: Plug wires replacement interval [Re: zmelli] #5125005 06/04/19 11:18 AM
Chris Meutsch Offline
A set of Denso wires is $29 on Rockauto. After 23 years, I'd change them and the distributor/rotor also.
2005 Honda CR-V EX, 275k
Re: Plug wires replacement interval [Re: zmelli] #5125016 06/04/19 11:31 AM
K
KenshinHimura Offline
K
The ones on my Eclipse I replaced this year due to the OEMs (made in 1996) were dry rotting
1997 Mitsubishi Eclipse Spyder Penzoil Plat 5w30 Silver Can Of Trico filter
2019 Hyundai Veloster Turbo Whatever 5w30 synthetic the dealer uses OEM filter
Re: Plug wires replacement interval [Re: zmelli] #5125031 06/04/19 11:46 AM
K
Kira Offline
K
Caveat: Just because a set of wires is clad in nice, new silicone compound rubber doesn't mean the inwards are quality.
Buy quality (you know that, just sayin')
Have you done the "Open the hood on a moist night with the engine running" test to check for dancing sparks?
Does it make sense to measure the resistance?
Can "wire wires" be used or are they all carbon impregnated rope for RF suppression? The old aircraft mechanic next door would only use wire wires.
Re: Plug wires replacement interval [Re: zmelli] #5125045 06/04/19 12:13 PM
R
Rat407 Offline
R
A friend has 369k miles one the original plug wires on his 2004 suburban. Still runs great.
To me no need to change them unless you need to. Not like they will all go bad at once. Mainly you will have an issue with one cylinder and so when that occurs you can then just do the entire set.
Otherwise if you have the cash and can do it yourself and it makes you fee.l better then change them out now.
2002 Silverado 5.3 0w-20 AMSOIL
Re: Plug wires replacement interval [Re: zmelli] #5125046 06/04/19 12:14 PM
W
WobblyElvis Offline
W
I haven't changed plug wires in 20- 30 years. They seem to last forever. I carry a roll of electrical tape so I can repair a wire if I see a spark jumping to ground. If you have a cap and rotor they are more likely to cause problems. IMO.
Re: Plug wires replacement interval [Re: Rat407] #5125053 06/04/19 12:22 PM
M
Mad_Hatter Offline
M
That was my dilemma recently. I had 150k on the original CoP's, no ignition problems whatsoever. The OE's are Denso. I had to pull the plenum off to do the plugs (a 2hr job), so I decided to just put new CoP's on since I was already there. I checked around in a users group and called the dealership to see if I could get some consensus on longevity - none. They could easily go another 150k or they could go tomorrow.
Even with s/h charges RA had the best prices on the OE's..
Re: Plug wires replacement interval [Re: Kira] #5125054 06/04/19 12:22 PM
N
nthach Offline
N
I've been disappointed in Denso wires, they are not made by Denso themselves - they aren't getting them from Seiwa or one of the Japanese plug wire suppliers(or even Prestolite). Bosch disappoints me as well, even where they are OEM. It seems like getting wires at the dealer or using NGK/Motorcraft/Delco(if your car has them available) is the only way to get good wires.
The open hood on a dark night/garage test seems to work pretty well to diagnose wires besides feel and looks. You will need a megger to test the insulation otherwise.
Re: Plug wires replacement interval [Re: Kira] #5125056 06/04/19 12:24 PM
T
Trav Offline
T
When McDonalds first opened their drive up windows I was driving a big block Chevelle SS with metallic core wires, it drove their equipment crazy. LOL
Re: Plug wires replacement interval [Re: zmelli] #5125058 06/04/19 12:26 PM
M
mk378 Offline
M
If you did experience misfiring, those 20 year old wires would be the first thing to suspect. But if running OK you could see how much longer they'll go(*). Visual inspection of wires or ohm tests won't always show when they are bad.
(*) Though you don't want to get in a situation where you end up in a time crunch buying a set of lousy wires from a chain parts store and having them fail in a year or less.
Re: Plug wires replacement interval [Re: zmelli] #5125081 06/04/19 12:47 PM
J
JLTD Offline
J
23 years? It's time.
You may notice it runs smoother...
I use the overseas manual to choose my oil viscosity.
Using AMSOIL
Hers: 2008 Jeep Liberty 149k, SS5w30/Amsoil
His: 2015 4Runner 55k, SS 5w20/Amsoil
Re: Plug wires replacement interval [Re: zmelli] #5125128 06/04/19 01:46 PM
J
JeffKeryk Offline
J
Acura wires would be best, but are pricey.
I have used NGK on Honda engines with great results.
Don't forget a little dielectric grease....
Amazon is your friend.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Plug wires replacement interval [Re: zmelli] #5125139 06/04/19 01:55 PM
Z
zmelli Offline OP
Z
I went ahead and ordered NGK RC-HE82 from AMAZON Warehouse deals for $23! I think the RC P/N made be the Made in Japan wires. There are two P/Ns for these HE82 and the RC-HE82 not sure of the difference. Maybe where they are made? Got to love Warehouse deals for deep discounts on parts for older Cars.
96 Acura Integra SE
