Best Shell/Pennzoil is ?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
bagyoau, frank57, gheewala114, Rob_Jeff, BrianinTucson
68412 Registered Users
38 registered members (AndyB, BlueOvalFitter, Bighorn2500, chemman, 8 invisible), 638 guests, and 19 spiders.
Topics290,259
Posts4,987,225
Members68,412
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: Plug wires replacement interval [Re: zmelli] #5125247
06/04/19 04:24 PM
06/04/19 04:24 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Leave the new leads in the trunk until it need them.
Rule #1
Don't mess with hi tension ignition if it is working well.
You see, It wants to do anything but work well.
Packard used to make good hi-tension leads - even the Japanese sourced Packard
Never had much luck professionally with anything else.
You don't want metal core wire. Incorrect impedance for the ignition circuit. HUGE and dangerous RFI.
Likely violates FCC law. Also never found magwire helpful, but I never ran alky with a magneto.
2019 VW Jetta S,6M OCI#0 3107mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Plug wires replacement interval [Re: zmelli] #5125286
06/04/19 05:41 PM
06/04/19 05:41 PM
California
nthach Offline
nthach  Offline
California
Some cars, more so German cars do call for metal-core wire with the appropriate resistive plug boots/covers.
Re: Plug wires replacement interval [Re: slacktide_bitog] #5125302
06/04/19 06:18 PM
06/04/19 06:18 PM
California
vavavroom Offline
vavavroom  Offline
California
Originally Posted by slacktide_bitog
NGK makes a good set of wires. They are numbered and come in a nice blue color smile
I have cut NGK/NTK silicone spark plug wires. The jacket consists of an outer blue layer of silicone and the inner jacket out of white silicone. The core is a multistrand silver-colored wire, although it says on the wire jacket "copper." By the way, why do we call them spark plug cables? They are wires.
Re: Plug wires replacement interval [Re: Trav] #5125305
06/04/19 06:23 PM
06/04/19 06:23 PM
USA
oldhp Offline
oldhp  Offline
USA
"When McDonalds first opened their drive up windows I was driving a big block Chevelle SS with metallic core wires, it drove their equipment crazy. LOL"
When I would be driving one of my "toys" always with a MSD 6 box............I never bothered to stop at the speaker......I just drove up to the window. grin
2018 RAM 1500 3.6/8 speed.
2019 Dodge Charger SXT 3.6/8 speed.
"When others cut you down, remember where they came from."
Re: Plug wires replacement interval [Re: vavavroom] #5125687
06/05/19 08:33 AM
06/05/19 08:33 AM
N.H, U.S.A.
N.H, U.S.A.
BC there is NO wire in high tension ignition cables - unless its aftermarket "MAG Wire"
The Copper notation was for the terminals ONLY - not the wire. '
The center insulator is typically EPDM rubber.
You don't want or \need low impedance "wire" for super high voltage pulse ignition. It doesn't help. And the FFC will chase you.
Re: Plug wires replacement interval [Re: ARCOgraphite] #5129611
06/09/19 07:10 PM
06/09/19 07:10 PM
California
vavavroom Offline
vavavroom  Offline
California
There is definitely a wire core in this OE replacement wire. I'll have to look for the wire. Maybe I can find it.
Re: Plug wires replacement interval [Re: zmelli] #5129684
06/09/19 08:26 PM
06/09/19 08:26 PM
Minnesota
philipp10 Offline
philipp10  Offline
Minnesota
Originally Posted by zmelli
I own a 1996 Acura Integra with the B18 non-vtec engine. 130K miles runs perfect. Original plug wires. I was thinking about changing the wires but don't want to waste money. On the other hand, I like to replace things before they fail. Any thoughts on this?
Generally speaking, if it ain't broke, I leave it as is. In the case of wires, I wouldn't change until I needed to. More than likely they will never need changing unless your keeping the car a very long time.
Re: Plug wires replacement interval [Re: zmelli] #5129696
06/09/19 08:37 PM
06/09/19 08:37 PM
Cajun Country, La.
BlueOvalFitter Online happy
BlueOvalFitter  Online Happy
Cajun Country, La.
What I usually do is replace the plugs at 100K miles, or when my gas mileage and performance start to drop off. The wires get changed at that time too. YMMV.
"One Filter, One OCI!"
2007 F150, 4.2 V6
Havoline HM 5W20, MC FL-400S
"One Box, One OCI!"
Re: Plug wires replacement interval [Re: zmelli] #5129705
06/09/19 08:40 PM
06/09/19 08:40 PM
out there
spasm3 Offline
spasm3  Offline
out there
I generally replace the wires with the plug change. I did replace wires every other plug change back in 80's before i was using precious metal plugs.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Plug wires replacement interval [Re: zmelli] #5129906
06/10/19 04:42 AM
06/10/19 04:42 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Spray the wires down with water at night. No light show, I would keep using them.
The "thinking" man's friend.
Re: Plug wires replacement interval [Re: ARCOgraphite] #5131673
06/11/19 07:16 PM
06/11/19 07:16 PM
California
vavavroom Offline
vavavroom  Offline
California
What alloy is the wire?
[Linked Image]
Re: Plug wires replacement interval [Re: zmelli] #5132148
06/12/19 09:19 AM
06/12/19 09:19 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Do you hear a tick , tick , tick or click , click , click under the hood? Then look for sparks jumping , at night / in the dark .
Is it missing / cutting out ? Spray water on them . Any changes ?
How long do you plan to drive it ? Long time , more ? If it makes you sleep better , buy a set of plug wires & put them away , in the trunk , for when / if the old ones go bad .
I have replaced plug wires only a few times . When they started going bad & causing problems .
Wyr
God bless
Page 2 of 2 1 2
