P21S Windshield Wash Booster
by Duffyjr. 07/21/19 05:25 AM
Transmission Swap
by Ponchinizo. 07/20/19 11:41 PM
Ecogard S4477
by Steiny. 07/20/19 11:25 PM
Manny Pacquiao vs Keith Thurman
by Warstud. 07/20/19 11:06 PM
Fuel Tanker Driver Here
by GoldDot40. 07/20/19 10:25 PM
Overfilled diff?
by HoosierJeeper. 07/20/19 10:02 PM
Brake Surge - Lexus
by MaximaGuy. 07/20/19 09:55 PM
Oil Rec for Street Driven & Track Usage
by randomhero439. 07/20/19 09:46 PM
Paint correction lighting setup for white paint
by Reddy45. 07/20/19 09:07 PM
Cannot pull credit report for wife
by Klutch9. 07/20/19 08:24 PM
Toyota 2AZ - FE!??
by miden851. 07/20/19 08:23 PM
What about the Chevy Trax?
by gregk24. 07/20/19 08:06 PM
Authentic 100% Synthetic 5W30/0W40 engine oil
by Denali376. 07/20/19 07:59 PM
Any Towing Reviews with New Tacoma V6 Manual 4x4?
by oilpsi2high. 07/20/19 07:39 PM
Synthetic 5W30 D1/Gen2 vs. Synthetic 10W30 ?
by ChrisD46. 07/20/19 07:00 PM
ECOGARD X4612 NEW FILTER CUT OPEN
by 53' Stude. 07/20/19 06:48 PM
Show me your dinner
by 53' Stude. 07/20/19 05:52 PM
Shelf life of Gumout fuel injector cleaner
by pentode. 07/20/19 05:24 PM
grikor, Mikelima, mannydingo, Roadtripp, Denali376
68720 Registered Users
45 registered members (AlienBug, bbhero, 65convertible, cjcride, chunt, 53' Stude, 5 invisible), 675 guests, and 22 spiders.
Topics292,177
Posts5,018,151
Members68,720
Most Online2,967
Mar 10th, 2019
Page 4 of 6 1 3 4 5 6
Re: Engine done for? Some hope? [Re: JLTD] #5124504
06/03/19 07:47 PM
06/03/19 07:47 PM
New Orleans La
Bullet Offline
Bullet  Offline
New Orleans La
My vote it's the bearings. It's possible trash was in the cooler and was sent into the bearings. It the pan is still down I'd replace the bearings. If you spin a bearing you will have rod issues also.
Re: Engine done for? Some hope? [Re: TimeRS4] #5124515
06/03/19 08:01 PM
06/03/19 08:01 PM
WA
vw7674 Offline
vw7674  Offline
WA
If the oil pan is off why not pull a rod cap & inspect?
The analysis may be useless if copper anti seize was pumped into the sump.
Re: Engine done for? Some hope? [Re: heynow] #5124539
06/03/19 08:39 PM
06/03/19 08:39 PM
Virginia
bbhero Online content
bbhero  Online Content
Virginia
Originally Posted by heynow
I would:
1) Get an accurate oil gauge on the engine, and see how the pressure compares to what is spec'd.
2) Change the oil again in 500 miles and see what you find in it.
3) Pull the pan and do a visual inspection of at least some of the bearings, if not too labor intensive.
It seems possible that some copper manufacturing debris could have been in the replaced cooler lines, but that seems a bit excessive. I would do at least a few frequent oil changes to flush the system, and then make UOA's a habit to monitor what is going on.
This is a great list.
Nissan Altima 3.5 Coupe
Carquest High mileage full synthetic 5w30
CQ blue 84356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Engine done for? Some hope? [Re: bbhero] #5124546
06/03/19 08:44 PM
06/03/19 08:44 PM
GoVols
kstanf150 Offline
kstanf150  Offline
GoVols
Seems to be we’re all taking a SWAG at this deal
Re: Engine done for? Some hope? [Re: TimeRS4] #5124547
06/03/19 08:45 PM
06/03/19 08:45 PM
Norcal
TimeRS4 Offline OP
TimeRS4  Offline OP
Norcal
That's the oil drain capture pan. Not the actual oil pan off of the engine
Re: Engine done for? Some hope? [Re: TimeRS4] #5124552
06/03/19 08:48 PM
06/03/19 08:48 PM
Maricopa Arizona
dave1251 Offline
dave1251  Offline
Maricopa Arizona
What is the PSI at the recommended grade? The funny thing about engines even with all this copper it may run fine for another decade or within 10 hours of use it may go.
don't use.
Re: Engine done for? Some hope? [Re: TimeRS4] #5124556
06/03/19 08:51 PM
06/03/19 08:51 PM
Suburban Washington DC
atikovi Offline
atikovi  Offline
Originally Posted by TimeRS4
Originally Posted by atikovi
What did the PPI report say?
My first mistake: didn't get 1 done
Plus, not sure if a simple PPI would have discovered the shavings/flakes or whatever it is
I assume they check the dipstick and the copper should show pretty clearly. And if the engine takes a dump in the first month or two, you have someone to blame or at least make repairs at a steep discount.
Re: Engine done for? Some hope? [Re: TimeRS4] #5124557
06/03/19 08:52 PM
06/03/19 08:52 PM
New Hampshire USA
Dinoburner Offline
Dinoburner  Offline
New Hampshire USA
If the material is from the inserts there should be lead babbit and copper, from the pics it looks like the copper is from some other source. With all the disparate clues the rods should be checked then go from there.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Engine done for? Some hope? [Re: atikovi] #5124561
06/03/19 08:56 PM
06/03/19 08:56 PM
Norcal
TimeRS4 Offline OP
TimeRS4  Offline OP
Norcal
The dipstick didn't pick up the flakes. Though the oil was a little darker than clean oil, the flakes were not visible.
Re: Engine done for? Some hope? [Re: TimeRS4] #5124865
06/04/19 08:02 AM
06/04/19 08:02 AM
DELAWARE
Hootbro Offline
Hootbro  Offline
DELAWARE
Bunch of stabbing guesses here. If me, I would start submitting an oil sample and then run it for a OCI and resubmit for another oil sample and see what trends up or down. I would do this for at least 2-3 OCI's. If copper trends down, then more than likely the oil cooler replacement.
2020 Jeep Gladiator Rubicon 3.6L (Factory Fill 0W-20)
2017 Jeep Renegade Latitude 2.4L (Idemitsu 0W-20)
Re: Engine done for? Some hope? [Re: NoNameJoe] #5124872
06/04/19 08:09 AM
06/04/19 08:09 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Originally Posted by NoNameJoe
Maybe some kind of oil additive? There are additives that have soft metals in them, like engine restore. Engine restore uses a "CSL" formula which to my knowledge is copper, silver and lead. The formulation is supposed to be small enough in microns that they shouldn't be visible.
The bottle does state to shake well as the first instruction step. I suspect if it does precipitate out over time it could build up and be visible? I have no idea how it would react in an oil pan over time.
Hypothetically even if engine restore caused it, why did the owner use engine restore? That in and of itself may be indicative of a problem.
Exactly what I was thinking. I would do a compression and leak down test, and at least get an idea of how things are looking based on those tests. Then a couple of short OCI's and hope for the best. A UOA now and after the short OCIs might be of some benefit. As mentioned it could also be copper from part replacements.
God Bless Our Troops
Re: Engine done for? Some hope? [Re: kstanf150] #5124954
06/04/19 10:00 AM
06/04/19 10:00 AM
New England
gathermewool Offline
New England
OP, do any of the mods that this car has require it to be professionally tuned? Anything that was change with the intake, air in or out geometry will need a tune.
Not all. Many are asking pertinent questions and making educated guesses based on the information we have.
Those who post, "that thing is TOAST!", not so helpful...
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Magnatec 5W-20 + FU filter (47,300 miles)
Re: Engine done for? Some hope? [Re: TimeRS4] #5124986
06/04/19 10:50 AM
06/04/19 10:50 AM
Florida
1978elcamino Offline
Florida
You never really know what viscosity was in the engine when you got it, could it be a higher viscosity masking a problem? possibly, you never know. If it were me, I would change the oil and filter, maybe a good 5w40 - 10w40, give it a run of about 2k and then change it again. If it were flakes from work done then you will not see nearly as much this time. The change you do would be the sample to send in because you know what you poured in and the true run time on the oil. After this you can begin diagnosing.
2018 F150 5.0
2016 Ford Fusion 2.5
Re: Engine done for? Some hope? [Re: TimeRS4] #5125029
06/04/19 11:45 AM
06/04/19 11:45 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
That much has to have a serious source. Could deft be thrust bearing. I've seen a lot that appear to be exposed copper straight out of the box.
Crank walking takes quite a bit to start making noise. I'd check the crank play for sure. May be tough to pull off since that engine is smashed in there and then has shims inserted (other parts) to make it extra tight.
Re: Engine done for? Some hope? [Re: TimeRS4] #5125222
06/04/19 03:29 PM
06/04/19 03:29 PM
CO
JLTD Offline
JLTD  Offline
CO
Let's just assume it is the above anti seize compound. What damage has been done?
If it's anti-seize you are good to go!
I use the overseas manual to choose my oil viscosity.
Using AMSOIL
Hers: 2008 Jeep Liberty 149k, SS5w30/Amsoil
His: 2015 4Runner 55k, SS 5w20/Amsoil
