Fram Ultra - Hot Tub Filter
by SavagePatch - 11/19/19 10:08 PM
Possible bad coil on Husky 150bt
by i6pwr - 11/19/19 09:52 PM
JD LVU800097
by Jason_Michaels - 11/19/19 09:09 PM
Chiappa M1-9
by GumbyJarvis - 11/19/19 09:05 PM
Power steering fluid change out; frequency.
by GeorgeMP - 11/19/19 08:59 PM
2020 Toyota Supra
by Y_K - 11/19/19 08:57 PM
Door hinge pins and bushings
by P10crew - 11/19/19 08:22 PM
future new car prices-gas vs electric
by 1978elcamino - 11/19/19 07:51 PM
Briggs/ Walbro idle tuning
by eljefino - 11/19/19 07:46 PM
Shell Rotella Gas Truck 0W-20, 9349 miles FCA 2.4
by austinlunsford - 11/19/19 06:53 PM
06' V6 Accord 12,462 miles Penzoil Platinum 0W20
by Daschicken - 11/19/19 04:57 PM
Pride Asian Plus Coolant-thoughts?
by N Heat - 11/19/19 04:21 PM
Should it really take this long?
by IronMaidenRules - 11/19/19 02:21 PM
Does Ford use Hall Effect sensor for the APPS?
by LoneRanger - 11/19/19 02:09 PM
Cubez007, dshadow, Hansvoytek, DeltaP71, 300Kncounting
69918 Registered Users
39 registered members (BigJohn, Aero540T, 4WD, bdcardinal, 3 invisible), 1,182 guests, and 23 spiders.
Topics297,659
Posts5,120,127
Members69,918
Most Online3,589
Nov 2nd, 2019
Possible new used truck-2008 F150 #5124591 06/03/19 08:26 PM
W
Wagonmaster261 Offline OP
W
I looked a bit at a F150 I saw for sale.
2008 4x4 regular cab long box.
XL trim, so rubber floor and hand crank windows, which is fine by me.
Going by the VIN it has a 4.6, so it shouldn't have any of the 5.4 or 3v issues.
Sign in the window listed:
180,000 miles
New tires
Brakes
Front coils-Ball joints-Control arms-Steering linkage
Spark plugs
New alternator
Runs rough (may need coils)
$4000
Lower corners of the front fenders have small rust holes, and some surface rust in the box. No liner or topper. For a truck in Wisconsin it looked decent to me, even after crawling under it a bit. It does look a lot better than my 94 F150.
Dealer sticker on tailgate is from the local dealer a few miles down the road from where it is parked.
Anything to watch out for in F150s of this vintage? Depending on how it runs, is the price decent?
02 Focus ZTW Zetec M1 0w30
03 Windstar 3.8 M1 0w30
96 Windstar 3.8 M1 0w30
94 F150 300 Whatever doesn't leak out too fast...
Re: Possible new used truck-2008 F150 [Re: Wagonmaster261] #5124596 06/03/19 08:32 PM
1
14Accent Offline
1
4.6? You'll be fine. All the major stuff has been done, they do have a tendency to break front coil springs so that's good. The running rough could be anything, but I certainly wouldn't offer $4,000 for it. $2,500-$2,800 as-is.
Very few people want a used truck with NO options. You could probably find a XLT or even a Lariat for that price, but then you would have 5.4 issues so I don't recommend that.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Possible new used truck-2008 F150 [Re: Wagonmaster261] #5124601 06/03/19 08:35 PM
P
PPWarrior Offline
P
You are overpaying
Re: Possible new used truck-2008 F150 [Re: Wagonmaster261] #5124605 06/03/19 08:39 PM
G
Greggy_D Offline
G
4 grand? They're nuts.
Greggy D.
Re: Possible new used truck-2008 F150 [Re: Wagonmaster261] #5124618 06/03/19 08:47 PM
J
joegreen Offline
J
Make sure you check the inside of the frame from the cab back especially on the gas tank side. Hit it with your fist or a hammer. They like to rot from the inside out. They will look good but be paper thin and huge chunks can come off
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: Possible new used truck-2008 F150 [Re: Wagonmaster261] #5124640 06/03/19 09:11 PM
W
W
It was parked and I looked at it. $4k was the price listed on it. I wouldn't pay $4k as it sits. I would also need to find a topper or bed cover or something to make the bed usable.
Date code on the tires is 2017, so those should be decent.
My 94 F150 is also XL trim with rubber floor and hand crank windows. I use it as a spare vehicle when I need to do truck things. The 94 is getting a bit rotten, so this could be a 14 year newer replacement, with 90 more horsepowers. laugh
Thank you for where to look for frame rot.
What kind of highway MPGs could I expect? I can get 20 mpg from the 94 F150 driving at a respectable speed (55-60 mph), and my Windstars usually get 20-23 mpg.
Re: Possible new used truck-2008 F150 [Re: Wagonmaster261] #5124649 06/03/19 09:23 PM
M
MNgopher Offline
M
Check the cab corners for rust too. Checking the frame is also advisable. I broke 1 coil spring on mine, so the fact they are already done is a plus.
The 4.6 is a dog in that vintage of truck. I had two 4.6 powered trucks (a 97 and a 99). Drove 04-08 F150's at work, all with the 4.6, and they were just slow in that truck. Dependable, yes (and much more so than the 3V 5.4 as the miles pile on).
As far as highway MPGs, don't expect anything great. We had 5.4 and 4.6 trucks in the work fleet (my department were all 4.6 engines). They averaged within a 0.5 mpg of each other. Fuelly seems to match that result. Those trucks averaged 14.5 mpg in our fleet.
Re: Possible new used truck-2008 F150 [Re: Wagonmaster261] #5124744 06/04/19 03:40 AM
L
Linctex Offline
L
My 2008 F150 is a 4.6 - - - but 2WD.
192,000 miles - the only thing I have ever replaced was the alternator, and the main power window switch.
Everything else is original.
Power is fine - you'll probably drive around unloaded most of the time. 260 HP is much better than the 2004 and under year models.
Regular trans fluid changes keeps the trans alive.
I often pull 8,000 - 10,000 lbs and it does great. I feel it's more "torquier" than the ol' 300-6 from years past.
I get about 17.9 MPG lifetime average. Even pulling a loaded trailer it barely drops into the low 15's. I have seen mid-19's MPG when running zero ethanol and driving under 60 mph. Highway speeds kills the MPG - - stay at 55 mph and you could see 20 mpg.
Mine doesn't use a drop of oil. The dipstick oil level does not move at all in 10,000 miles.
Re: Possible new used truck-2008 F150 [Re: Wagonmaster261] #5124773 06/04/19 05:00 AM
A
atikovi Offline
A
I had this plain XL '08 and turned it into an XLT with the addition of stock 18" wheels, chrome bumpers, chrome grille, carpet, power windows and locks, RKE, etc. Can't remember if it already had cloth seats or not but it did when I was done with it.
[Linked Image]
[Linked Image]
Re: Possible new used truck-2008 F150 [Re: Wagonmaster261] #5124786 06/04/19 05:16 AM
F
ford46guy Offline
F
180,000 miles
New tires
Brakes
Spark plugs
New alternator
$4000
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Possible new used truck-2008 F150 [Re: Wagonmaster261] #5124873 06/04/19 07:10 AM
W
WyrTwister Offline
W
Look it up on NADA.com & KBB.com . Also , ask your banker .
Wyr
God bless
Re: Possible new used truck-2008 F150 [Re: Wagonmaster261] #5124941 06/04/19 08:48 AM
K
Kira Offline
K
Can you take the VIN to that dealer and ask if it was ever serviced there?
While you go about this, keep your eyes peeled to see what your '94 will fetch.
Rear spring shackles, rotted gas tank (friend's '97), trans and diff fluids,
Re: Possible new used truck-2008 F150 [Re: Wagonmaster261] #5124947 06/04/19 08:51 AM
J
jeepman3071 Offline
J
As for price, that is area dependent. Any 4x4 truck that runs and isn't a complete rot box sells for $3500 here in the Northeast. I'd check prices of similar trucks in your area. I'd rather have the 4.6 vs. the 5.4.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (52k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Possible new used truck-2008 F150 [Re: jeepman3071] #5125069 06/04/19 11:38 AM
J
JTK Offline
J
^ Truth.
I'm not sure if emissions and safety inspections are a thing where the OP is from, but this can be more of an issue on an 'aged' vehicle than some rust and wear. EVAP problems, catalyst inefficiency, etc.. Things that can cost more than the truck is worth.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Possible new used truck-2008 F150 [Re: Wagonmaster261] #5126960 06/06/19 11:21 AM
W
W
Where I am at (Wisconsin) there are no inspections. I live out of the emission test area, so most anything goes. wink
My 94 has a few issues:
Water in cab (maybe leaking windshield, feet can get wet in a heavy rain. Rubber floor allows it to run out, carpet would've rotted the floor by now)
Driver's door needs alignment
Tailgate doesn't have much left, outer skin rotted away
Fender wells in box are starting to get holes
Front tank leaks, I haven't used it in the 6 years I've owned it. Back tank is small, 18 gallon, so I don't get much range filling up at half tank.
Leaks oil pretty good, probably oil pan and gasket and side cover
Might have a cracked head (it did get overheated before I put a new radiator in)
Lifter tick (I hope, not something worse)
Fiber cam gear that to my knowledge hasn't been replaced.
Doesn't like to go freeway speeds (70 mph) To be fair, it wasn't designed to go that fast, national speed limit was 55 mph back then, and is comfortable at that speed.
I do have funds available to spend $3k without issue, wouldn't need to go to the credit union or anything.
[Linked Image]
[Linked Image]
[Linked Image]
