This is my first time filling in a rusted hole on the quarter panel of my truck. I used bondo glass, supported the material properly, removed all of the rust before applying the bondo, etc.
Today I sanded it down, and applied a temporary coat of primer.
The end product looks quite good, although in a few areas are pinholes; in one small area, there are a few pinholes arranged in a cluster.
At my house I have 3M fiberglass resin; could I use this to fill in the pinholes, or do y'all recommend that I buy, and use, bondo to finish off the job?
In the pinholes is the primer coat that I had sprayed. Will the resin or bondo properly adhere to the pinholes? Again...we're talking about pinhole sized holes - a few of them in total.
Thank you in advance for your time.
