so my son wants to replace all of the faux wood veneer in the Cougar with real burled walnut. ok. sounded simple at first. I have alot of woodworking experience but none with veneers. tried yellow glue to glue the veneer to plywood backer. looked good until he polyurethaned it with oil-based poly. the veneer lifted and bubbled. I'm guessing that the solvent attacked the glue. fine. tried again. contact cement and water-based poly. same thing, although not as bad. grrrrr!
ideas?
ideas?
