737 max... what now?
by Tdog02. 07/18/19 11:46 AM
Picked up a Hyundai oil filter from WM
by mclasser. 07/18/19 11:29 AM
Mobil1 20w50 Vtwin in a tuff torq K61
by gman2304. 07/18/19 10:47 AM
4t outboard W rating question
by 1978elcamino. 07/18/19 10:27 AM
Top three based on known specs.
by sloinker. 07/18/19 10:24 AM
Harbor freight 25% coupon
by Fitter30. 07/18/19 10:11 AM
Going to try longer OCI.
by mctmatt. 07/18/19 10:06 AM
diagnosing a/c problem
by matrass. 07/18/19 09:49 AM
Any friends of StevieC here ?
by Kjmack. 07/18/19 09:29 AM
Oil change interval on 70 Chevelle
by 007. 07/18/19 09:20 AM
New to me 2018 Grand Caravan 3.6 weight questions.
by racinjason. 07/18/19 07:38 AM
Help With 6L80E Fluid & Pan Replacement
by Sierra048. 07/18/19 06:39 AM
98 Expedition heating system flow diagram
by Fitz98. 07/18/19 12:39 AM
How did I become the constable?
by Chris142. 07/17/19 11:05 PM
Changed oil, Ravenol FullSynth Turbo VST 5W-40
by NotEnoughSpeed. 07/17/19 08:30 PM
Shaz, Grousebeater, RoyD, clonis, golddots
68699 Registered Users
91 registered members (4WD, aircooled, AlienBug, Alfred_B, 2012AccentSE, ad244, 7 invisible), 2,170 guests, and 32 spiders.
Topics292,025
Posts5,015,478
Members68,699
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: All wheel disk brakes wear even front to back? [Re: Duffyjr] #5124154
06/03/19 02:50 PM
06/03/19 02:50 PM
N.C.
gman2304 Online content
gman2304  Online Content
N.C.
For me typically 2 fronts to 1 rear, wife...not so much.
Re: All wheel disk brakes wear even front to back? [Re: Duffyjr] #5124163
06/03/19 02:54 PM
06/03/19 02:54 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
Yes, that sounds correct. the rears will wear "much faster" than drum brake shoes. I usually just replace fronts and rears at the same time now. also, here in the salt/rust belt, I just replace them every three years whether they need it or not. I have found that the rear disc pins/pads/slides seem to suffer from rust worse than the fronts and like to stick.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: All wheel disk brakes wear even front to back? [Re: Duffyjr] #5124186
06/03/19 03:09 PM
06/03/19 03:09 PM
CA
user52165 Offline
user52165  Offline
CA
Buy one of these and really see what it is:
https://www.amazon.com/gp/product/B0015DMJ2S/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
If you are lucky, you can check with wheels installed.
Re: All wheel disk brakes wear even front to back? [Re: Duffyjr] #5124227
06/03/19 03:43 PM
06/03/19 03:43 PM
Texas
2009Edge Offline
2009Edge  Offline
Texas
Some Mfgr's bias the brakes to have the rear engage before the front to minimize nose down dip.
Re: All wheel disk brakes wear even front to back? [Re: bdcardinal] #5124332
06/03/19 05:26 PM
06/03/19 05:26 PM
WA
Mad_Hatter Offline
Mad_Hatter  Offline
WA
Originally Posted by bdcardinal
I was always taught to never give a percentage, miles, or time left on brake components. You don't know for sure where and when they started or how the person drives. Just give measurements of the pads and rotors and their proximity to spec.
This 👆.. invest in a dial mic or vernier calipers and check them yourself. I'd consider replacing between 4 ~ 6mm myself because I don't want to gouge my rotors. How many months/miles that 2mm translates to just depends on your driving.
Re: All wheel disk brakes wear even front to back? [Re: Duffyjr] #5124534
06/03/19 08:22 PM
06/03/19 08:22 PM
Jupiter, Fl
CBR.worm Offline
CBR.worm  Offline
Jupiter, Fl
For me, two sets of rear pads will last about the same length of time as one set in the front. I think it is some amount of brake bias and some amount of traction control system design. I don't remember the percentage, but I understand that most of the vehicle stopping ability is provided by the front brakes. I suspect my rears may be undersized for the vehicle size or driving conditions.
'06 Infiniti G35 Sedan 6MT - 180k
Re: All wheel disk brakes wear even front to back? [Re: CBR.worm] #5124616
06/03/19 09:46 PM
06/03/19 09:46 PM
WA
Mad_Hatter Offline
Mad_Hatter  Offline
WA
Upwards of 75%. When you break all that momentum and vehicle weight shifts forward. Your selection of tires plays a big part in your ability to stop also. You can have the best brake pads money can buy but if you got bargain bin tires, your tires become the limiting factor in braking performance.
Page 2 of 2 1 2
