98 Expedition heating system flow diagram
by Fitz98. 07/18/19 12:39 AM
How did I become the constable?
by Chris142. 07/17/19 11:05 PM
Changed oil, Ravenol FullSynth Turbo VST 5W-40
by NotEnoughSpeed. 07/17/19 08:30 PM
Blending TCW3 in diesel
by 32319. 07/17/19 08:27 PM
Leaking Batteries
by ecotourist. 07/17/19 08:22 PM
Shake down tow complete!
by ls1mike. 07/17/19 08:22 PM
Looking for cheap int'l air tix
by daves66nova. 07/17/19 08:05 PM
Not *new* per se, but $3.98 for 5 quarts of M1
by mrdctaylor. 07/17/19 07:45 PM
Winter tires for 2019 Ram
by NissanHauler. 07/17/19 06:16 PM
Is the car hobby/enthusiast a dying breed?
by Redright9. 07/17/19 05:48 PM
Mobil One design change M1C-154A
by piesled. 07/17/19 05:26 PM
crazy granny gear spotted
by Number_35. 07/17/19 04:32 PM
Grease gun suggestions
by rideon. 07/17/19 04:16 PM
17 Imprezza 2.0
by JHogan. 07/17/19 03:42 PM
new boat, considering twin f 150 yamis
by 1978elcamino. 07/17/19 03:20 PM
Preventative repair - 2009 Ford Flex water pump
by KGMtech. 07/17/19 02:56 PM
patman3d, Oillogger, Rob707, rageyourdreams, Beemer25
68692 Registered Users
21 registered members (2015Corolla, Bailes1992, Char Baby, chrisri, alchargo, AnthemBassMan, 2 invisible), 622 guests, and 24 spiders.
Topics292,010
Posts5,015,202
Members68,692
Most Online2,967
Mar 10th, 2019
Replacing faux wood veneer with real... problems with the veneer lifting! #5124148
06/03/19 02:44 PM
06/03/19 02:44 PM
Chicago, IL
tomcat27 Offline OP
tomcat27  Offline OP
Chicago, IL
so my son wants to replace all of the faux wood veneer in the Cougar with real burled walnut. ok. sounded simple at first. I have alot of woodworking experience but none with veneers. tried yellow glue to glue the veneer to plywood backer. looked good until he polyurethaned it with oil-based poly. the veneer lifted and bubbled. I'm guessing that the solvent attacked the glue. fine. tried again. contact cement and water-based poly. same thing, although not as bad. grrrrr!
ideas?
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Replacing faux wood veneer with real... problems with the veneer lifting! [Re: tomcat27] #5124263
06/03/19 04:13 PM
06/03/19 04:13 PM
Massachusetts
AuthorEditor Offline
Massachusetts
I have no experience working with wood in a car, but on boats epoxy is your friend. I've used West System and System 3 and they are both good. West is generally easier to find at places like West Marine. Just be sure it is aligned right or you will never get it off! A very thin coat of epoxy is a great sealer before you varnish and will save many coats. Epoxy is pretty resistant to most chemicals, so the poly will do nothing to it.
