15 WRX RGT 5W-30 UOA 5400 mi OCI
Pennsylvania
Here is the last UOA from Blackstone used Shell RGT 5W-30 for a 5400 mile OCI. I did add 1/2 Qt during that time as usage was a bit more than with past Valvoline/ Mobil changes.
Sheared right down. Flash is still high; so doesn't seem to be fuel.
So much for a 'tough truck oil'!
I was looking forward for this uoa, very good results! Very low wear metals.
It did shear down to a 20 grade like every other GF5 I tried though, although it might not matter since the results are good.
Well out of Valvoline, Mobil, and RGT UOAs I have.The RGT had the lowest viscosity after the OCI.
Were they all in the 20 grade after the OCI?
Jbutch, Yes UOA samples left to right are RGT, Mobil 1 EP, Valvoline FS, and last Valvoline Maxlife. All in 5W-30
I'm generally not a Valvoline fan for Subarus, but in all honesty, the Valvoline FS looks the stoutest. However, you do realize you've been cross-contaminating all your samples don't you? Also, did you run some kind of octane booster on the Valvoline? Manganese is generally a compound of an octane booster.
Considering all these sheared, have you looked at PP Euro L? My VOA showed it starts off at nearly 12.4cSt@100*C. There isn't any moly, but other than that it compares well to the other oils you've used, albeit much further towards the thick end of 30wts.
[Linked Image]
Yes, I get that unless you are running back to back OCI of the same oil you get some cross contamination. I was looking to see what the oil viscosity was. Im surprised none stayed in grade but am new to the whole UOA thing.
Yes. That probably was octane booster. I tryed one bottle on a whim. Car did not like it.
PP Euro L is in the stash to try.
I daily and track my 2015 WRX. The shearing is why I run 0W40 or 5W40 oils, as they still shear down to a 30 weight in short order. Given the Texas heat and my 250 degree track temps, 40 weight oils are a no brainer for me.
In the 6 different UOAs I did, ALL of them sheared down to a 20 grade, granted they were all GF5 oils. They tend to really get trashed in our engine.
[Linked Image]
Hopefully the Rotella MV will hold better.
From an earlier thread someone did multiple UOAs with a non-GF5 SN rated oil (Mobil 1 ESP and Rotella MV) and they all stayed in the 30 grade.
I wonder what is in the GF5 oils that make them shear so much, VIIs?
And even if a GF5 starts a little thicker, like a few do, it's not going to be shear stable with the lower HTHS. That's why M1 ESP and RMV will usually stay in grade.
I hope and I think it will be the case.
QSUD (which is a good oil imo) starts at 11.60 cst @100c and ended up at 7.81 cst @100c after 4500 miles.
A lot of people on this board claims it is fuel dilution, but it would require a lot of fuel to bring it down that much (BS reports 0.8%) and I highly doubt it is the case.
Next sample of RMV goes to OAI to clear this up.
OAI may only provide a fuel estimate if viscosity looks ok. Just put a note that you're also requesting an actual fuel reading by GC.
Will do.
Is there an extra cost?
Will do.
No.
I sent one sample to OAI as a check against blackstone. They where similar with most readings. A few were drastically different. Cost was similar they included TBN but dont do a flash point. IIRC.
Fuel dilution was also higher but they use a different testing method.
They all thin out but your engine is doing great regardless. I would just pick one and stick with it or try 10w30s of what you've already run and see if they behave differently.
