belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
32 registered members (CATERHAM, DeafBrad, Ctopher, Danimal1q2w3, Bjornviken, Bailes1992), 1,211 guests, and 19 spiders.
Topics301,894
Posts5,204,869
Members70,798
Hyunda SP4-M Compatible ATF ? #5123676 06/03/19 05:09 AM
ChrisD46 Offline OP
My 2017 Sonata has a 6 speed transmission calling for SP4-M , unfortunately both Hyunda and Kia want over $20 per qrt. for it ... *I believe I can run Maxlife Multi Vehicle ATF (if upgraded to meet SP4-M) or I can use Redline D6 (not sure of the price) - any other SP4-M compatible ATF's you have used with good results in place of the OEM SP4-M ?
'17 Hyundai Sonata 2.4L GDI 5W20 QSUD / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: Hyunda SP4-M Compatible ATF ? [Re: ChrisD46] #5123680 06/03/19 05:19 AM
Diesel12 Offline
Ive had excellent results with this fluid thumbsup
Schaeffer All-Trans https://www.schaefferoil.com/documents/90-204SAT-td.pdf
1998 Dodge Neon-Rebuilt 2.4L-Schaeffer 10w-30
2014 Dodge Durango 3.6, 66K- Schaeffer 10w-30
2002 Ram 2500 Cummins 125K- Schaeffer 5w-40
2008 Dodge Avenger 232K Schaeffer 10w-30
Re: Hyunda SP4-M Compatible ATF ? [Re: ChrisD46] #5123687 06/03/19 05:31 AM
skyactiv Offline
From what I've read, Hyundai/Kia is not like the other auto makers when your engine or transmission goes kapluey under warranty.
They want absolute proof you properly maintained your vehicle according to the owners manual or your screwed. Spend time on Ripoff Report.com if you think otherwise.
I don't care much for Amsoil, but if I wasn't under warranty, I'd use it in this application.
https://www.amsoil.com/shop/by-prod...-synthetic-automatic-transmission-fluid/
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Hyunda SP4-M Compatible ATF ? [Re: Diesel12] #5123694 06/03/19 05:41 AM
J
JustN89 Offline
J
This is NOT the correct fluid for SP-IV M.
If you want to run Schaeffer's trans fluid, the correct fluid to run their Dexron VI/Mercon ATF #205A.
Re: Hyunda SP4-M Compatible ATF ? [Re: ChrisD46] #5123697 06/03/19 05:44 AM
J
JustN89 Offline
J
OP: I'm not sure how picky Hyundai's are when it comes to trans fluid. All the dealers around here use BG ATF, unless OEM is requested by the customer. Historically, Hyundai/Kia ATF hasn't been a very good product, although now it apparently is quite stout.
Re: Hyunda SP4-M Compatible ATF ? [Re: ChrisD46] #5123715 06/03/19 06:11 AM
J
Jimzz Offline
J
Maxlife and castrols Synthetic LV trans fluid work fin e in Hyundais.
https://sharena21.springcm.com/Publ...bd3/3fa3136a-09bd-e711-9c12-ac162d889bd1
yup
Re: Hyunda SP4-M Compatible ATF ? [Re: ChrisD46] #5123727 06/03/19 06:21 AM
doitmyself Offline
There's been lots of buzz about SP4-M lately due to the apparent price hike of the OEM products. In my area, 6 local dealers (Jeep,Kia, Hyundai) use what JustN89 stated (BG) even on vehicles still under warranty . This goes against what skyactive claims about dealers insisting by-the-book OEM fluids only.
To the OP, dig around a bit and you will find about a dozen products that list "compatible with" SP4-M. Even the Warren MAG 1 product claims SP4-M compatibility. What's odd is that the Asian and European brands (Eneos, etc,) have not changed their labeling from SP4 to SP4-M. Something I "imagined" that I read somewhere was that the U.S. version initially came out as a synthetic blend and the M version is now full synthetic, just like the Asian and European brands have always been. Just my thought that I wish someone would try to disprove.
Battles rage on Hyundai and Kia forums that their trannies are especially sensitive to fluid and the use of a universal product is hotly contested. LOTS of evidence shows up at BITOG to suggest people are getting very long life using non OEM fluids.
Re: Hyunda SP4-M Compatible ATF ? [Re: ChrisD46] #5123735 06/03/19 06:30 AM
W
WhizkidTN Offline
W
FWIW: In talking to the Kia tech who replaced my engine this past December (under warranty for the "Rod knock of death"), the transmissions are seen as very reliable and also pretty inexpensive (as far as transmissions go) to replace (~$1.5K). Thought that was very interesting if universally true (not just this dealership's service departments experience).
His: '12 Kia Optima SX - 2.0L GDI Twin-Scroll Turbo [Tuned] (87K)
>EDGE 0W-40, Fram XG9688
Her's: '14 Nissan Rogue SL AWD - 2.5L NA (100K)
>EDGE 0W-20, Fram XG6607/XG7317
Re: Hyunda SP4-M Compatible ATF ? [Re: ChrisD46] #5123831 06/03/19 08:12 AM
ChrisD46 Offline OP
*I believe that even if my 2017 Sonata is under warrantee - as long as the Maxlife all vehicle ATF states suitable for SP4-M on the container - then you should be covered with Hyundai ... Otherwise you threaten them with the " Magnuson–Moss Warranty Act" which essentially states that if Hyundai only states their SP4-M ATF be used , then Hyundai has to supply it for FREE !!
Re: Hyunda SP4-M Compatible ATF ? [Re: ChrisD46] #5123846 06/03/19 08:31 AM
csandste Offline
I'm out of power train warranty with a used car purchase but when I change it will be Max Life.
2017 Kia Soul Plus-- Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Hyunda SP4-M Compatible ATF ? [Re: ChrisD46] #5123892 06/03/19 09:32 AM
slacktide_bitog Offline
Maxlife will work fine smile
Another good choice is Castrol Full Synthetic ATF, when it goes on sale for $5/qt
Re: Hyunda SP4-M Compatible ATF ? [Re: JustN89] #5123902 06/03/19 09:44 AM
Diesel12 Offline
Im sorry i seen the spec right on the list? But to your answer it does show the smae spec for the LV Trans fluid.
Hyundai/Kia/Mitsubishi SP II, SP
III, SP IV, J2, SPH-IV, SP-IV-RR,
NWS-968, Kia Red-1
Re: Hyunda SP4-M Compatible ATF ? [Re: Diesel12] #5123920 06/03/19 10:05 AM
J
JustN89 Offline
J
NWS-968, Kia Red-1
The #204SAT is not the low-viscosity fluid that Hyundai calls for- that would be the #205A. Schaeffer's has it mislabeled. I sent their customer service an e-mail and asked which one to run and they confirmed that it would be #205A. Attached is the e-mail below. I doubt it matters, but I blocked her last name out just for privacy reasons.
Re: Hyunda SP4-M Compatible ATF ? [Re: doitmyself] #5123933 06/03/19 10:16 AM
blupupher Offline
Yeah. Back with the SP-III fluids, those transmissions were very picky on fluid, and were basically OEM fluid only.
When they went to SP-IV and now SP-IV-M, that fluid is basically Dex VI/Toyota WS spec.
Maxlife ATF is my fluid of choice for my fleet for the foreseeable future (Merc V, Toyota WS, SP-IV, Dex VI).
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/PG
'10 Santa Fe: Synpower 5w-30/D+
'04 F150: Magnatec 10w-30/ST
'12 xB: M1EP 0W-20/CQ Blue
'02 F150: Magnatec 5W-20/D+
'94 VT1100: Peak 15W-40/D+
Re: Hyunda SP4-M Compatible ATF ? [Re: ChrisD46] #5124841 06/04/19 06:38 AM
ChrisD46 Offline OP
If OEM Hyundai SP4-M is now the full synthetic version then it stands to reason that Maxlife All Vehicle ATF (full synthetic) or the Castrol All Vehicle ATF (also full synthetic) claiming SP4-M compatibility would also be just as good ? Currently , the OEM Hyundai SP4-M ATF is over $20 per quart (ouch) . *When Maxlife ATF is $18 per gallon and Hyundai OEM is $80 per gallon - that is a significant cost difference to consider !
