Is my transmission fluid overfilled? Scion xB '10
by puredata - 08/22/19 02:38 AM
Which are you?πŸ˜‚
by Mad_Hatter - 08/22/19 12:21 AM
The Fatal Flaw...
by Mad_Hatter - 08/21/19 10:58 PM
early OCI because of HIGH REVVING
by tahoe_hybrid - 08/21/19 10:38 PM
API diesel / gas ratings
by KiwiBiker - 08/21/19 10:18 PM
For the XOM fans!
by Marco620 - 08/21/19 09:43 PM
I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
oilq, Nesss, Robto, Chaparro_trucker, KiwiBiker
69027 Registered Users
23 registered members (bonjo, 4WD, 2015Corolla, ChrisD46, Bailes1992, DR3406C, 3 invisible), 565 guests, and 26 spiders.
Topics293,636
Posts5,043,857
Members69,027
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: Has anyone used this high dollar/little known stop leak? [Re: demarpaint] #5124359 06/03/19 05:48 PM
M
Mad_Hatter Offline
M
Originally Posted by demarpaint
Their warranty has me scratching my head. From what I gather it is not a money back warranty, if the leak doesn't stop they'll send you another bottle to try again. I guess it might be worth a shot, but I would be more willing to try it had they offered a money back guarantee. If I read it wrong and they'll refund the money my apologies.
I'd be interested in the results.
That sounds like the guarantee for the "5 minute Abs"..if you don't get that 6pk the first time, they send you out another 5mins for free!πŸ˜‚
Here's hoping it helps but realize it's a band aid. Eventually you're going to have to do those valve covers. That was my experience with stop leaks and a leaky valve cover. It stopped for a while then started to leak again and where the leak was, the oil was getting onto/into my alternator. That's when I decided to do it right and pull the valve covers. And yeah, it's easily a 4hr job because just about everything has to come off it seemed. Grrr...
Re: Has anyone used this high dollar/little known stop leak? [Re: Ernie45] #5124708 06/04/19 12:10 AM
B
Black_Thunder Offline
B
Originally Posted by Ernie45
I also replaced something that is an idle solenoid that caused something called Ranger moan. The one spark plug was fouling from coolant leaking into plug from intake manifold.
Bars leak liquid copper stopped it. I also did all the ball joints and tie rod ends because of torn boots. The upper moog ones now have marine rtv on then. I also hate the vacuum shift 4wd but don’t need it in Fl. I just got a new to me oem rim and
Now have a real spare from best old tire. Real fun is putting those camber adjustment things in the upper suspension A frames. Owning this thing is love/hate thank you for comments and interest.
Was it the IAC valve aka Idle air control valve?
Sone contours and mystiques and probably cougars with the 2.5 had an issue causing a noise like moaning and was called moosing.
I'd buy Callahan autoparts if I could.
Re: Has anyone used this high dollar/little known stop leak? [Re: Mad_Hatter] #5124752 06/04/19 05:04 AM
demarpaint Offline
That pretty much sums it up. thumbsup After a little more thought I'd pass, and look for a product that offers a real money back guarantee, or even better bite the bullet and make the necessary repairs.
God Bless Our Troops
Re: Has anyone used this high dollar/little known stop leak? [Re: Ernie45] #5127842 06/07/19 12:15 PM
W
WAYNERIDES Offline
W
try MOTORKOTEs stop leak. 8oz and a 32oz js
Re: Has anyone used this high dollar/little known stop leak? [Re: Ernie45] #5128075 06/07/19 05:30 PM
MolaKule Offline
Global Moderator
Global Moderator
I just put it in my 98 Ford Ranger 4.0 engine 106 K miles with leaky valve covers... l
Leaky valve covers use gaskets, not elastomeric seals.
Originally Posted by Molakule
When discussing seals such as in engines, transmissions, and other driveline components, the context is that of using flexible, elastomeric materials to keep fluids contained within the mechanical system that have rotating components exiting the system, such as protruding rotating shafts.
For a gasket, the context is that of using a material (such as silicone or cork or composite), or some other material to keep fluids contained in and around stationary objects, such as the valve cover gasket on an engine or the pan gasket on an automatic transmission.
Both seals and gaskets "prevent" loss of fluids...
Conditioning seals refers to the following actions:
1) Increasing seal pliability due to Seal elastomer molecular replacement
2) Seal cleaning,
Today's synthetic formulations have pretty much solved the seal "shrink-swell" problem.
Stop leak fluids have little effect on Gaskets, so if you have a leak to the outside, it is usually due to a Gasket, not a Seal.
Now on older vehicles or vehicles with rear wheel drives, the most common fluid leak occurs because of a worn tailshaft seal, and is mostly seen when parking on an upslope where the rear of the vehicle is below the front.
On front wheel drive vehicles, the most common fluid leak is due to the pan gasket, in my experience.
The value of a scientific theory is its ability to prompt further study, not that it has any relation to the established facts of scientific reality.
Re: Has anyone used this high dollar/little known stop leak? [Re: Ernie45] #5172056 07/27/19 11:02 AM
newtoncd8 Offline
Any update on this product?
12 Jeep GC, 04 Lexus RX330, 77 MG-B
Re: Has anyone used this high dollar/little known stop leak? [Re: Ernie45] #5178938 08/04/19 04:25 PM
DocMARTEN74 Offline
I would like to know more about this Titan oil stop leak.
Page 2 of 2 1 2
