Pay Raise
by KeithS_NW_Ohio - 12/11/19 09:17 PM
Mid-size SUVs for exploring/DD
by AZjeff - 12/11/19 09:05 PM
3.5 Ecoboost issues solved for 2018?
by JLTD - 12/11/19 08:30 PM
14 Grand Caravan Broken Exhaust Valve
by cptbarkey - 12/11/19 07:48 PM
Put the winter tires on the Impala today.
by JimPghPA - 12/11/19 07:31 PM
Chasing down a brake issue
by HawkeyeScott - 12/11/19 07:14 PM
Total Quartz 9000 Energy 5w40
by BurntMusic - 12/11/19 06:53 PM
Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
Sooty Oil in Ford Focus
by RW1 - 12/11/19 02:27 PM
oil sample shelf life?
by novadude - 12/11/19 12:51 PM
oilylp, Motorapido, TyMillerfc, AcadiaDave, lmt1911
70106 Registered Users
121 registered members (77GrandPrix, 14Accent, 4WD, AndyB, 2015_PSD, 69Torino, 9 invisible), 1,761 guests, and 26 spiders.
Topics298,600
Posts5,138,935
Members70,106
Most Online3,589
Nov 2nd, 2019
Vortec 5.3 Question #5122269 06/01/19 12:04 PM
Speak2Mountain Offline OP
Have there been any problems w/the 5.3 and carbon build up on the pistons/rings in the last 10 model years?
Re: Vortec 5.3 Question [Re: Speak2Mountain] #5122342 06/01/19 01:26 PM
A
addyguy Offline
A
AFM problems seem to cause accelerated cylinder wear and increased oil consumption.
2010 Kia Soul 2U - 2.0L I-4, auto; 149k miles.
Castrol Edge (black bottle) 5W-30; Fram TG 9688.
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles.
Oil/filter TBD
Re: Vortec 5.3 Question [Re: Speak2Mountain] #5122346 06/01/19 01:30 PM
4WD Online Confused
Online Confused
Think the DI started on the L83 (2014?) but it’s also said AFM was improved by this generation …
Re: Vortec 5.3 Question [Re: Speak2Mountain] #5122367 06/01/19 01:50 PM
R
Railrust Offline
R
I think you'll find some newer generation owners running oil catch cans to prevent some of the concerns with carbon buildup, but as far as it actually being a huge problem...I'd say not really. Not to the extent of earlier direct inject BMW and Audi engines, etc.
I've seen photos of these engines with over 100,000 miles and the valves don't look that bad...not perfect, but not terrible either.
I own one, I use a catch can, it does catch a lot of oil...is it actually helping? Probably. I'd like to remove my intake and take a look...some day I probably will.
Re: Vortec 5.3 Question [Re: Speak2Mountain] #5122398 06/01/19 02:27 PM
N
NYEngineer Offline
N
Of five people I know, including myself, only mine and my dad's haven't been to the dealer. My brother got an entire engine, my friend got all new rods and pistons and another guy sold his when it became troublesome.
My dad and I have catch cans and the AFM locked out. My truck has 170,000 miles on it. Not sure how many pop's has. NOW my brother has a catch can and an AFM blocker. My buddy who got the new pistons doesn't listen and just drives his as is.
Re: Vortec 5.3 Question [Re: Speak2Mountain] #5122458 06/01/19 04:29 PM
Spitter Offline
Probably not a direct answer to the question but 07+ models with dod cylinder deactivation tend to have more wear and usually end with a lifter exploding under 200k miles but can be avoided with devices that lock out the dod such as custom tuning. Amazon sells a box that plugs in to shut this off which doesnt void warranties. Also the 2014+ with direct injection would benefit from a catch can. 30wt oil can be used if dod is shut off.
2004 Silverado 5.3
Pennzoil ultra platinum 10w30 acdelco upf44
2006 Buick lucerne 3.8
Pennzoil ultra platinum 5w30 acdelco pf47
Re: Vortec 5.3 Question [Re: NYEngineer] #5122468 06/01/19 04:41 PM
R
Railrust Offline
R
I really think it’s hit or miss, I know several people with the AFM or DOD and when ask them if they’ve had any issues with it the first thing they say is...what are you talking about? Are you talking about that V8/V4 thingy? No I don’t even notice it, I guess it switches into 4 cylinders or something.
I’m amazed because all I hear about is bad things, yet I’ve only seen one fail...and the guy beat the snot out of it and never changed the oil. Personally I’m hoping I can go 200,000 miles before I have any problems.
I figure...I change my oil every 5,000, I don’t beat on it, I don’t use it as a work truck...we’ll see
Re: Vortec 5.3 Question [Re: Speak2Mountain] #5122497 06/01/19 05:14 PM
Snagglefoot Offline
Certainly you can’t compare a 13 and earlier engine with a 14 and later version. They had much different oiling systems and pressures.
If you want the job done right......do it yourself.
Re: Vortec 5.3 Question [Re: Speak2Mountain] #5122593 06/01/19 06:59 PM
AZjeff Online Content
Online Content
Now for 2019 we have GM's Dynamic Skip Fire that will deactivate cylinders in 17 different patterns, whatever that means.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Vortec 5.3 Question [Re: Railrust] #5122745 06/02/19 12:56 AM
E
edyvw Offline
E
CBU issues on those manufacturers are present in forced induction engines. Naturally aspirated are OK. VW/Audi had issue in NA engine in first DI models with excessive duel dilution and some CBU.
As long as engines are NA, it seems that CBU is not as big problems as on forced induction engines.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
Re: Vortec 5.3 Question [Re: addyguy] #5123415 06/02/19 07:52 PM
clinebarger Online Content
Online Content
My Cylinder Bore Gauge disagrees with you; I've checked several AFM equipped LSx engines & haven't found any bore distortion or taper........Stuck rings cause the oil burning.
2001 Chevy Camaro L92/4L80E
Re: Vortec 5.3 Question [Re: Speak2Mountain] #5123482 06/02/19 08:43 PM
L
LeakySeals Offline
L
Are you trying to figure out why the 5.3 w/AFM consumes a fair amount of oil? There are a few reasons why it's common.
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: Vortec 5.3 Question [Re: LeakySeals] #5123484 06/02/19 08:45 PM
4WD Online Confused
Online Confused
I have two … no oil consumption
Re: Vortec 5.3 Question [Re: Speak2Mountain] #5123539 06/02/19 09:44 PM
P
P10crew Online Content
Online Content
P
I’m gonna chide with CLinebarger. Big time.
I have checked and taken in to the best machine shop any where near here 5 ls blocks of all bores except a 5.7.
56,000 to 140,000 Miles. Every single one of them so far has undetectable taper, out of round and top of bore. The ls platform is somewhat new to these dudes and they are impressed. I asked the lead man why these bores dont hardly wear and all he could say was fuel injection #1... it’s not living it’s life with fuel washed cylinder walls and the liners are..... I can’t remember what alloy he said which is supposedly super wear resistant material. Is it nicasil?
Any ways these liners are not at all like gen 1-2 stuff.
