Originally Posted by demarpaint
Originally Posted by burla
Originally Posted by WillB
Is it ok to run a 5w30 with mds?
About 45% of members in a hemi forum run 5w30 and thicker, only one guy said he got a CEL but it wasn't credible, never any follow up despite being asked many times, honestly it could have been a typo on the poll. 100's of guys running 5w30 w/o issue in polls oer there. A larger consideration is why have this many people decided to ditch the manu on this, and the answer to that is the large number of forum members who have cam failures to due heavy wear. Whether or not using a thicker oil will help that or not is another matter. But fca did raise viscosity on 1500's to correct bearing wear issues in another application, so they believe thicker oil will protect against that situation, but they literally can't recomend that for the 5.7 because the gov't is all over them with CAFE. Yes, it is safe.
I agree. While having my airbag recall done I spoke with a friend who is a Jeep A-tech and we discussed the cam failure issue. It seems cam issues are not limited to the hemi. Chrysler outsources their cams, they are not made in house. There are people in engineering who feel the issue has to do with the zinc reduction in the oil. He and other people I discussed this with and respect seem to agree. He suggests bumping up a grade to a 30 and using a high ZDDP oil, or Heaven forbid a ZDDP additive.
I think it certainly won't hurt, and I would give it a shot. 1,200-1,500 ppm ZDDP seems to be the sweet spot according to what I've been told. Opinions vary. Flame suit on.
Roller engines do not have high ZDDP requirements, as the roller rolls; it's not a sliding interface. The requirement for higher levels of phosphorous stem from the higher pressure
sliding interface on a flat tappet setup where you have the lifter spinning and sliding directly on the lobe, with this sacrificial layer being the only thing keeping those two components from eating each other. Elevated levels are deemed beneficial when those pressures are increased due to wilder camshaft profiles and higher spring pressures for high RPM operation. If a roller starts sliding, you've already got failure, as it's a setup that isn't designed/engineered to function in that manner and a sliding (seized) roller presents a ridiculously narrow interface to a lobe that isn't designed for sliding contact and failure of both units will be the result.
You could run all the ZDDP in the world, but if that roller stops rolling, it's still going to eat the lobe, as neither of those surfaces are designed to operate as sliding interfaces. The metallurgy is wrong, the geometry is wrong and the mode of operation is wrong. A flat tappet interface is broad and rotates, whilst a roller is extremely narrow in comparison and is intentionally designed NOT to change its alignment with the lobe.
