NSFBitog
by Ursatdx - 02/18/20 03:25 PM
Wider rear tires?
by drop - 02/18/20 03:07 PM
ROCKAUTO Coupon Codes
by jrvn - 02/18/20 02:24 PM
Gold (brass?) flecks in drained Honda ATF
by TNM6i - 02/18/20 12:10 PM
What happened to licensed ATF clones?
by TimN3QE - 02/18/20 12:08 PM
E85 in non-flex fuel Ford Expy ~2013
by DriveHard - 02/18/20 11:46 AM
Jacking up a car by itself
by Alfred_B - 02/18/20 11:44 AM
Valvoline MST in 2015 Macan S
by musclecarscott - 02/18/20 11:43 AM
PH10060 oversized?
by bullwinkle - 02/18/20 11:36 AM
Toyota Sienna
by cb_13 - 02/18/20 10:05 AM
Larger fuel filter on Riding mower?
by dedonderosa - 02/18/20 10:03 AM
Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
spbonus, mtnwzrd11, TnTA2, TimN3QE, musclecarscott
70742 Registered Users
98 registered members (762fermeandyou, atikovi, 53' Stude, ArrestMeRedZ, andreigbs, 8 invisible), 2,290 guests, and 19 spiders.
Topics301,615
Posts5,199,172
Members70,742
Amsoil ASL 5W30, 7.5K, 12 Jeep Wrangler #5122034 06/01/19 07:59 AM
dhellman12 Offline OP
First full run with Amsoil Signature series oil. This oil was changed when the Jeep oil light came on at 7,500 miles.
Make/Model: Jeep Pentastar 3.6L v6
Vehicle: 2012 Jeep Wrangler Unlimited Rubicon
Code
OIL             Ams ASL 5w30	Toy 5w30
MILES IN USE    7,543		4,283
MILES ON UNIT   72,826		65,283
SAMPLE TAKEN    5/11/19		9/12/18
MAKE UP OIL	0		0
ALUMINUM	3		3
CHROMIUM	1		1
IRON		10		8
COPPER		9		10
LEAD		0		0
TIN		0		1
MOLYBDENUM	178		51
NICKEL		0		0
MANGANESE	0		0
SILVER		0		0
TITANIUM	0		1
POTASSIUM	3		1
BORON		49		13
SILICON		16		16
SODIUM		11		9
CALCIUM		1252		1900
MAGNESIUM	761		221
PHOSPHORUS	650		683
ZINC		725		793
BARIUM		0		0
SUS @ 210F	60.4		53.5
Visc @ 100C	10.34		8.33
Flashpoint	395		415
Fuel %		<0.5		<0.5
Antifreeze %	0.0		0.0
Water %		0.0		0.0
Insolubles %	0.3		0.2
TBN		3.5
Blackstone comments:
These are some nice results! Even though you ran this oil a good deal longer than the last, there's hardly any more wear to show for it. The 3.6L Pentastar powering your Jeep looks like it had no problem with the additional miles, and the oil itself held up well, too. Its viscosity is still in grade, no contamination was found, and the TBN is a strong 3.5 (1.0 is too low). The air and oil filters did a good job, too, based on the normal levels of silicon and insolubles. This all adds up to an ideal report, so feel free to run the next oil even longer. Check back after ~9,500 miles.
00 WS6 5.7L - Amsoil ASL 5w30 256K
04 DMax 6.6L - Amsoil AME 15w40 238K
12 Jeep 3.8L - Amsoil ASL 5w30 74K
Re: Amsoil ASL 5W30, 7.5K, 12 Jeep Wrangler [Re: dhellman12] #5122055 06/01/19 08:18 AM
O
oil_film_movies Offline
O
Blackstone comments are good. (They aren't always!)
Healthy engine with a great oil. No bad numbers. Could have gone another 3,000 miles with that high TBN at the end.
Originally Posted by dhellman12
Amsoil ...This oil was changed when the Jeep oil light came on at 7,500 miles.
Using higher-spec oils than what the engine computer software algorithm (OLM) assumes you're using, especially in a low-soot port fuel injected engine, means you could possibly go about 1.5x the dashboard light time and miles. I'd use a Fram Ultra XG10955 to match the performance of Amsoil SS, M1 EP, M1 AP, Castrol Edge EP, Ravenol DXG, or Rotella T6 Multi-Vehicle in there.
My 1.5T DI gasoline 'soot-maker' (GM 2018) defeats just about any oil at 7,500 miles according to GM.
Re: Amsoil ASL 5W30, 7.5K, 12 Jeep Wrangler [Re: dhellman12] #5122158 06/01/19 09:49 AM
T
Triple_Se7en Offline
T
Nice results from a real nice oil. I would keep running it for 7.5K. What oil filter was on that run?
Being Trolled? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai Santa Fe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 Mobil1 Filters
Re: Amsoil ASL 5W30, 7.5K, 12 Jeep Wrangler [Re: dhellman12] #5122203 06/01/19 10:41 AM
J
JLTD Offline
J
10k would be a walk in the park for this oil. What filter are you using?
Lates.
Re: Amsoil ASL 5W30, 7.5K, 12 Jeep Wrangler [Re: dhellman12] #5128934 06/08/19 09:36 PM
On that run I was using a Wix filter. On this run I switched over to the Amsoil EA as I'd assumed the report would show it would be safe to extend the OCI out even further.
Re: Amsoil ASL 5W30, 7.5K, 12 Jeep Wrangler [Re: dhellman12] #5132015 06/12/19 05:29 AM
J
JLTD Offline
J
thumbsup Thanks - areyou planning 9500 ... or further?
Lates.
