Either will work. I run M1 HM 10w-30
Wonder why my son's 2016 Escape with the 2.0 Eco-boost owner's manual says to use 5W30? Why would the 1.5 call for 5W20?
Giving this thread another life. A friend of mine has a 12 Fusion with a 1.6t ecoboost engine, only 5w20 used by the dealer. The engine is dead at 80k miles, some failure of the 2nd cylinder
The Motorcraft 5w20's in syn and syn-blend are SN+. So is an LSPI event just bad design, or maybe the Motorcraft oil just not good enough?The 1.6EB is apparently one of the more likely to experience an LSPI event along with the 1.0 3 cylinder. Most I've seen broke the piston between the #1 and #2 rings.
Most of the online reports for 1.6EB issue suggest a coolant issue which caused some type of overheat condition, prompting a recall for some of them?
Doesn't it show high wear metals and no glycol in the oil, as said in your linked thread?Funny this thread was revived, the car I was asking about initially just got a short block under warranty. Burning coolant, not oil related. I sent out a sample of the RGT 5W-20 that was in it when I noticed the coolant loss, and the wear metals looked good. New engine will be on the same diet as the original.
See UOA HERE
Escape’s are known for multiple issues, I owned an 08 Ford Escape XLS and ended up having every issue in the world wrong with it. I’ve talked to others who have had similar issues. I’d recommend trading it in for something else if possible.Giving this thread another life. A friend of mine has a 12 Fusion with a 1.6t ecoboost engine, only 5w20 used by the dealer. The engine is dead at 80k miles, some failure of the 2nd cylinder
Well, I should have said wear metals looked "relatively good to me" when considering it was still a fairly new engine. It's consistent with what I'd expect to see from an engine with 9k miles of short trip and in town driving.Doesn't it show high wear metals and no glycol in the oil, as said in your linked thread?
Hard to say if that was sarcasm or not, also hard to say if the failure was oil-related. From what he's told me, a mechanic at that dealer said they've got a lot of ecoboost engines failed. Some even didn't make it to 50k. I'm not qualified to judge the engine design really, sticking to my Kia which also know for engine-related problems, but has a 10 years powertrain warranty so I can sleep wellClearly if this friend had used 5w50, that wouldn't have happened.
Per Ford specs 5w 20 for timing ( belt ) driven blocks . 5w 30 for timing (chain ) driven block , upgrade due to timing chain issues .Because they did actual testing and the 2.0EB needed a higher HTHS?
My daughters '17 1.5L Escape has been run with mostly Pennzoil Ultra 5W-20. 47,000 miles and going strong. No coolaint problems so far. OCI's at 5,000 miles with Motorcraft, Mann and Mahle oil filter. Vehicle came with a tight/close fitting thick rubber engine cover. I always thought it was holding in too much heat so I removed it within a few months. Maybe removing it helps reduce heat. Engine noise might be a tad higher but nothing really. BTW this vehicle other than the oem Michelin Latutude Tour HP wearing evenly but gone by before 40,000 miles has been 100% flawless. Oopss forgot a sqeaky inside door handle.....
Didn't notice a difference on the temp gauge but I have to believe the airflow over the valve cover is greatly increased without the cover. As you know from your own vehicle it is quite a cover. MIght help for emissions getting engine to operating temp..and maybe a bit engine/injector noise. I will keep it off just in case it helps even a little bit with temp. Makes me feel better in either case LOLI've been tempted to remove the engine cover on our Ecoboost Escape. After it was removed did you see a temp change ?
