I just received this tractor out of my parents estate. It is right at 10 years old and has been in the barn the whole time, unless it was working on the road with a Box Blade or mowing with a Brush Hog. It is in pristine condition. It also has a front end loader.
Now the bad..... It is ten years old and nothing (ZERO) maintenance has ever been done to the tractor. It only has 152 hours on it, but the manual called for a full round of filters and fluid at the 50 hour mark, every 200 hours after that.
So.... it's time to give it a little TLC.
From the best I can tell, there are four filters that need replacing: engine oil filter, hydrostatic drive filter, hydraulic filter and the fuel/water separator filter. Also from the best I can tell, the fluids to drain and replace are: engine oil, transmission fluid, front differential fluid.
I don't see any refer to a reservoir for standard hydraulic fluid. Does this tractor use the transmission fluid for the hydraulic components, like the front end loader?
The engine is a Mitsubishi 1.3L, 3 cylinder. I am guessing I will put about 50 hours on the tractor a year, mostly between mowing and snow removal. Maybe I am wrong, but it just seems silly to dump good HDEO annually. If I pour in some high quality synthetic for extended drain intervals, can my OCI's be two, three..... maybe even four years?
For the oil, is there any reason why I shouldn't pour in T6 5w40?
Also, I know nothing of hydrostatic drive fluids. Whatever I purchase will probably be picked up at my local Big R or Tractor Supply. What is general recommendation here?
