17 Imprezza 2.0
by JHogan. 07/17/19 03:42 PM
new boat, considering twin f 150 yamis
by 1978elcamino. 07/17/19 03:20 PM
Preventative repair - 2009 Ford Flex water pump
by KGMtech. 07/17/19 02:56 PM
Bought out phone lease for a song
by 14Accent. 07/17/19 02:54 PM
Do you have a fave RTV sealant you use?
by ZZman. 07/17/19 01:36 PM
Scanner
by tiger862. 07/17/19 12:36 PM
Hyundai ELantra ATF follow up
by flinter. 07/17/19 10:14 AM
Poor Bill
by 4WD. 07/17/19 10:05 AM
Cadillac parked for 25 years...
by mattwithcats. 07/17/19 09:52 AM
Sumitomo Encounter Tires
by parshisa. 07/17/19 09:40 AM
API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
prof_redbeard, drnc, blackseven, EdK, guru2019
68686 Registered Users
114 registered members (2tite, 69GTX, 53' Stude, 1ofeverything, 4WD, 12 invisible), 2,286 guests, and 24 spiders.
Topics291,994
Posts5,014,819
Members68,686
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Hole in engine :( #5120605
05/30/19 07:37 PM
05/30/19 07:37 PM
NC
Matagonka Offline OP
NC
Well, crap! My 2004 Craftsman LT1000 took its last breath today. frown
Pi ssed at myself more than the tractor.
2018 Mazda 3 Touring HB 2.5
Re: Hole in engine :( [Re: Matagonka] #5120607
05/30/19 07:39 PM
05/30/19 07:39 PM
Killeen, TX
GumbyJarvis Offline
GumbyJarvis  Offline
Killeen, TX
Maxlife. It has seal swellers.
2018 RAM 1500 SLT 5.7L HEMI 19K
Schaeffers 5w20 - Mahle OC 614
Disabled US Army Vet
OEF 2013-2014
Re: Hole in engine :( [Re: GumbyJarvis] #5120614
05/30/19 07:43 PM
05/30/19 07:43 PM
NC
NC
Ahem, check the hole in the block.
Re: Hole in engine :( [Re: Matagonka] #5120619
05/30/19 07:47 PM
05/30/19 07:47 PM
In the Garage...
ls1mike Offline
ls1mike  Offline
In the Garage...
Does it run still?
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Hole in engine :( [Re: Matagonka] #5120625
05/30/19 07:51 PM
05/30/19 07:51 PM
Killeen, TX
GumbyJarvis Offline
GumbyJarvis  Offline
Killeen, TX
I saw. I think you need a Fram Ultra too. That's the only filter ever made..
I was being sarcastic lol
OEF 2013-2014
Re: Hole in engine :( [Re: Matagonka] #5120630
05/30/19 07:54 PM
05/30/19 07:54 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
so why are you mad? run it out of oil? no air filter? broken governor?
if it just randomly blew up.. thank it for its service by craiglisting its carcass.. doubt its worth repowering.
Re: Hole in engine :( [Re: Matagonka] #5120637
05/30/19 07:57 PM
05/30/19 07:57 PM
NC
NC
I reused the oil filter after an oil change. The problem is that it was so tight, that when I loosened it dented the filter housing. Didn't think it was a big deal. Well, it started leaking while mowing and it blew.
Stupid decision on my part. I should've known better.
Re: Hole in engine :( [Re: ls1mike] #5120638
05/30/19 07:58 PM
05/30/19 07:58 PM
NC
NC
Originally Posted by ls1mike
Does it run still?
Only downhill in neutral.
Re: Hole in engine :( [Re: Rand] #5120648
05/30/19 08:07 PM
05/30/19 08:07 PM
Killeen, TX
GumbyJarvis Offline
GumbyJarvis  Offline
Killeen, TX
Or find a similar model on CL with the same engine that is still in good shape and swap it to this one, theres plenty of mowers out there for sale that the engine still runs but the deck etc is rusted out.
If you are getting rid of it, is there a high school around that has a small engines shop class? Agriculture class? Can always donate it!
OEF 2013-2014
Re: Hole in engine :( [Re: GumbyJarvis] #5120682
05/30/19 08:42 PM
05/30/19 08:42 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
And some ST HM 10w30...
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Hole in engine :( [Re: Matagonka] #5120683
05/30/19 08:43 PM
05/30/19 08:43 PM
New Hampshire USA
Dinoburner Offline
Dinoburner  Offline
New Hampshire USA
HF has cheap engines if the machine is worth the expense.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Hole in engine :( [Re: Matagonka] #5120720
05/30/19 09:32 PM
05/30/19 09:32 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
HF engine to the rescue?
2015 Ford F250 w/Powerstroke
Re: Hole in engine :( [Re: Dinoburner] #5120766
05/30/19 10:35 PM
05/30/19 10:35 PM
Kansas
Kruse Offline
Kruse  Offline
Kansas
A couple of years ago, I got a 22 HP HF Predator engine for a Kohler Courage engine that created a hole in the block on my zero turn. (The Kohler Courage engine is notorious for that. Google it)
Anyway, I managed to find a coupon to get it for $549 and purchased it. Except if you do the paperwork on it, it's not the bargain that it appears to be.
HF stopped printing the coupons for that engine, as far as I know. It is now at a normal $730 that gets the price up to the "American-branded" engines.
First, the HF engine has only a 90 day warranty, where most B&S engines have at least a year. If you add the extended warranty to the HF engine, the price can be a big turnoff, especially if you listen to the horror stories of getting replacement parts for the HF engine. I no longer consider a Harbor Freight engine cheap, nor a bargain.
Re: Hole in engine :( [Re: Kruse] #5120908
05/31/19 05:57 AM
05/31/19 05:57 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
B&S still has USA built engines? When I repowered my log splitter & replaced the ancient flathead Briggs that was on it, the local B&S shop wanted DOUBLE the price of the 13 HP Predator I ended up putting on it-and the B&S engine was "Made in China" too!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Hole in engine :( [Re: Matagonka] #5120926
05/31/19 06:19 AM
05/31/19 06:19 AM
New England
madRiver Offline
madRiver  Offline
New England
Life's best lessons are the most expensive ones.
Page 1 of 3 1 2 3
