98 Expedition 5.4 4x4
I have these fuel injectors FOTE-D5B
I thought I should replace the O Ring seals while the fuel rail is out from an intake remove and replace.
The dealer only sells packages of black seals. These injectors have blue and black seals.
I don't know if there is any difference, but would like to replace the seals with a known compatible seal for these injectors. Any ideas where I can get them, if the black dealer seals are in fact the same, or if it is even worth replacing. I have had no issues and visually they appear fine. Only thinking to change them because they are out now and easy to change.
