HUBB reusable stainless steel filter?
by Vern_in_IL - 02/18/20 08:41 PM
Ultrasonic carb cleaning problems
by atikovi - 02/18/20 08:05 PM
Cheeseburger pie
by P10crew - 02/18/20 07:25 PM
The midwinter detail.
by dan_erickson - 02/18/20 05:27 PM
Tired of Using Cassette Player with iPhone
by Gebo - 02/18/20 05:04 PM
STP oil filter
by Stinky123 - 02/18/20 04:41 PM
How is this possible
by V10 - 02/18/20 04:07 PM
Monroe made in Turkey
by atikovi - 02/18/20 03:31 PM
NSFBitog
by Ursatdx - 02/18/20 03:25 PM
Wider rear tires?
by drop - 02/18/20 03:07 PM
ROCKAUTO Coupon Codes
by jrvn - 02/18/20 02:24 PM
Gold (brass?) flecks in drained Honda ATF
by TNM6i - 02/18/20 12:10 PM
What happened to licensed ATF clones?
by TimN3QE - 02/18/20 12:08 PM
E85 in non-flex fuel Ford Expy ~2013
by DriveHard - 02/18/20 11:46 AM
Jacking up a car by itself
by Alfred_B - 02/18/20 11:44 AM
Valvoline MST in 2015 Macan S
by musclecarscott - 02/18/20 11:43 AM
PH10060 oversized?
by bullwinkle - 02/18/20 11:36 AM
GardenStateAudi, Strommen95, Idaholewis, Sprite, spbonus
70746 Registered Users
86 registered members (AdditionalD, Ag76, AC1DD, aleneros, 2009Caraman, 2010Civic, 11 invisible), 1,767 guests, and 15 spiders.
Topics301,629
Posts5,199,489
Members70,746
Where to find Pennzoil Ultra Platinum 0W-20 SN PLUS datasheet #5119479 05/29/19 04:09 PM
M
mikecz Offline OP
M
Does anyone know where it can be found? The ones on the US and Canadian Pennzoil website have 'SN', but no 'SN PLUS'.
Re: Where to find Pennzoil Ultra Platinum 0W-20 SN PLUS datasheet [Re: mikecz] #5119509 05/29/19 04:40 PM
B
buster Offline
B
I had Shell send me the 5w20 and 0w20 SN + PDS. They are as of May 2019. I’ll try and upload and image in a bit.
2019 Frontier Pro 4X - RGT 5w30
2019 Impreza Sport - OE fill
Re: Where to find Pennzoil Ultra Platinum 0W-20 SN PLUS datasheet [Re: mikecz] #5119513 05/29/19 04:41 PM
G
Garak Offline
G
Check here. If it's available anywhere, it will be there.
Plain, simple Garak.
Re: Where to find Pennzoil Ultra Platinum 0W-20 SN PLUS datasheet [Re: mikecz] #5119543 05/29/19 05:08 PM
T
tenderloin Offline
T
Re: Where to find Pennzoil Ultra Platinum 0W-20 SN PLUS datasheet [Re: mikecz] #5119566 05/29/19 05:37 PM
M
mikecz Offline OP
M
Thanks, yes, it's there.
Comparing Ultra to Platinum, is it worth the extra ~$3 per 5 litres, in your opinion? smile It's ever so slightly thicker, 48/8.8, vs 46.3/8.6 for the Platinum, and they have similar flashpoints now. What other differences are there, or might there be, if you don't know for sure, between the current Ultra and Platinum in 0W-20?
As for the Ultra SN to SN PLUS, from the Canadian PDSs, the only change seems to be the flashpoint, which went from 224C (D93) to 208C (D93).
As for the Platinum, via epc.shell.com,
__'German' 'Shell Helix Ultra SN PLUS 0W-20' (https://www.shell-livedocs.com/data/published/en/33fea361-c8d2-4cbd-b3a4-aff1b35fac61.pdf),
has the same numbers as,
__'Canadian' 'Pennzoil Platinum SN PLUS 0W-20' (https://www.shell-livedocs.com/data/published/en-CA/47ee9a21-8068-4328-9444-a38578a240cc.pdf),
except the flashpoint is D92 in the German PDS, and D93 in the Canadian one.. the actual flashpoint number is the same though... coincidence, or mistake? Are those two actually the same oil??
Also, the Canadian 'Pennzoil Platinum SN PLUS 0W-20' I got at Canadian Tire today (April 2019 on the jug) doesn't have HTO-06 on the back, but the PDS (01.29.2019) has it. Mistake in the PDS? hmmmm confused
coffee
Re: Where to find Pennzoil Ultra Platinum 0W-20 SN PLUS datasheet [Re: mikecz] #5119580 05/29/19 05:52 PM
M
mikecz Offline OP
M
By the way, the Pennzoil oil selector, for my car, suggests PUP for 'premium' and PP for 'standard', which is obvious I guess, but shell.de's oil selector recommends only Helix Ultra SN, not SN PLUS, though both exist, and there is no equivalent to PUP in Europe? I tried to find an SN only PUP today, but couldn't (other than a 2 year old one), so just bought the SN PLUS PP, thinking that I vaguely recalled reading somewhere on BITOG that the SN+ PP and PUP might be almost the same now.
Sorry, just trying to make sense of the differences between the various 0W-20 Shell synthetics.
Thanks in advance.
Re: Where to find Pennzoil Ultra Platinum 0W-20 SN PLUS datasheet [Re: mikecz] #5119599 05/29/19 06:18 PM
G
Garak Offline
G
Errors on data sheets are not uncommon. The Honda spec used to be 5w-30 only, as I recall, but was expanded to other grades. Hopefully someone here will know more about that than I do. Pennzoil will use up their old labels first, in any event.
Re: Where to find Pennzoil Ultra Platinum 0W-20 SN PLUS datasheet [Re: mikecz] #5119686 05/29/19 07:27 PM
SubieRubyRoo Offline
HTO-06 is an outdated spec that only ever truly applied to a single vehicle, the Acura RDX turbo. Current SN+ and the appropriate ACEA oils will almost certainly exceed every requirement of HTO-06.
What vehicle are you using this in?
Mobil info on HTO-06, thanks to Buster
De omnibus dubitandum.
