Using the concrete slab under the deck during the summer as another outside area. Not covered so it gets wet. it doesn't get a lot of sun so takes a while to dry out. Gets some mildew and algae if there is a lot of rain.
I bought some Olympic multi-surface waterproofer from Home Depot with hopes that it will help keep it dry. I put it on with a roller. White milky substance that was absorbed into the concrete. It dried like nothing was there. Then 24 hours later it rained. I was expecting "waterproof". Instead I still got a wet slab but it appeared to repel water a little better.
Is my expectations of the word waterproof too high? Or is this another VOC product underperforming?
