Originally Posted by AC1DD
Originally Posted by hallstevenson
Originally Posted by CT8
Siphoning out the M/C does not really do any good
I've wondered how much, if any, does brake fluid "circulate" or is it somewhat static ? For instance, if a piece of "dirt" fell in the master cylinder, will it eventually make it to one of the calipers, then to another, and so on ?
Someone here discussed that some time ago...I believe they said that the fluid at the front calipers/piston areas was BLACK as night even after doing the refreshing the fluid with the turkey baster out of the MC reservoir.
I asked because if you can see the dirty brake fluid from the master cylinder, it has to circulate for it to have dirty fluid right?
