Bruce Crower Passes
by 02SE. 07/20/19 12:30 AM
Toyota YZZA1 Filter, 9,958mls
by edyvw. 07/20/19 12:06 AM
Chevron Supreme 5w30 Noack?
by Whammo. 07/19/19 11:56 PM
Injector sleeves in 7.3 Powerstroke w/ 6 sp MT
by Earls1st. 07/19/19 11:32 PM
Which 0W20 to slow use
by lukejo. 07/19/19 11:09 PM
2012 Camry suspension question
by lukejo. 07/19/19 11:03 PM
Opinions on manufactured homes
by ram_man. 07/19/19 10:50 PM
NGK Ruthenium HX
by David1. 07/19/19 10:21 PM
Royal Purple Filter Mileage Rating
by JerryBob. 07/19/19 09:53 PM
what brand of filter is this?
by ctwhitechin. 07/19/19 09:45 PM
VW Amorak truck
by AZjeff. 07/19/19 09:25 PM
New Honda Super Cub - leaking oil
by Lawn_Care. 07/19/19 08:55 PM
Loc-n-lube
by rideon. 07/19/19 07:54 PM
Humidity thread follow-up... phew!
by 14Accent. 07/19/19 06:55 PM
NEW FEDERATED LF651F FILTER CUT OPEN
by 53' Stude. 07/19/19 06:39 PM
Brake Job @ 26K On My GLC43
by 2015_PSD. 07/19/19 06:25 PM
New Scanner Autel MK808BT
by another Todd. 07/19/19 06:20 PM
Stonehunter, ctwhitechin, gwandless, Philippe1988, ChiefDaBooty
68712 Registered Users
28 registered members (CleverUserName, chrismo, c1vic, Driz, DrDave, 4 invisible), 649 guests, and 26 spiders.
Topics292,124
Posts5,017,197
Members68,712
Most Online2,967
Mar 10th, 2019
Anti seize ? #5118792
05/28/19 11:45 PM
05/28/19 11:45 PM
wa
Exhaustgases Offline OP
wa
All aluminum male and female threads, what is best to use to stop galling and corrosion?
Re: Anti seize ? [Re: Exhaustgases] #5118820
05/29/19 01:27 AM
05/29/19 01:27 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Anti seize ? [Re: Exhaustgases] #5118865
05/29/19 05:14 AM
05/29/19 05:14 AM
Upper midwest
Mainia Offline
Mainia  Offline
Upper midwest
5% moly grease.
Re: Anti seize ? [Re: Exhaustgases] #5118885
05/29/19 05:48 AM
05/29/19 05:48 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Definitely bring a torque wrench o that party.
Re: Anti seize ? [Re: Exhaustgases] #5118922
05/29/19 06:59 AM
05/29/19 06:59 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
This. Now called Aluminum anti seize. Good to 1600 F. Military spec.
www.permatex.com
If you want the job done right......do it yourself.
Re: Anti seize ? [Re: Exhaustgases] #5118923
05/29/19 07:00 AM
05/29/19 07:00 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
For aluminum on aluminum you want to use a ceramic never seize, this is a good one. Don't bother with Amazon they want $150 for a case, this place will sell you one.
https://www.emisupply.com/catalog/w...tiseize-paste-106oz-brushtop-p-2310.html
Edit: I thought this might be of interest.
Re: Anti seize ? [Re: Exhaustgases] #5118945
05/29/19 07:49 AM
05/29/19 07:49 AM
NJ
JLawrence08648 Offline
NJ
The Permatex is good stuff. For past 50+ years I've been using Never-Seize, graphite based, because my father used it. It has served me well, never has failed. You can get it at plumbing supply stores. I use it on car's lug nuts, besides bolts which are heated, exhaust, ... Bicycles, lawn mower bolts especially the blade bolt, snowblowers
Re: Anti seize ? [Re: Exhaustgases] #5119058
05/29/19 09:51 AM
05/29/19 09:51 AM
Texas
2009Edge Offline
2009Edge  Offline
Texas
Never seize on lug nuts will change the torque value. Lug nut torque relies on the friction of the nut threads and the friction of the nut shoulder and the wheel. Any lubricant will change the value.
Re: Anti seize ? [Re: Exhaustgases] #5119105
05/29/19 10:40 AM
05/29/19 10:40 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
DIYers, 99% of situations where Anti seize is used can just as well be served by chassis grease grin2
Thick oil is better grin2
Re: Anti seize ? [Re: Exhaustgases] #5123631
06/03/19 04:48 AM
06/03/19 04:48 AM
wa
wa
I was thinking using Al type anti seize, may not be a good idea on all Al parts, since it is already a case of Al on Al. That permatex is okay on steel bolts, just not sure about all aluminum.
