Originally Posted by maxdustington
By the time your DD needs a new CV at 250k miles, Raxles might not be the best option unless you are certain about the rest of the vehicle. Unless you are sick of twisting axles at the dragstrip!
You'd be surprised how not true that is
Most CV axle "rebuilds" out there are poorly/cheaply "done" by Cardone. At best, you'll get a reground axle, but more likely they just slip on a new boot made of neoprene, which is inferior to the original boot. Remember that almost all CV failures are due to torn boots.It might even fail again within a year!
Raxles is worth it if they make them for your car, which they do for all Hondas
If it's not worth using Raxles, it's not worth keeping the car
If the car is worth keeping, it's worth Raxles. If the job is difficult or time-consuming, it's worth using Raxles
