Originally Posted by atikovi
Originally Posted by jongies3
You don't need larger, just a better filter! 820S is the WORST MC filter in the lineup for tearing and general poor quality control problems.
If it's good enough for Ford to put on cars under factory warranty it's good enough for anything I put it in.
Which do you want, a part that will last the warranty period, or a part that will last as long as you keep the vehicle?
If you keep the vehicle for just the warranty period, then fine, but if you keep it a lot longer, why use an inferior part?
