NAPA Presents: A Concert Behind Prison Walls
by GumbyJarvis. 07/15/19 11:35 PM
2019 Dodge Ram Warlock
by buster. 07/15/19 11:04 PM
2014 VW Jetta - transmission service
by gregk24. 07/15/19 10:09 PM
I wish my Camaro was this color!
by clinebarger. 07/15/19 09:19 PM
2019 Crosstrek 2500 Mile Review
by Al. 07/15/19 09:00 PM
Panasonic Cockpit Radio
by dishdude. 07/15/19 08:36 PM
97 Honda Civic won't crank
by Merek. 07/15/19 08:22 PM
Farmall alternator
by chilson450. 07/15/19 08:19 PM
30K and Hyundai ATF?
by flinter. 07/15/19 07:43 PM
'03 Suburban Quirks
by A_Spruce. 07/15/19 06:51 PM
new clutch shop $1500
by sirgerman. 07/15/19 06:45 PM
Pain in the rear transmission service...
by 14Accent. 07/15/19 06:38 PM
Longer Canister Fram Ultra Part #?
by gwarrior4u. 07/15/19 06:27 PM
Rats! I need bodywork
by PeterGreen. 07/15/19 06:15 PM
ATF-4?
by WillB. 07/15/19 05:58 PM
Rotunda AOD Transmission Rebuild Tool Kit
by TooManyWheels. 07/15/19 04:44 PM
No more Champion plugs for me LOOK!
by bchannell. 07/15/19 04:11 PM
Lucas_Jones, cobb_cruiser, robinjeter, SpicySenpai, Weatherdriver77
68669 Registered Users
48 registered members (Bailes1992, A_Spruce, AC1DD, Ammofirst, 1WildPig, 928, 5 invisible), 986 guests, and 27 spiders.
Topics291,925
Posts5,013,434
Members68,669
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
Oil and filter 9000miles trip with 7000lbs trailer. #5118296
05/28/19 03:00 PM
05/28/19 03:00 PM
ON
MagneticFX Offline OP
ON
2017 F150 V8. What oil you will recommend for 9000 miles summer trip East- West- East trip with 7000lbs travel trailer ,also by Canadian Rocky Mountain 2ways.
16000 miles on truck at the moment and will keep my F for next 10+ years .
Should I go with higher HTHS and viscosity oil fro that trip ?!
At the moment i'm running PUP 5W20 ( Ford specs ) with Purolator Boss filter . Will change oil after get to west coast.
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118303
05/28/19 03:07 PM
05/28/19 03:07 PM
Killeen, TX
GumbyJarvis Online happy
GumbyJarvis  Online Happy
Killeen, TX
I'd bump the PUP to the 5w30 and whatever filter suits your taste if it still falls under Ford specs and roll with it.
Safe travels!
2018 RAM 1500 SLT 5.7L HEMI 19K
Schaeffers 5w20 - Mahle OC 614
Disabled US Army Vet
OEF 2013-2014
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118305
05/28/19 03:11 PM
05/28/19 03:11 PM
SE PA
diyjake Offline
diyjake  Offline
SE PA
I would change the oil filter with a Fram Ultra, much better filter than the Purolator Boss.
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118319
05/28/19 03:23 PM
05/28/19 03:23 PM
Far East Side
DoubleNickels Offline
Far East Side
Ford specs are minimum for daily driving. Go to the back of the the owners manual, and you will find maintenance schedule for severe duty. 5W-20 synthetic blend should be switched to full synthetic, and maybe even 5W-30. Although some people will say that the engine was engineered for the lower viscosity oil, and a thicker oil may be harmful.
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: diyjake] #5118320
05/28/19 03:25 PM
05/28/19 03:25 PM
Killeen, TX
Killeen, TX
Both are good filters, both are different brands "top of the line" filters. Both will work for what hes trying to accomplish.
Plenty of 1/2 ton pickups in fleet/construction uses run with OEM spec Oils/Filters or even whatever is the cheapest. Some of these pickups go hundreds of thousands of miles without an issue. Either a Boss or a Ultra are gonna do the jobs they were intended to do
OEF 2013-2014
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118333
05/28/19 03:35 PM
05/28/19 03:35 PM
PimTac Offline
PimTac  Offline
That is severe service. Why not change the oil at a predetermined point along the way? Towing 7000 pounds over the Rockies is hard work for any engine no matter what the commercials say.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118334
05/28/19 03:38 PM
05/28/19 03:38 PM
Midwest
volk06 Offline
volk06  Offline
Midwest
Personally with that trip and towing, I'd use M1 or Edge 0w-40, if you do not care about the required weights. If you want to stick with a 5w-20, I'd get M1 EP or Castrol Edge, as edge is a very thick 20wt.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118363
05/28/19 04:08 PM
05/28/19 04:08 PM
Alberta
carviewsonic Offline
Alberta
That's severe service IMO, so I would run a full syn 5W30, and change at 7-8000 kms during the trip.
'18 Impala
'05 Park Avenue
'03 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118367
05/28/19 04:14 PM
05/28/19 04:14 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
I'd go with PUP 5W-30 and the Fram Ultra. Leave it I for the full trip.make sure you check the level and top it up if necessary.
2015 Grand Caravan SXT Plus 5w-30 Valvoline White Bottle/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118370
05/28/19 04:16 PM
05/28/19 04:16 PM
canada
hemitom Offline
hemitom  Offline
canada
i see you are another brother from Ontario.
i'm from the east and have been on the 0w30 kick , easy winter starts even unaided down to -30 and more than ample summer protection.
Thinking i will stay with 0w30 from now on.
I'm sure its the best of both worlds for your up and coming trip.
2014 buick verano.
2012 mustang coupe.
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: PimTac] #5118377
05/28/19 04:23 PM
05/28/19 04:23 PM
ON
ON
I will change oil at 4000-4500 miles thats should be 1/2 of the trip.
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118380
05/28/19 04:27 PM
05/28/19 04:27 PM
Ca.
UncleDave Offline
UncleDave  Offline
Ca.
Whatever brands grade and filter you settle on - you'll benefit from a magnet on the filter- or anywhere you can put one.
That little small block is going to be screaming its guts out and those cam chains and valve train flying- it behooves you to keep as much iron out of them as you can.
In my Nissan titan I run 5/10-30, or 0w40 , an ultra, a filtermag, and a magnetic drain plug. Mostly these brands- M1/M1EP/PP/Idemitsu
The titan is a shear beast as (Im guessing the coyote is as well especially with a DI pump) and it shears M1 0w-40 out of grade in 7500 miles of towing.
I haven't leaked it down but in 100K of mostly towing miles from 3500-9K through the brutal az desert - it still doesn't consume oil, smoke and mileage is identical to what it was at 3500.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118382
05/28/19 04:28 PM
05/28/19 04:28 PM
Upper midwest
Mainia Offline
Mainia  Offline
Upper midwest
5w-30
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: diyjake] #5118383
05/28/19 04:29 PM
05/28/19 04:29 PM
ON
ON
Iwould change the oil filter with a Fram Ultra, much better filter than the Purolator Boss.
Can you tell me more about the difference F ultra / P Boss, ( Media microns?! )
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118389
05/28/19 04:40 PM
05/28/19 04:40 PM
Killeen, TX
Killeen, TX
The main difference is people have a hatred towards Purolator due to the semi recent tearing issues in their regular/classic filters.
As someone who’s been on here since the days of “Use Purolator not Framz!” People are gonna say what they’re gonna say, and there’s always a slight bias toward one brand of oil or filter.
AFAIK, the boss hasn’t had issues with tearing, and is more than likely just as good as a ultra in this case.
Find a ford spec 5w30, use it, with the hauling I’d find something with a good lump of Moly in it, which is more than likely going to be a SOPUS product
I’d use QSUD 5w30 or Pennzoil Platinum 5w30 and a decent filter
In this case, if I did use a Fram, a tough guard will be both cheaper and more than enough for the job at hand.
I swear the love for fram ultras on here is crazy, they’re good filters, but yeesh, people just say “filter” and people scream “FRAM ULTRAS!!” Y’all probably use them on your lawnmowers and weed trimmers too.
OP just find a filter rated for your severe service oci and call it a day.
Edit: now might even be a good time to try the new Rotella Gas Truck 5w30!
OEF 2013-2014
Page 1 of 4 1 2 3 4
