Originally Posted by blupupher
Originally Posted by OnTheRocks
Installed at the factory. Used for service by dealerships.
I bought a case back about 10 years ago, and I still have 6 left.
Of course there are better filters. Nobody would go out on a limb to say that Ford Motorcraft are the best.
These filters are not the same as what is installed at the factory.
FoMoCo filters are what is installed at the factory, and are made by Champ Labs (used to be Wix made).
Motorcraft Filters are the aftermarket OEM and made by Purolator.
Originally Posted by BlueOvalFitter
Are there ANY reported engine failures from said "PROBLEMATIC" oil filter?
Until someone can prove that ANY MC oil filter has caused an engine failure, I will continue to use them.
And that is a choice you have made after seeing the problems with them. That is fine.
Turning a blind eye to a manufacturing defect and choosing to use a filter that has a known defect are 2 different things.
I choose to not support a company that has not addressed a known issue (and a filter that does not filter as it is supposed to is an issue) for over 5 years, regardless if there is any "proven" failure because of it.
It must be filtering correctly. I know of no engine failures.
Can you show ANY "proven" engine failures from "said problematic" oil filter?
