Pennzoil GF-6 & Low Viscosity Q&A
Click here to participate in the Pennzoil Q&A
2019 JD Power Initial Quality
by wemay. 06/26/19 01:42 AM
Legal matter stormwater pipe, no easment
by expat. 06/26/19 12:08 AM
2019 Yamaha FX Cruiser HO
by jtwrace. 06/25/19 11:14 PM
The Mysterious Mopar SAE 5W-20?
by John344. 06/25/19 10:24 PM
90915-YZZD3 particle count - ISO code 24/23/15
by newtoncd8. 06/25/19 10:12 PM
Pep Boys syn oil sale. . . $15.98 after rebate
by Robster. 06/25/19 09:47 PM
How to contact Amazon customer service?
by mjk. 06/25/19 09:10 PM
Leupold screws
by buck91. 06/25/19 08:51 PM
2004 Lexus RX330, 5659mi, Pennzoil Platinum HM 5W30
by newtoncd8. 06/25/19 07:38 PM
Milesyn 5w/20, 5500 miles, 2007 Mazda6 2.3L
by RayCJ. 06/25/19 07:12 PM
Mystik JT-6 Green tube @ Tractor Supply
by K20FA5. 06/25/19 06:58 PM
Saw a '53 Chevy this morning
by fdcg27. 06/25/19 06:20 PM
Motorcraft Mercon V opinions?
by Vigilant. 06/25/19 05:28 PM
New Personal Best MPG
by Kjmack. 06/25/19 05:01 PM
DuraMAX Synthetic Oil?
by Torino117. 06/25/19 04:54 PM
Battery Cables!
by NYEngineer. 06/25/19 04:35 PM
Brake Rotors
by WyrTwister. 06/25/19 04:00 PM
Rubber cement tubes?
by buck91. 06/25/19 03:53 PM
2019 Camaro SS 10sp auto, brief review
by Cujet. 06/25/19 03:14 PM
Beason, Toddstephens22, Macky, javadog, giwatcher
68488 Registered Users
27 registered members (07hemi, aleneros, 2105stgvh, ArrestMeRedZ, bbhero, Astro14, 3 invisible), 686 guests, and 22 spiders.
Topics290,976
Posts4,996,254
Members68,488
Most Online2,967
Mar 10th, 2019
2019 Toyota twin turbo 4.5 litre V8 diesel oil #5116814
05/26/19 09:48 PM
05/26/19 09:48 PM
Sydney, Australia
Up2nogood Offline OP
Sydney, Australia
Hi guys.
I have a question re what oil to run in this.
We’re running this as a farm wagon, and we’ll drive it until it’s junk on the farm only.
As it’s going to be fully off-road, we will be removing all the DPF and cats (don’t want issues with DPF and catalytic converter clog) which means we no longer need to run rubbish oil to suit these systems.
My default oil here is (usually) the same stuff we put in the farm trucks and tractors, being Delvac Super 15W40 or Rimula R4X 15W40.
But I don’t know a lot about these little V8 diesels. We run 15W40 in everything else and they have lasted just fine. Toyota want a DPF safe 5W30, which will wear out the engine.
Am I on the right track here?
Re: 2019 Toyota twin turbo 4.5 litre V8 diesel oil [Re: Up2nogood] #5116847
05/26/19 10:30 PM
05/26/19 10:30 PM
New Hampshire USA
Dinoburner Offline
Dinoburner  Offline
New Hampshire USA
So jealous, we can`t have the Toy diesel here. Wouldn`t dare advise on which oil.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: 2019 Toyota twin turbo 4.5 litre V8 diesel oil [Re: Up2nogood] #5116858
05/26/19 10:44 PM
05/26/19 10:44 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
I thought farm trucks were supposed to be heaps? Must be a nice farm.
Straight pipe that bad boy and run the tractor oil!
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: 2019 Toyota twin turbo 4.5 litre V8 diesel oil [Re: Dinoburner] #5116884
05/26/19 11:59 PM
05/26/19 11:59 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
Pretty sure posted just to rub it in. cry
95 Cherokee 190K DELO 10W30, XG8
07 IS250 110K Frankenbrew, WIX 57173
04 YZF-R1 19K DELO 15w40, XG7317
14 RX450h 41k Idemitsu 0w20, WIX 57047
18 RAM 3500 <1k VWB 15w40, Dual DBL7349
Re: 2019 Toyota twin turbo 4.5 litre V8 diesel oil [Re: Up2nogood] #5116898
05/27/19 12:28 AM
05/27/19 12:28 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Originally Posted by Up2nogood
Hi guys.
You might want to educate yourself.
Keep using those "rubbish" oils.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: 2019 Toyota twin turbo 4.5 litre V8 diesel oil [Re: Up2nogood] #5117179
05/27/19 11:01 AM
05/27/19 11:01 AM
California
SavagePatch Offline
SavagePatch  Offline
California
The RAM 1500 EcoDiesel 3.0L was first spec'd for a 5w30 Low SAPS oil and was then back spec'd to a 5w40 Mid SAPS.
My RAM 1500 EcoDiesel has shown the best UOA's with a 15w40 Synthetic Blend.
I think your truck will be fine with a 15w40. Save yourself some money and leave the exhaust aftertreatment parts in place and run a CK-4 or E7/E9 spec'd oil. If the parts fail outside of warranty then do a delete.
Re: 2019 Toyota twin turbo 4.5 litre V8 diesel oil [Re: Up2nogood] #5117277
05/27/19 01:00 PM
05/27/19 01:00 PM
New Braunfels
Bryanccfshr Offline
Bryanccfshr  Offline
New Braunfels
Yeah but the nearness to river may add recreational rental value
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: 2019 Toyota twin turbo 4.5 litre V8 diesel oil [Re: Up2nogood] #5117285
05/27/19 01:20 PM
05/27/19 01:20 PM
California
CleverUserName Offline
California
The Low-saps crowd will tell you that C3 oils are great and they are suitable for this application. However you will see that with regular UOA sampling an HDEO that is CJ-4, CK-4 or even CI-4+ will hold up better and produce lower wear numbers.
A 10w30, 5w40 or 15w40 that meets the above specs will be excellent. Full Synthetic would be best because of the twin turbo and extra heat/load this truck will see. Personally I’d be looking at the 40 wt options. Amsoil, Kendall, Redline, Penrith, Ravenol, etc...
Re: 2019 Toyota twin turbo 4.5 litre V8 diesel oil [Re: Up2nogood] #5117744
05/27/19 11:22 PM
05/27/19 11:22 PM
Sydney, Australia
Sydney, Australia
Thanks guys. As to the factory spec oil, we’ve already had overhead gear failure on a 4cyl TD Toyota Prado at 70,000 kms which has been attributed to the type of oil used by Toyota. Unfortunately it died outside of warranty.
Im not greatly interested in having the same occur on this one. Our older farm utes without these things do 600,000 with minimal fuss before one of the team or our environment eventually break them.
As the local EPA isn’t going to fund me new engines, I’m going with what would be spec’d without this equipment. No offence meant with the rubbish oil comment, just been my poor previous experience.
As to it being the farm rig, my back can’t take the leaf sprung utes anymore and they are only $15k less than this rig and I deduct it from tax anyway. This poor thing will be driving dirt roads with a three tonne trailer, so it’s going to suffer quite a bit.
Thanks for the feedback, once we bin the EGR and pull the rest of the gear off and replace it with a ratbag exhaust, I’ll switch over to the synthetic 15W40.
Re: 2019 Toyota twin turbo 4.5 litre V8 diesel oil [Re: Up2nogood] #5118005
05/28/19 09:55 AM
05/28/19 09:55 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
If you will leave dpf and egr as it is...look for Rimula R6lm in 10w40.....ash level is just 0.9 (ACEA C3 is 0.8 for comparison)...
I am fideling with that oil option for my Yaris with D4d engine (DPF) wink
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: 2019 Toyota twin turbo 4.5 litre V8 diesel oil [Re: Up2nogood] #5118800
05/29/19 12:00 AM
05/29/19 12:00 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
4cyl Toyota diesels, especially smaller ones, 2.2 and 1.4 are absolute POS of engines. I have 3.0 D-4D Prado in Europe, and it is astonishingly unremarkable and below average reliable engine. 1.4 and 2.2 engines are probably some of the worse engines European market ever seen when it comes to diesel engines. ANd it does not have anything to do with oils, but poor quality and design.
I would go with 5W40 oil that meets MB 229.51 specification in that engine.
Re: 2019 Toyota twin turbo 4.5 litre V8 diesel oil [Re: CleverUserName] #5118801
05/29/19 12:02 AM
05/29/19 12:02 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Low-SAPS oils are there to protect overly expensive emission system. All taxi vehicles are running on Low-SAPS oils, and pretty much all gas and diesel engines are running on low -SAPS oils. SO if wear is bit higher what does that mean? That engine is not going to last 400k, but 359k?
Re: 2019 Toyota twin turbo 4.5 litre V8 diesel oil [Re: SavagePatch] #5118806
05/29/19 12:04 AM
05/29/19 12:04 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Those engines were moved to heavier oils due to engineering issues, not because oils are bad.
Re: 2019 Toyota twin turbo 4.5 litre V8 diesel oil [Re: Up2nogood] #5118817
05/29/19 01:09 AM
05/29/19 01:09 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
I have to disagree with you about Toyota diesels....1.4 & 2.2...you dont like them because of higher oil consumption on them...but that was back in 2007/2008...only
3.0 Prado...well yes they are fincky engines....like to crack heads (mine was repaired by a previous owner)....but that is the reason why I am a little OCD with coolant change and I also have 76C tjetmostate in it
Re: 2019 Toyota twin turbo 4.5 litre V8 diesel oil [Re: Kamele0N] #5118823
05/29/19 01:30 AM
05/29/19 01:30 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
I was involved in fuel testing on 1.4 D-4D engines. It is absolute POS, with pumps that are designed to run basically on laboratory clean diesel. The list of what to use or not to use in that engine is on par with how to handle Gremlins smile 2.2 had engineering issue and quality of components issue. It is issue since 2005. That is to put on a side the fact that those are mediocre engines in every performance aspect.
Only Toyota diesel that is really good was inline 6 in Land Cruisers that red Cross used, with no turbo smile
