LSPI Event - ?
by josephp732. 06/16/19 08:39 AM
'09 Honda Metropolitan hit 15k this morning
by Lawn_Care. 06/16/19 08:17 AM
16 y/o car w/98k, switch oil?
by Ricky_Samsonia. 06/16/19 08:13 AM
Ultrasonic Cleaner
by ET16. 06/16/19 06:27 AM
Best Shell/Pennzoil is?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
SyedTribo, bagyoau, frank57, gheewala114, Rob_Jeff
68413 Registered Users
92 registered members (1WildPig, 1foxracing, 87sammy, 2003f7, alarmguy, 7 invisible), 1,770 guests, and 26 spiders.
Topics290,264
Posts4,987,362
Members68,413
Most Online2,967
Mar 10th, 2019
benefits of leaving a penetrating oil to soak in #5116599
05/26/19 06:31 PM
05/26/19 06:31 PM
Winnipeg MB CA
Number_35 Offline OP
Winnipeg MB CA
Some background:
I was working on my friend's car, a 2012 Chevy Sonic he'd bought new. He had previously had both front stabilizer bar end links replaced, one under warranty and the other by Midas a year ago. (These are plastic shafts with a ball-and-socket at each end; the socket wears, and they start knocking over bumps.)
When he was at Midas a few weeks ago having his tires swapped over (winters to all-seasons), they told him his struts needed to be replaced. (The front end was making various evil noises - knocking and thunking and rattling harshly.) He brought it over for a 2nd opinion, and the struts looked OK to me - but they did have over 100K km on them, and he wanted to proceed. We did the driver's-side strut first, and found that the stabilizer bar end-link previously replaced under warranty was shot - lots of play in the lower ball-and-socket. OK, there's some of the noise. These are always a challenge here in the semi rust belt. (Due to our extreme cold, it's not as bad here as southern Ontario or Quebec, but stuff does rust. There's not too much oxidation happening at -35 C, but this past winter was terrible with a number of freeze-thaw cycles in March. I was riding my bike home during a thaw, and tasted salty brine every puddle I went through, for example. Imagine that stuff getting sprayed all over your undercarriage.)
Any of the FWD Asian cars I've worked on use a style of end link whereby one is supposed to use an Allen key or a Torx bit in the end of the threaded shaft to stop the ball from turning in the socket while one removes the nut from the threaded shaft. Terrible design for this climate, as one is limited to using a wrench rather than a socket, and there's no way a small Allen key or Torx has enough strength to hold the shaft while one is trying to turn off a rusted-on nut. I wish they would install these with anti-seize compound!!!
Anyway, we disconnected the top of the end link from the strut, which was easy, but when we had to disconnect the bottom from the stabilizer bar, it was a nightmare. I finally had to grind it off. Very challenging, as there was very little room to work. GRRRR!
The new strut and end link on the driver's side got rid of the distinctive knocking noise over bumps, but not the very harsh rattling noise.
We moved over to the other (passenger) side, and had a heck of a time getting the top nut off, but finally got it after about an hour, with liberal application of penetrating oil, and going back and forth with a wrench while trying to keep the ball from turning. This on a part that had been installed by Midas only a year or so ago. Wow, rust never sleeps. At that point I had to pack up for the day. My wife and I went away for a few days cycling, but I gave my friend my rattle can of PB Blaster and asked him to soak the bottom nut and threaded rod a few times while we were away. This was more or less an act of pure optimism on my part - on the other side the bottom nut was much harder to remove than the top. How much worse would this side be, with the top nut on this side so much more difficult than the top nut on the other side???
He brought the car over yesterday, and we found the source of the harsh rattling sound - the bottom nut on the passenger-side end link had backed off several turns, and the threaded shaft was moving in the the stabilizer bar hole. We presume that the nut had worked loose sometime after Midas had installed it. It's interesting they didn't find it when they diagnosed the struts as being bad. We also found that the link had been installed upside-down - the plastic body of the link is marked 'STRUT' or 'STAB BAR' at each end. (You can barely see these embossed markings in two of the photos.) The link looks the same either way to me, but they had installed the stabilizer bar end on the strut, and vice versa. Perhaps that led to the nut working loose. Just a guess.
But here was the surprise - the bottom nut came off with ease. I know it's not a controlled experiment, but it sure seemed that waiting for a week, and applying penetrating oil regularly over that week, made a huge difference. Facing this sort of situation in the future, I will definitely try to make time to pre-soak the parts to be removed with lots of penetrating oil for a few days in advance.
We installed the new links properly, and used plenty of anti-seize on both sides. The car drives quietly now. We saved both struts, as I really don't think there was much wrong with them.
Re: benefits of leaving a penetrating oil to soak in [Re: Number_35] #5116648
05/26/19 07:23 PM
05/26/19 07:23 PM
ME
eljefino Offline
eljefino  Offline
ME
What I typically do with these is cut the extended stud flush with the nut, actually, slightly under-flush so I'm looking at all shiny metal. Then I slice a dash across the remnants of the stud so I can stuff a flat head screw driver in there.
The rust connection is on the outer part of the stud where it hits the outer (top) of the nut. Cutting all that off makes the part seem like it went on yesterday.
Re: benefits of leaving a penetrating oil to soak in [Re: eljefino] #5116713
05/26/19 08:25 PM
05/26/19 08:25 PM
Winnipeg MB CA
Winnipeg MB CA
Thanks, good thought. I'll try this when I encounter this again. I imagine things would rust in coastal Maine.
Re: benefits of leaving a penetrating oil to soak in [Re: Number_35] #5116767
05/26/19 09:09 PM
05/26/19 09:09 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Nice job. It's wise to pre soak everything with penetrating fluid. Also good to use a wire brush to remove the rust scale build up. Also great to use Anti-seize on the new stuff.
2015 Grand Caravan SXT Plus 5w-30 Valvoline White Bottle/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: benefits of leaving a penetrating oil to soak in [Re: Number_35] #5116776
05/26/19 09:14 PM
05/26/19 09:14 PM
Champlain/Hudson Valley
Kira Online content
Kira  Online Content
The mechanical story was good.
THE THING I see with any penetrating oil is that people spray it on and take a tool to it immediately. Fools can be seen spraying for 10 seconds as the product drips off. They look like they're enjoying it.
You must try to brush the rusted zone clean of surface rust as best you can and add penetrant several times....perhaps over a week if you have the option.
Re: benefits of leaving a penetrating oil to soak in [Re: Number_35] #5117014
05/27/19 08:00 AM
05/27/19 08:00 AM
NJ
Leo99 Offline
Leo99  Offline
NJ
After struggling to remove the sway bar links on my Rav4, I bought a cheap angle grinder at HF. Just cut them off next time.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: benefits of leaving a penetrating oil to soak in [Re: Leo99] #5117026
05/27/19 08:13 AM
05/27/19 08:13 AM
Winnipeg MB CA
Winnipeg MB CA
Works well on some vehicles, not so well on others. The Sonic is very crowded around there, with the LCA quite close. I had to resort to cutting off the lower end on the passenger side, but was glad to avoid having to do so on the passenger side.
Re: benefits of leaving a penetrating oil to soak in [Re: Number_35] #5118060
05/28/19 10:44 AM
05/28/19 10:44 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Penetrating oil penetrates !!!!!
2015 F150 2.7
2018 F350 6.2
