ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
My new rig - 1987 Ford Econoline 27' Glendale RV
by caprice_2nv. 07/16/19 07:44 PM
Air Compressor OCI?
by Vern_in_IL. 07/16/19 07:35 PM
Looking for an SUV
by dgunay. 07/16/19 07:29 PM
Castrol GTX Magnatec 5w30
by Envoyguy. 07/16/19 07:21 PM
2019 Subaru Dual X-Mode
by buster. 07/16/19 06:36 PM
Wear Metal Max?
by tsm750. 07/16/19 05:54 PM
Harbor Freight 25% off Thurs - Sunday
by JC1. 07/16/19 05:52 PM
80% Furnace exhaust silencer?
by PandaBear. 07/16/19 05:10 PM
MBhuntington, captainfloss, Lyndol, Belczek, Bronco628
68681 Registered Users
65 registered members (Al, Bailes1992, AZjeff, 2015_PSD, 6 invisible), 887 guests, and 17 spiders.
Topics291,976
Posts5,014,334
Members68,681
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: Get New HVAC or Keep Old? [Re: Kestas] #5116347
05/26/19 12:55 PM
05/26/19 12:55 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
Originally Posted by Kestas
Originally Posted by JMJNet
Check the capacitor every year and replace as necessary.
A lot of AC issue happens when capacitor went out.
It is not a bad idea to check what capacitor is used in the unit and have spare at home at least 1 for each type or get one of those multi capacitance capacitor.
A unit will have at least 1 or 2 running capacitor and 1 starting capacitor.
As long as we're on this topic, how do you manage capacitors in HVAC units? What do you look for, and when do you replace them?
My unit is 34 years old... original furnace and a/c. The a/c isn't used much here in Michigan. It'll likely die from corrosion before it wears out.
I bought a cheap capacitance tester (ONLY) from Amazon/Ebay that have a higher measurement range or you can get a more expensive multimeter with a higher range capacitance tester.
Every year, when I took off the winter covering, I tested all the capacitor.
For the most part it is good, you can see it bulging when it goes bad but 2 years ago I found a capacitor that is not bulging yet but it only has 2uF well below the rated 10uF.
It was an Amrad capacitor with 5 years warranty so I sent an email to them and they sent me a new one for free with a return label to return the defective one.
In TX, we used the AC more than the heater.
The AC coil cover usually goes up in late November/ early December and taken off sometimes in mid March.
Note: be careful when testing capacitor when the unit has been turn on.
Check Youtube and they have lots of video on this.
Based on experience, even in MI, you may want to turn the AC unit on sometimes to preserve the unit.
AC will go bad if you never turn it on.
  • 2017 Toyota Sienna
Re: Get New HVAC or Keep Old? [Re: Kestas] #5116398
05/26/19 02:09 PM
05/26/19 02:09 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
Capacitors are a crapshoot. I mentioned a replacement that lasted only 14 months, then replacing that with the exact same thing lasted over 3 years before the whole unit was replaced.
Few people replace them preemptively, instead waiting for failure. When they fail they fail fast, will bulge on the end instead of being flat. It is a great idea to have a spare already if your unit is getting older.
The failure is pretty obvious when it happens, the motor starts making funny sounds instead of spinning, but the one I repaired was in an area right next to a garage and frequently used entrance door so the owner was in and out often enough to notice that.
Anyway the motor could have shot bearings/bushings instead but if you (shut off power to it first) and can spin the blades without resistance, it's probably not the motor. Windings could short out but that would usually trip a fuse and regardless the capacitors don't usually last as long as the motors so checking the cap first gets to the most likely problem the fastest.
Lastly, "lubed for life" fan bushings is nonsense. It just means the fan will fail if the bushing runs out of lube and will last MUCH longer if you use a very light oil to lube every few years. Once upon a time ago they used to have lube ports, even tubes going to the ports to squirt some oil in, but in recent decades they saved 20 cents by omitting those so it takes more labor to get to the bushings to lube them. On older units then often have a felt/other reservoir so you can get quite a bit of oil into them but make sure you don't over-oil to the point where it's pushed out into the rest of the motor.
Re: Get New HVAC or Keep Old? [Re: tc1446] #5116520
05/26/19 05:03 PM
05/26/19 05:03 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
My furnace and AC vintage 1982 and they still work well. Compared to my neighbor who has new AC and furnace I spend $300 - $350 more per year. Doing the math it makes no sense to replace them. I do have back up heat [gas fireplace]. When it comes to sell the house I'll probably replace them as people don't appreciate the old reliable equipment.
Re: Get New HVAC or Keep Old? [Re: tc1446] #5116527
05/26/19 05:13 PM
05/26/19 05:13 PM
Cincinnati, OH, USA
bullwinkle Online confused
bullwinkle  Online Confused
Cincinnati, OH, USA
A spare dual run capacitor & a 24V contactor are good spare parts to have on hand, if you're mechanically inclined enough to replace them. Capacitors don't generally fail yearly, unless you have really high voltage or Chinesium caps!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Get New HVAC or Keep Old? [Re: gman2304] #5116533
05/26/19 05:23 PM
05/26/19 05:23 PM
Lexington, NC
tc1446 Offline OP
tc1446  Offline OP
Lexington, NC
Originally Posted by gman2304
I live 20 miles from you and their are plenty of HVAC people in our area who do emergency calls all the time. They even advertise as such on their work vans. My 24 year old Trane is happily humming away but if it poops out in the next hour I feel confident I can get someone out here today to fix it, granted at a premium on a holiday. I had a new furnace installed last fall and the tech checked my ac unit and said “ they don’t make them like this anymore” and it would be worth repairing when the time comes, though it does take more energy to run. As an aside, do you still have that IBM 30 cal carbine?
Thanks for info. I do still have the IBM.....Have we met before?
'14 Kia Soul, 2.0L (29K)
'13 Accord EX-L 2.4L (110K) M1 & FU
'00 Ford Ranger 4.0L {69K} M1 & FU
'18 Polaris Slingshot 2.4L GM (QS & Bosch Cart.)
'07 Kioti CK-30 (Delo & Wix)
Re: Get New HVAC or Keep Old? [Re: tc1446] #5116544
05/26/19 05:34 PM
05/26/19 05:34 PM
Lexington, NC
tc1446 Offline OP
tc1446  Offline OP
Lexington, NC
Super good advice and much appreciated. My Amer Standard Hi Eff has been kept clean, coils washed, etc., filters changed frequently. Fan blade turns easily but anything electrical is beyond my capabilities. I do know of a small contractor, recommended by an electrician friend. Based on all the comments it seems worth while to have him check out the system to see what he thinks. Maybe he can oil the motors too. Thanks again for all the feedback. Makes me feel a lot better.
Re: Get New HVAC or Keep Old? [Re: tc1446] #5116680
05/26/19 07:58 PM
05/26/19 07:58 PM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
20 years old isn't bad. If it breaks get a window unit to use until you can get it fixed, or fix it yourself.
Replaced a contractor for less than $10 last summer. Used a window unit while waiting on the mail ordered contactor, since locally they were at least $40.
Re: Get New HVAC or Keep Old? [Re: tc1446] #5116720
05/26/19 08:29 PM
05/26/19 08:29 PM
KansasCity
twoheeldrive Offline
KansasCity
Good advice on this thread. My recommendation, get a cheap window unit for backup. That will keep you going if the AC quits.
The AC in my houset is 35 years old and still going strong... although it has a small leak, so I have to add a pound or so of Freon every year. It's a five ton Lennox.
I think AC units can last a long time if they were installed correctly and not abused by running (by accident) in the winter and cycling them on and off quickly.
... using Mobil 1 since 1976.
Re: Get New HVAC or Keep Old? [Re: tc1446] #5116839
05/26/19 10:20 PM
05/26/19 10:20 PM
New Hampshire USA
Dinoburner Offline
Dinoburner  Offline
New Hampshire USA
Perhaps this should be in a different thread, looking to get rid of the wall shaker and buy a floor model but they all look poorly made with cheap plastic. Any advice, don`t need central AC here.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Get New HVAC or Keep Old? [Re: tc1446] #5116941
05/27/19 05:31 AM
05/27/19 05:31 AM
Maryland
RayCJ Offline
RayCJ  Offline
Maryland
My HVAC is about the same age. My son's friend is an HVAC installer and we sought his opinions not long ago. If your AC system is 20 years old, it's most certainly filled with R22 which is now VERY expensive because it was banned shortly after your unit was installed. If you need a refrigerant top-off, expect to pay up to $75/lb (varies locally). New units are rated by EER and SEER ([Seasonal] Energy Efficiency Ratio). Bigger number = higher efficiency.
A brand new unit today will only be a couple points higher today than the ones from 20 years ago if the old one is a decent name brand. The way EER is calculated has changed over time so, don't compare old units with new units. If properly maintained, the efficiency of a unit does not degrade much.
As time passes, units develop leaks and motors/compressors start wearing out. Replacement parts for the larger components are sometimes harder to get. Once the compressor is shot, it's generally not worth fixing especially if your unit is R22.
In my case, the system is well maintained and in good condition. I will run it till it drops. BTW: Capacitors are basically considered a consumable item. Any capacitor with the proper rating can be used instead of an OEM part. I've replaced mine a couple times.
Ray
PS: Stick with a large name brand such as Carrier or Trane. My son's friend feels that Carrier is pretty decent. Staying with a name brand will virtually ensure easy availability of parts and the service technicians will be most familiar with them. These things aren't rocket science so it's a simple matter of proper maintenance and availability of "consumable" parts.
Re: Get New HVAC or Keep Old? [Re: Dinoburner] #5117572
05/27/19 07:39 PM
05/27/19 07:39 PM
zzyzzx Offline
zzyzzx  Offline
Is a mini split system an option?
Re: Get New HVAC or Keep Old? [Re: zzyzzx] #5117614
05/27/19 08:44 PM
05/27/19 08:44 PM
New Hampshire USA
Dinoburner Offline
Dinoburner  Offline
New Hampshire USA
Need to educate self, did check out a Mitsubishi a couple years ago, interesting. Thanks
Kubota L5030 T6
Page 2 of 2 1 2
