Intermittent shake
by supton - 10/15/19 08:11 AM
0W 20 in place of 5W 30 in First Gen CRV?
by Revrick - 10/15/19 07:29 AM
Servicing '13 Cadillac SRX AWD Haldex unit
by gd9704 - 10/15/19 06:15 AM
Possible WIX failure?!?
by AutoNotifier - 10/14/19 11:59 PM
Possible WIX failure?!? What could have happened?
by tony1679 - 10/14/19 11:48 PM
Anyone use a radiant barrier?
by daves66nova - 10/14/19 10:13 PM
FS- Corolla 15 inch hubcap
by bowlofturtle - 10/14/19 10:04 PM
tire wear from -0.5 degree of camber
by bowlofturtle - 10/14/19 09:48 PM
E85 fuel composition?
by JorgeSimon - 10/14/19 09:12 PM
Microsoft enables Tamper Protection for Home Users
by Jimmy9190 - 10/14/19 08:13 PM
Need rotary hammer for chiseling tile & glued floor laminate
by JLawrence08648 - 10/14/19 08:06 PM
Super Auto of2500x (57045) cut open
by Inlo - 10/14/19 08:01 PM
Detailed the new Renegade!
by HoosierJeeper - 10/14/19 07:34 PM
All My Filters
by kstanf150 - 10/14/19 07:07 PM
Switching from conventional to synthetic
by messerschmitt - 10/14/19 06:04 PM
Lower MPG
by borgward - 10/14/19 06:02 PM
Hoffy1, joy786, robinasu, TriniDerian, kaspurr
69565 Registered Users
115 registered members (2015_PSD, 2004tdigls, A310, 2009Edge, 379KITTY, 53' Stude, 10 invisible), 1,765 guests, and 40 spiders.
Topics295,982
Posts5,088,659
Members69,565
Most Online3,532
Jul 30th, 2019
Maxlife ATF for +4 application #5116470 05/26/19 03:43 PM
Z
ZraHamilton Offline OP
Z
Can you use Maxlife synthetic ATF to replace +4 type ATF? It would be for a 2017 Ram 2500 5.7L gas with 6 speed auto. Thinking of drain/fill and filter change at 70k miles since it is used for a lot of towing.
Re: Maxlife ATF for +4 application [Re: ZraHamilton] #5116499 05/26/19 04:37 PM
B
bullwinkle Offline
B
Why would you want to not use ATF+4? Full synthetic, cheap, available everywhere-I've been tempted to use it in Dexron II/III applications (cheaper than Dex VI).
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Maxlife ATF for +4 application [Re: ZraHamilton] #5116513 05/26/19 04:54 PM
Z
zrxkawboy Offline
Z
I would stick with ATF+4.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Maxlife ATF for +4 application [Re: ZraHamilton] #5116517 05/26/19 04:59 PM
CT8 Offline
Maxlife seems to be on the thinner side.
2015 F150 2.7
2018 F350 6.2
Re: Maxlife ATF for +4 application [Re: ZraHamilton] #5116521 05/26/19 05:08 PM
W
WobblyElvis Online Content
Online Content
W
ATF+4 has specific static and dynamic friction characteristics. Your vehicle is designed/programmed with this in mind. Changing to a fluid with other specs would be asking for trouble in my books.
Re: Maxlife ATF for +4 application [Re: ZraHamilton] #5116530 05/26/19 05:17 PM
M
Mad_Hatter Offline
M
From CarTechBooks.com
"Chrysler ATF+4, also called ATE—a synthetic ATF introduced in 1998, it should always be used in any vehicle in which ATF+4 is specified. It can be used in Chrysler vehicles manufactured in prior years, except for minivans from before 2000, which use the 41TE/AE transmission. It is not compatible with Dexron or Mercon fluids."
I think you'd be wise to stick with genuine ATF+4 while you're still under warranty. You can buy qt size bottles of ATF+4 at Wally's and Carquest for about $5 or get a 5ltr jug of Mopar/ACDelco ATF+4 on Amazon for about $30.~35. The Mopar product is supposed to be one of those "for the life of" products but I'd still change it out per the mfgs schedule.
Re: Maxlife ATF for +4 application [Re: ZraHamilton] #5116558 05/26/19 05:45 PM
G
Gebo Offline
G
Maxlife ATF may be better than sliced bread for the little I know.
But I would use whatever the maker of my car/transmission recommended. In your case +4.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Shell Gas and Truck & Supertech Full Syn HM
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Maxlife ATF for +4 application [Re: ZraHamilton] #5116564 05/26/19 05:55 PM
demarpaint Offline
I'd stick with ATF+4. Auto Zone has Castrol ATF+4, two quarts for $11, untii the end of the month. WMT has Super Tech, which might even be cheaper.
God Bless Our Troops
Re: Maxlife ATF for +4 application [Re: ZraHamilton] #5116569 05/26/19 05:59 PM
slacktide_bitog Offline
During the warranty period, use any licensed ATF+4 from Chrysler's official approved list. All of these are the same. Walmart ATF+4 is licensed and thus is OK to use. The parts stores put Castrol ATF+4 on sale a few times a year. If you find an approved ATF+4 for less, use it smile
After the warranty is over, consider Redline C+ if you can afford it. If not, stick with something on the list.
If your transmission doesn't have a drain plug, get an aftermarket pan that has one.
Re: Maxlife ATF for +4 application [Re: bullwinkle] #5116688 05/26/19 08:03 PM
dave1251 Offline
The coefficients of friction don't match in this application. I would just wait until a ATF sale or use a house brand DEX VI.
don't use.
Re: Maxlife ATF for +4 application [Re: ZraHamilton] #5116761 05/26/19 09:05 PM
J
JC1 Offline
J
As others have said don't do it. From what I've read the majority of Chrysler Tranny fails were do to the wrong fluids being used throughout the years.
Use only ATF+4 in your tranny. I just drained and filled 2.5 liters (using a vacuum pump) from my 2015 Caravan last weekend and it's shifting a bit smoother. I have 60,xxx km (37200 miles) on it, Later this year I'll drop the pan and change the filter.
2015 Grand Caravan SXT Plus 5w-30 Valvoline White Bottle/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Maxlife ATF for +4 application [Re: ZraHamilton] #5116919 05/27/19 02:26 AM
T
The_Nuke Offline
T
You can, but you should not unless no other option.
Also, are you certain the transmission is using the ATF +4? I was under the impression everything after 2014 got the ZF transmissions, in which case there a ZF-specific fluid which has to be used (and it is more expensive than inkjet printer ink, so prepare yourself if you have to buy multiple quarts of that).
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 2.65 (215mm)
Re: Maxlife ATF for +4 application [Re: ZraHamilton] #5116937 05/27/19 04:55 AM
Snagglefoot Offline
Valvoline makes a separate stand alone product for ATF +4. It’s in a blue bottle. The Valvoline Maxlife ( in the red bottle ) does not list ATF +4 as being one of the products it replaces. Here is a shot of the back of the red bottle. Also have a look at www.valvoline.com
If you want the job done right......do it yourself.
Re: Maxlife ATF for +4 application [Re: ZraHamilton] #5116960 05/27/19 06:22 AM
Slick17601 Offline
Why? ATF+4 is available everywhere.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: Maxlife ATF for +4 application [Re: The_Nuke] #5117075 05/27/19 09:05 AM
Snagglefoot Offline
From the 2017
From the owners manual for a 2017 Ram: For the 8 speed AT use Mopar ZF 8&9 Speed ATF. For the 6 speed Automatic Transmission use ATF +4. Since the OP says he has the 6 speed AT, the AFF +4 is correct.
smile
