Oil additive and effects on oil analysis results
by MoneyJohn - 02/23/20 09:48 AM
More 6.7 PSD engine repairs
by mattd - 02/23/20 09:10 AM
How to get sediment out of heater oil tank?
by BAJA_05 - 02/23/20 08:37 AM
Oil Prices in Europe
by BBDartCA - 02/23/20 08:08 AM
Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
106 registered members (74Widebody, 53' Stude, 2004tdigls, 4WD, aircooled, 55hambone, 11 invisible), 2,152 guests, and 19 spiders.
Topics301,823
Posts5,203,385
Members70,787
Cutting Wet Grass #5116086 05/26/19 07:20 AM
Snagglefoot Online Content OP
OP Online Content
I normally don’t cut wet grass but I was away from home for two weeks, back home for two days and then had to leave again. The forecast was was for more rain so I decided to bite the bullet and cut the grass while it was still wet. It was about 6 inches long.
Here are my findings:
1. Forget about using the mulch or bagging features. Everything clogged. I dug out the plastic diverter that came with the lawnmower and put it on. Good thing I didn’t chuck it away. It kept the “ side door” open and allowed the grass to be launched sideways.
2. I changed the spring on the carb to the 2nd position on my Honda GCV 160. Someone else mentioned you can get more RPM by doing this and it’s true. That 2nd hole is not there by accident.
3. Watch the discharge. If it stops, you might as well stop the engine and clear it out.
4. Safety tip: Don’t clear the the diverter using your hand with the mower running. I know a guy who can only order 3 beer because of this.
5. Take a smaller bite with the mower. Takes longer but you don’t have to clear it as often.
6. Your lawn will be covered in clumps of gas. Run the mover over it if it ever dries out.
7. Wash the underside afterwards. It will be packed with wet grass. laugh
If you want the job done right......do it yourself.
Re: Cutting Wet Grass [Re: Snagglefoot] #5116116 05/26/19 07:47 AM
H
hemitom Offline
H
The exact reasons why i never cut my grass when wet.
Have done it a few times like you because of circumstance, what a real pain in the A$$
2009 Saturn Vue.
2015 Mustang GT Convertible.
Re: Cutting Wet Grass [Re: Snagglefoot] #5116117 05/26/19 07:48 AM
Cujet Offline
Thanks for the info on the second hole for the governor spring. I have two Honda powered mowers, a 160 and an 190. Both run about 3000 RPM, a bit lower than I’d like.
Re: Cutting Wet Grass [Re: Cujet] #5116147 05/26/19 08:22 AM
justintendo Offline
you will use a tad more fuel, but the bagging function and mulching are improved a good amount
13 escape 2.0 awd mobil 1 10w30ep
08 fusion 2.3 mtx mobil 1 5w30ep/redline mt90
96 f150 4.9 2wd mtx mobil 1 10w30hm/redline ps fluid
99 kaw zrx 1100 redline 10w40
many husqvarnas 5w40 t6 rotella
Re: Cutting Wet Grass [Re: Snagglefoot] #5116163 05/26/19 08:41 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
With the kind of wet spring we've had in Michigan, we had no choice but to mow wet grass.
Re: Cutting Wet Grass [Re: Snagglefoot] #5116204 05/26/19 09:18 AM
E
eljefino Offline
E
Sometimes you have to mow wet grass so the sun gets down to the earth so what's there can dry out.
IOW, 9-inch tall grass is a humidity trap that self-perpetuates its ugliness.
Washing the underside is rarely done. I let so much stuff accumulate and dry out that when I pull the chunks off (satisfying!) the deck is noticeably lighter. LOL
Re: Cutting Wet Grass [Re: Snagglefoot] #5116233 05/26/19 09:55 AM
A
atikovi Online Content
Online Content
A
Move to a condo? Hire a company to mow if you can't be home? Will you get a fine if the grass is too high?
Re: Cutting Wet Grass [Re: Snagglefoot] #5116354 05/26/19 12:08 PM
K
Kira Offline
K
Always 'thank you' for any tips large and small. This goes for everything and everybody....
....but # 4 did seem a little obvious.
I grab a fallen branch to poke about the discharge chute if I clog up while mowing wet grass.
Also, when my wet cuttings make their own windrows my mower can't reach 'em. Going over them is ineffective.
I hit 'em with a hand rake. That's the grass where I am.
Re: Cutting Wet Grass [Re: Snagglefoot] #5116358 05/26/19 12:16 PM
Dave9 Offline
I always have to mow wet grass here in spring. My mower came with a discharge chute but I haven't used it once in over 20 years... can't remember where I put it, lol.
I just mow slower, and overlap my path because it leaves a trail of grass that a second pass over helps to redistribute in a thin layer. I also need to clean the deck partway through spring. Spraying the underside of the deck with cooking oil helps to slow down grass buildup, and it comes off easier when I pull the deck to swap in sharpened blades. Sharp blades help a lot.
More than anything the PITA of mowing wet is the green goo that builds up everywhere, including places like the fan mine has that blows over the differential. Heh, I never even thought about changing the oil in the dff, should get around to it some year soon!
Re: Cutting Wet Grass [Re: Snagglefoot] #5116370 05/26/19 12:29 PM
R
RayCJ Offline
R
Ehhh, the lawn will live. If its really tall, go over it twice and raise the mower wheels a notch on the first pass. Most of my neighbors hire lawn services but, I cut my own for the same reason I change my own oil -because I can and because I enjoy it. Anyhow, if possible, cut your lawn each time in a different pattern (left-right and opposing criss-cross). This way, the droppings don't clump-up in the same spot.
So... have you noticed if the grass looks better when use 0w-20 or 5w-30. I think a little zinc additive helps too (Uh Oh... I hope that doesn't trigger a few of the regulars here. I heard a few brands year models of Briggs/Stratton engines had problems with their flat tappets hornets ).
Re: Cutting Wet Grass [Re: Snagglefoot] #5116393 05/26/19 01:04 PM
spk2000 Offline
I have mowed the wet grass when necessary but try not to. Currently mowing over an acre on a hill with rider only so it does make the hill portion very slick when wet. The tires also tear up the yard quite a bit more. I am noticing the rear wheels for past 3 years and 100 hrs have worn to the point of not holding the dry hill as well and sliding a bit more.
I put synthetic oil in motor and changed from the mini briggs filter to a fram 3600 (orange can) They didn't have any of the others and it was a better option than the briggs filter IMO.
What I am so surprised is how clean the oil actually is compared to how it used to get on conventional and the mini briggs filter. Did not expect much of a difference so it could be the oil and filter combo. It used to turn dark in 10-20 hrs on briggs oil and I know some will say dark oil doesn't mean anything. Clean looking oil to my eye is preferred though. I am noticing more smoke on start up though so not yet sure why but it doesn't really use oil so far 350 hrs on the briggs 22HP and going strong.
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Cutting Wet Grass [Re: Snagglefoot] #5116464 05/26/19 02:36 PM
dailydriver Offline
The contractors for our HOA management company cut/maintain the laws around here, but I get LIVID when they INSIST on cutting it WET and blowing all of that wet grass onto my WET car to help out the acids in such etch into my paint! mad
2016 Ford Fiesta ST 17K miles
Ravenol REP 5W-30
Fram XG3600 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Cutting Wet Grass [Re: Snagglefoot] #5116486 05/26/19 03:23 PM
Z
zzyzzx Offline
Z
My push reel mower works just as good on wet grass as it does on dry grass.
Re: Cutting Wet Grass [Re: Snagglefoot] #5116498 05/26/19 03:36 PM
V
vw7674 Offline
V
I hate the grass-stained shoes & fingers.
No more. Always cut dry or semi-dry.
Re: Cutting Wet Grass [Re: Snagglefoot] #5116518 05/26/19 03:59 PM
A
Al Offline
A
I never never never cut wet. Seems like I am the only person that doesn't. I have been cutting grass for 60 years and ever lawnmower I have used (12+) the grass sticks to the underneath. Yes I have used silicon.
