Nu Finish
by rrretiree7 - 04/02/20 07:18 PM
Leases?
by wallyuwl - 04/02/20 07:04 PM
Ford A/C quick connects
by Colt45ws - 04/02/20 06:16 PM
Steel rims ; How good are ...
by odie - 04/02/20 03:42 PM
I'll be back hopefully
by 53' Stude - 04/02/20 02:09 PM
Mazda CX-5 Skyactive Transmission fluid?
by Drew99GT - 04/02/20 01:32 PM
Transfer pics / videos iPhone to PC
by diyjake - 04/02/20 11:47 AM
Valve train noise on start up
by NavyVet88 - 04/02/20 11:24 AM
Eezox vs Prolix?
by Gebo - 04/02/20 10:52 AM
Tool battery question
by supton - 04/02/20 10:36 AM
Can not see NOT using HIgh Mileage Oil !!!
by BAJA_05 - 04/02/20 09:16 AM
Anyone here using a AGM battery for their mower
by zzyzzx - 04/02/20 08:19 AM
use E85 or not?
by foresthawk - 04/02/20 08:09 AM
2004 jeep transmission cooler
by jeep58 - 04/02/20 08:04 AM
'01 Ranger 4.0L Fuel Line Disconnect
by benjamming - 04/02/20 07:57 AM
ebarker, Knop, AConstructionGuy, MPDano, ferdna
71079 Registered Users
130 registered members (4WD, ABerns, Aero540T, 2004tdigls, 2009Caraman, 13 invisible), 2,074 guests, and 18 spiders.
Topics303,495
Posts5,236,349
Members71,079
Page 1 of 3 1 2 3
Ford 1.5 GDI Turbo Engine with 10.1 Compression Ratio #5115499 05/25/19 03:22 PM
tdi jerry Offline OP
I have two Ford Fusion's a 2016 and a 2018 both with the 1.5 GDI Turbo Engine with 10.1 Compression Ratio. I am using Mobil 1 5W30 Annual Protection. Is there a better oil for these two cars and does Castrol offer a better product than Mobil one ? I know Ford wants us to use a 5W20 but i am not sold on that idea.
2016 and 2018 Ford Fusion SE 1.5 GDI Turbo Ecoboost engine with 10:1 compression ratio both running Mobil 1 5W30 Annual Protection.
Jerry
Re: Ford 1.5 GDI Turbo Engine with 10.1 Compression Ratio [Re: tdi jerry] #5115516 05/25/19 03:35 PM
P
PPWarrior Offline
P
Castrol and Mobil are basically offering the same oil with their "flavor." I do think you are paying TOO much for oil. Regular Mobil 1 or Castrol or even Motorcraft would be better cost-wise than M1 AP.
Re: Ford 1.5 GDI Turbo Engine with 10.1 Compression Ratio [Re: PPWarrior] #5115527 05/25/19 03:43 PM
L
Linctex Offline
L
Welll... I got several jugs in 5W-20 AP when AutoZone clearanced them out for $10 a jug!
Re: Ford 1.5 GDI Turbo Engine with 10.1 Compression Ratio [Re: tdi jerry] #5115568 05/25/19 04:22 PM
CT8 Online Content
Online Content
With identical ratings ,,, oil is oil.
2015 F150 2.7
2018 F350 6.2
Re: Ford 1.5 GDI Turbo Engine with 10.1 Compression Ratio [Re: CT8] #5115652 05/25/19 05:43 PM
T
Triple_Se7en Online Content
Online Content
T
Wrong! Please read the labels carefully and slowly. Then observe what might be missing from them.
Jerry
No need to buy the most expensive. Buy Mobil-1 Vanilla and change every 5K. TGDIs need frequent changes, but still serve best with brand-name oils like Mobil, Castrol, Valvoline and Pennzoil.
Oil is not all the same. That's like saying 50 graduates holding the same, identical certification diplomas at Joe-Schmoe High School will all go-on to be doctors and lawyers.
People are not the same and neither are the oils, despite the same identical certs stamped to them.
Keep Your Pistons, Valves & Injectors Clean
19 Hyundai Santa Fe 2.4 GDI
20 Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Plat. 5W30 / AC Delco PF1127 Ecores
04 Chev Colorado Napa Syn 0w20 & K&N
Re: Ford 1.5 GDI Turbo Engine with 10.1 Compression Ratio [Re: Triple_Se7en] #5115685 05/25/19 06:15 PM
Jerry
I do 5000 mile oil changes the GDI engines are nasty. I want the best oil for my cars and don't mind paying a little extra for the oil because i plan on keeping them for the long term.
Jerry
Re: Ford 1.5 GDI Turbo Engine with 10.1 Compression Ratio [Re: tdi jerry] #5115697 05/25/19 06:27 PM
R
Rand Offline
R
I like pennzoil platinum 5w30 it meets api SN plus, Chrysler ms-13340, and dexos 1 gen 2, all important for GDI or Turbo GDI engines.
it is also around $23 for 5 quarts and frequently has a $10 mail in rebate.
Re: Ford 1.5 GDI Turbo Engine with 10.1 Compression Ratio [Re: tdi jerry] #5115700 05/25/19 06:31 PM
O
oil_film_movies Offline
O
You are picking an advanced synthetic, no doubt its good. They do use some PAO, with possibly GTL GroupIII+ in there, with Infineum anti-oxidants, it is the real thing. Main difference between your oil choice and cheaper synthetics would be how much piston deposits happen over many miles. Wear numbers are going to be similar across most dexos1 Gen2 full synthetics like that.
One oil that does tell us some wear results is the excellent Castrol Edge gold jug, which says Sequence IVA is 15 microns ! That may be the best I've heard of, and beats Amsoil Signature Series published results.
Walmart has Castrol gold jug, and amazon. https://www.amazon.com/Castrol-Extended-Performance-Advanced-Synthetic/dp/B00IPS3GMI
For all we know, your M1 AP could give great Sequence IVA results too, just not advertised exactly.
You're OK using 5w30 instead of 0w20 since there is only about 12% difference in hot viscosity anyway. Not much, but some extra margin if you want.
Re: Ford 1.5 GDI Turbo Engine with 10.1 Compression Ratio [Re: tdi jerry] #5115721 05/25/19 06:56 PM
O
O
Might add that Mobil1 is coming up with a new oil in a few months that is called "M1 Turbo" that claims to score very well on the turbocharger coking test part of dexos1 Gen2. Thats not to say M1 AP won't also score very well on that same test, but for a turbo engine, it might be good to get something you know is exceptionally low on turbo bearing deposits.
Re: Ford 1.5 GDI Turbo Engine with 10.1 Compression Ratio [Re: oil_film_movies] #5115739 05/25/19 07:17 PM
I have heard that mobil 1 was coming out with the turbo formula but i have not seen any info on it.
Jerry
Re: Ford 1.5 GDI Turbo Engine with 10.1 Compression Ratio [Re: tdi jerry] #5115765 05/25/19 07:46 PM
double vanos Offline
Magnatec does pretty well in the UOA section here. Using it in both my ‘boosts with no trouble.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Ford 1.5 GDI Turbo Engine with 10.1 Compression Ratio [Re: tdi jerry] #5116103 05/26/19 08:35 AM
O
O
Mobil has the MSDS info out on it, and this formula uses less PAO than their EP & AP products, so not the long oil change interval, but maybe about as good for least turbo deposits than the more expensive flavors anyway:
[Linked Image]
Re: Ford 1.5 GDI Turbo Engine with 10.1 Compression Ratio [Re: oil_film_movies] #5116343 05/26/19 12:49 PM
L
LEADED Offline
L
Using 5W-20 Castrol Magnatec on 15 Fusion & 17 Escape great results . Ford dealership let me take my choice of Lube & Filter . Baldwin + Castrol proven products .
Re: Ford 1.5 GDI Turbo Engine with 10.1 Compression Ratio [Re: LEADED] #5116353 05/26/19 01:07 PM
O
O
Truth: You don't know you got "great results". Nobody can stand outside a car, use x-ray vision like superman, and tell us "wear, deposits, longevity" is best. ... It takes actual engineering results from real engine testing of the most premium formulations to begin to hope for "great results".
And, you chose Baldwin which has mediocre filtering performance compared to Fram Ultra, and even 2nd-place oil filters like M1 Extended oil filters.
You can say "I probably got average results"... based on your choices. Sorry, just the truth here.
Re: Ford 1.5 GDI Turbo Engine with 10.1 Compression Ratio [Re: tdi jerry] #5116373 05/26/19 01:37 PM
2
209paulc Offline
2
I'm 12k miles into my a second 20K OCI using Mobil 1 5w20 AP.....this engine is extremely easy on oil!
2016 Ford F150 2.7L Ecoboost 78k Miles
Delo 400 SDE 15w-40 & Archoil 9100 10k OCI
Page 1 of 3 1 2 3
