Any sellers on amazon for Honda A02?
by BTLew81. 07/18/19 03:44 PM
First SMR (MMR) slated to be built at Chalk River
by OVERKILL. 07/18/19 03:31 PM
Torque Specs for 2004 Dodge Ram transfer case
by diyjake. 07/18/19 02:15 PM
OAT ad NOAT
by CCI. 07/18/19 02:06 PM
30 years clean & sober today.
by Papa Bear. 07/18/19 02:03 PM
What is high output AC?
by Fitz98. 07/18/19 12:45 PM
Killed my receiver
by Quattro Pete. 07/18/19 12:35 PM
I did it! Put Straight HD30 in the PSD...
by racin4ds. 07/18/19 12:34 PM
Bobcat S630 engine oil
by Spdfrk1990. 07/18/19 12:09 PM
737 max... what now?
by Tdog02. 07/18/19 11:46 AM
Picked up a Hyundai oil filter from WM
by mclasser. 07/18/19 11:29 AM
Mobil1 20w50 Vtwin in a tuff torq K61
by gman2304. 07/18/19 10:47 AM
4t outboard W rating question
by 1978elcamino. 07/18/19 10:27 AM
Top three based on known specs.
by sloinker. 07/18/19 10:24 AM
Harbor freight 25% coupon
by Fitter30. 07/18/19 10:11 AM
Going to try longer OCI.
by mctmatt. 07/18/19 10:06 AM
diagnosing a/c problem
by matrass. 07/18/19 09:49 AM
Shaz, Grousebeater, RoyD, clonis, golddots
68699 Registered Users
112 registered members (Astro_Guy, 1978elcamino, alchargo, bdcardinal, aquariuscsm, ad244, 10 invisible), 2,184 guests, and 28 spiders.
Topics292,035
Posts5,015,709
Members68,699
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
Transmission Pan Gasket? #5116019
05/26/19 07:12 AM
05/26/19 07:12 AM
TX-Texas
mctmatt Offline OP
mctmatt  Offline OP
TX-Texas
Did a pan drop yesterday on my 07 flex fuel Impala. Put in 7 quarts of Castrol Dex VI along with Lubriguard Red and I think the Impala appreciated it. I exchanged the filter with a Hasting premium but the rubber gasket seemed very flimsy and was difficult to work with . Curiouser what gaskets others prefer be it rubber, cork, or whatever form you like.
Re: Transmission Pan Gasket? [Re: mctmatt] #5116025
05/26/19 07:18 AM
05/26/19 07:18 AM
Suburban Washington DC
atikovi Offline
atikovi  Offline
RTV. Superior to any gasket you can use.
Re: Transmission Pan Gasket? [Re: mctmatt] #5116083
05/26/19 08:18 AM
05/26/19 08:18 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I use a gasket and this: High Tack It has never let me down, and gasket removal for future pan drops or filter changes are very easy. I was never a big fan of RTV, unless it had to be used as a last resort. Opinions vary.
God Bless Our Troops
Re: Transmission Pan Gasket? [Re: atikovi] #5116091
05/26/19 08:26 AM
05/26/19 08:26 AM
WA
Mad_Hatter Offline
Mad_Hatter  Offline
WA
What he 🖕said. I just did my valve covers with permatex ultra black and zero leaks.
Re: Transmission Pan Gasket? [Re: mctmatt] #5116123
05/26/19 08:53 AM
05/26/19 08:53 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
If this is the 4T65E the best gasket is the reusable one you took off, you can reuse that one a few times. The floppy rubber ones with the filter kits are not very good, the OE is rubber coated steel. RTV is my least favorite gasket material, I don't use it for much anymore, it is inferior to a physical gasket in almost every application.
The last time I used it was for the intake ends on a GM 3400. If a gasket is available I use it with a little High Tack Demarpaint mentioned.
Re: Transmission Pan Gasket? [Re: mctmatt] #5116129
05/26/19 08:59 AM
05/26/19 08:59 AM
Canada
nobb Offline
nobb  Offline
Canada
RTV is only for stuff you never want to take off ever again. For something like a transmission pan where you want to service regularly, then you'll want to go with a gasket.
Re: Transmission Pan Gasket? [Re: Trav] #5116138
05/26/19 09:12 AM
05/26/19 09:12 AM
TX-Texas
mctmatt Offline OP
mctmatt  Offline OP
TX-Texas
Trav just to let you know I did reuse the OEM gasket that was on the pan as it was still in good shape and much easier to work with when laying under the car trying to line up and bolt in the pan, RTV I would think make that difficult keeping the pan aligned without messing up what you applied.
Re: Transmission Pan Gasket? [Re: Trav] #5116139
05/26/19 09:12 AM
05/26/19 09:12 AM
NY
demarpaint Offline
demarpaint  Offline
NY
thumbsup
Re: Transmission Pan Gasket? [Re: mctmatt] #5116144
05/26/19 09:19 AM
05/26/19 09:19 AM
WA
Mad_Hatter Offline
Mad_Hatter  Offline
WA
Take one of the bolts to your local hardware store and find a bolt or threaded rod with the same pitch and diameter. The idea is to make 2 or 3 lugs to put in the pan holes. You may need a hacksaw and file to deburr. Once you put the lugs in, put the pan back on and go around in a star pattern hand tightening bolts, once you get to one of the lugs you put in, take it out w/pliars and replace it with the bolt.
This is how I put my oil pan on using gasket maker, laying on my back under the car. Easy peasy, lemon squeezy
Re: Transmission Pan Gasket? [Re: mctmatt] #5116145
05/26/19 09:19 AM
05/26/19 09:19 AM
Apple Valley, California
Chris142 Offline
Chris142  Offline
I like the gaskets that are some sort of compressed cardboard. Never had one leak in 30+ years of using them. Make sure to beat the pan straight if needed.
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: Transmission Pan Gasket? [Re: atikovi] #5116151
05/26/19 09:26 AM
05/26/19 09:26 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Never use RTV for a transmission pan gasket. Once the excess is squeezed out, it will wind up caught in the filter. Any impurity on the surfaces and that RTV won't stick. Good luck if you ever had to tweek the pan bolts, it won't work. Best bet is get an OEM gasket, it likely will be reusable.
The "thinking" man's friend.
Re: Transmission Pan Gasket? [Re: Lubener] #5116164
05/26/19 09:42 AM
05/26/19 09:42 AM
WA
Mad_Hatter Offline
Mad_Hatter  Offline
WA
Originally Posted by Lubener
[quote=atikovi]RTV. Superior to any gasket you can use.
Never use RTV for a transmission pan gasket. Once the excess is squeezed out, it will wind up caught in the filter. Any impurity on the surfaces and that RTV won't stick./quote]
Not if you a) don't over apply and b) let it cure for 24hrs before adding fluid and c) use a wire brush and brake cleaner. It's not like Niagra falls in your transmission or as if you have little gnomes in there hammering away. Once that stuff sets, it ain't going anywhere. And Permatex actually makes an anaerobic gasket maker that comes off relatively easy, where nothing more than a steady hand and a putty knife gets it open. It's specifically designed for use on oil/transaxle pans where servicing is required.
The nice advantage of a set in place gasket maker is it will fill in any undulations or surface imperfections in the pan, something preformed can't do.
Re: Transmission Pan Gasket? [Re: mctmatt] #5116197
05/26/19 10:13 AM
05/26/19 10:13 AM
MI
doitmyself Offline
doitmyself  Offline
MI
Nobody mentioned Felpro gaskets. Besides a quality OEM one, Felpro tranny gaskets tend to be very stout. They are made of a very dense composite rubber material and come packaged flat in a box. I prefer a gasket in most situations of repair work.
Re: Transmission Pan Gasket? [Re: Mad_Hatter] #5116218
05/26/19 10:38 AM
05/26/19 10:38 AM
Trav Offline
Trav  Offline
Who has 24hrs to leave it? That would really jam up the works if you work on multiple cars a day.
Re: Transmission Pan Gasket? [Re: Trav] #5116225
05/26/19 10:46 AM
05/26/19 10:46 AM
The low country, SC
RyanY Offline
RyanY  Offline
The low country, SC
^this.
I always use OEM gasket if available, or Felpro if the OEM price is too high. Both are top notch. Other brands may be fine but rarely much lower price than felpro. I would consider RTV only as a last resort, for the reasons mentioned above.
2007 Cadillac CTS 3.6L >123k miles (Valvoline synthetic HM + ACDelco PF2129G; Maxlife ATF)
2012 Honda Odyssey EX-L >99k miles (Pennzoil Platinum 5W-20 + STP XL; Pennzoil Platinum LV ATF)
Page 1 of 4 1 2 3 4
