Originally Posted by ChrisD46
Through various threads here an "HTHS 3.0 minimum reference" is stated as the base line minimum for engine protection . That would then seem to render HTHS readings below 3.0 (i.e. 2.7) to be inferior or at least less than desirable in engine protection . Perhaps stated another way : "What makes an HTHS of 2.7 less desirable than an HTHS of 3.0 and above ? ... Are their tests of HTHS 2.7 and HTHS 3.0 run side by side in the same temp , load , RPM , etc. conditions that show a clear difference in protection ?
Well, as you know, HTHS is pretty much the true measure of how much oil is actually flowing through where it is supposed to go at temperature and when it is hotter than blazes outside etc. The synthetics don't shear down. This site is cool and all, but it is still comprised of humans, sometimes, experts! Source: Them - that have their own individual attitudes and other things towards brand, how to measure oil, how to prop up their own oil, how to tear other oils down, ..in some threads, good base stocks make the oil. In other threads, they then don't matter.
If the HTHS is consistent with the SAE grade it says on the engine cap for your car then you should be great, and the rest is just healthy discussion in a good spirit and not nasty bickering about what might not even be applicable law.. the HTHS of an oil that meets the grade supposed to be in the car more than likely specified in something such as 5W-20 is not a disqualifier of that oil.
In conclusion, the minimum HTHS of a 5W-30 is 2.9, so having an oil with an HTHS 3.0 is probably indicating some kind of sweet spot of a Thick 20 if you wanted to say, I was not aware of the statement people prefer an HTHS of 3.0 although I can see why that would be attractive. Would have to indicate that it is all relative, as to your post.
