Originally Posted by oil_film_movies
Originally Posted by 08z06
... amsoil acd 10w30/sae30... I hope It dont hurt anything!
Amsoil says it's SL and ACEA A3/B3, so its good for gasoline engines, not just diesel. HTHS is high, but not excessive, at 3.6. NOACK is about the best I've ever seen at 4.2. ..... This is great oil, just not for very cold days in your OH (don't try starting the vehicle below 32F too often with any 10w oil if you can help it).
I see many owner manuals recommending 10W down to 0F and recently someone posted the specs that is good down to -13F.
Curious where you got the 32F?
Edit:
From @weasley:
"For CCS testing, a 5W has to pass at -30°C (-22°F) and a 10W at -25°C (-13°F).
For MRV, the 5W must pass at -35°C (-31°F) and the 10W at -30°C (-22°F).
Let's also remember that for MRV, the passing viscosity is the same - ie the oil must be For CCS the viscosity differs by grade, so a 5W must be <6,600 cP at -30°C but a 10W needs only be <7,000 cP at -25°C (so it can be thicker and warmer)."
