Bruce Crower Passes
by 02SE. 07/20/19 12:30 AM
Toyota YZZA1 Filter, 9,958mls
by edyvw. 07/20/19 12:06 AM
Chevron Supreme 5w30 Noack?
by Whammo. 07/19/19 11:56 PM
Injector sleeves in 7.3 Powerstroke w/ 6 sp MT
by Earls1st. 07/19/19 11:32 PM
Which 0W20 to slow use
by lukejo. 07/19/19 11:09 PM
2012 Camry suspension question
by lukejo. 07/19/19 11:03 PM
Opinions on manufactured homes
by ram_man. 07/19/19 10:50 PM
NGK Ruthenium HX
by David1. 07/19/19 10:21 PM
Royal Purple Filter Mileage Rating
by JerryBob. 07/19/19 09:53 PM
what brand of filter is this?
by ctwhitechin. 07/19/19 09:45 PM
VW Amorak truck
by AZjeff. 07/19/19 09:25 PM
New Honda Super Cub - leaking oil
by Lawn_Care. 07/19/19 08:55 PM
Loc-n-lube
by rideon. 07/19/19 07:54 PM
Humidity thread follow-up... phew!
by 14Accent. 07/19/19 06:55 PM
NEW FEDERATED LF651F FILTER CUT OPEN
by 53' Stude. 07/19/19 06:39 PM
Brake Job @ 26K On My GLC43
by 2015_PSD. 07/19/19 06:25 PM
New Scanner Autel MK808BT
by another Todd. 07/19/19 06:20 PM
Stonehunter, ctwhitechin, gwandless, Philippe1988, ChiefDaBooty
68712 Registered Users
18 registered members (EricBeau, Duffyjr, edyvw, Dylan1303, A_Spruce, anndel, 3 invisible), 619 guests, and 24 spiders.
Topics292,124
Posts5,017,199
Members68,712
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: Rounded off oil drain bolt - How to remove? [Re: spk2000] #5115500
05/25/19 03:24 PM
05/25/19 03:24 PM
NJ
JLawrence08648 Offline
NJ
large Stud extractor
Re: Rounded off oil drain bolt - How to remove? [Re: spk2000] #5115504
05/25/19 03:28 PM
05/25/19 03:28 PM
out there
spasm3 Offline
spasm3  Offline
out there
I would try a 12pt hammered socket first. ( don't bend the pan though.)
Then a large enough vise-grip or small pipe wrench.
If above does not work , mig weld a nut on it.
13 elantra 78k 5w30 synpwr
17 mazda cx-5 12300 miles m1 0w30
Re: Rounded off oil drain bolt - How to remove? [Re: spk2000] #5115515
05/25/19 03:35 PM
05/25/19 03:35 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
I had this happen on my Subaru. I used med sized vise grips. It was soft metal and they grabbed nicely. The reason they rounded it off. Used to be 17mm IIRC then they went to 14 MM but with the same large bung thread.
I was going to get a grinder wheel on a small E- Drill and grind it down to the next smaller size.
I bet the vise grips may work. Hammer on it. The Impact loosens it up
2019 VW Jetta S 6MT OCI#0 5033mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#7 52665mi-Castrol GTX Magnatec 5W20 + SOA Filter
Re: Rounded off oil drain bolt - How to remove? [Re: supton] #5115521
05/25/19 03:39 PM
05/25/19 03:39 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted by supton
I wonder if, if you lack tools for this, if it's just not easier to pay a mechanic to do an oil change, with fair warning to him.
Bring him a new drain plug to install.
Make him bring you the old one.
Re: Rounded off oil drain bolt - How to remove? [Re: spk2000] #5115539
05/25/19 03:58 PM
05/25/19 03:58 PM
NY
2dogs Offline
2dogs  Offline
NY
Re: Rounded off oil drain bolt - How to remove? [Re: spk2000] #5115553
05/25/19 04:12 PM
05/25/19 04:12 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
I used a left hand drill bit to extract a bolt before, easy enough for a steady hand.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 111K Frankenbrew, WIX 57173 (4 sale)
04 YZF-R1 20K Frankenbrew 20w50ish, XG7317
14 RX450h 41k Idemitsu 0w20, WIX 57047
18 RAM 3500 1k VWB 15w40, DBL7349
Re: Rounded off oil drain bolt - How to remove? [Re: KrisZ] #5115566
05/25/19 04:21 PM
05/25/19 04:21 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Originally Posted by KrisZ
I would use one of these, provided there is room. Tightens as you apply torques so you know it will not let go of the bolt.
[Linked Image]
Large vice grips might also work, but you have to make sure they are on square and very tight, otherwise you will mingle the bolt even more.
This
2015 F150 2.7
2018 F350 6.2
Re: Rounded off oil drain bolt - How to remove? [Re: 2dogs] #5115574
05/25/19 04:28 PM
05/25/19 04:28 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Originally Posted by 2dogs
+1 That is what I would use first, the HF should be good enough for a couple of uses. A better quality tool will last longer but at least the HF goes to 19mm.
Edit: Never mind I see you already tried them, go with the pipe wrench or Cobra's.
Re: Rounded off oil drain bolt - How to remove? [Re: spk2000] #5115634
05/25/19 05:27 PM
05/25/19 05:27 PM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Larger vise grips and make them super-tight to close.
19 Hyundai SantaFe 2.4GDI Castrol Edge 5w30 / NAPA Mann-Hummel filter / 6oz Liqui-Moly Treatment
04 Colorado 3.5 Castrol Edge 0W40 Euro & K&N filter
03 Malibu 3.1 QS / Valv Syn 5w30 mix Fram EG filter
Re: Rounded off oil drain bolt - How to remove? [Re: spk2000] #5115637
05/25/19 05:29 PM
05/25/19 05:29 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
10 or 12 inch Knipex Cobras. Make sure the lower jaw is on your right side.
Re: Rounded off oil drain bolt - How to remove? [Re: spk2000] #5115732
05/25/19 07:11 PM
05/25/19 07:11 PM
MN
oil_film_movies Offline
MN
Re: Rounded off oil drain bolt - How to remove? [Re: spk2000] #5115767
05/25/19 07:47 PM
05/25/19 07:47 PM
California
OnTheRocks Offline
OnTheRocks  Offline
California
You will need a special socket for rounded off fasteners. 2nd consideration is why it's rounded off. Did someone use an impact wrench? Then it's pounded on, and rounded off. Who knows what conditions the threads might be in.
Get a new magnetic drain plug and the washer. You may also need a thread repair kit by the time you get this removed.
[Linked Image]
[Linked Image]
Re: Rounded off oil drain bolt - How to remove? [Re: spk2000] #5115771
05/25/19 07:51 PM
05/25/19 07:51 PM
Suburban Washington DC
atikovi Offline
atikovi  Offline
Leave it alone and suck the oil out the dipstick tube from now on.
Re: Rounded off oil drain bolt - How to remove? [Re: spk2000] #5115787
05/25/19 08:13 PM
05/25/19 08:13 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
The Irwin Bolt Grips that OnTheRocks posted.
Use a short handled sledge to whack the right one on. It will get that plug out, without fail.
Re: Rounded off oil drain bolt - How to remove? [Re: spk2000] #5115961
05/26/19 01:51 AM
05/26/19 01:51 AM
California
OnTheRocks Offline
OnTheRocks  Offline
California
If you raise the front end of your vehicle, and support with jack stands, you may not be high enough off the ground. Crawling under, with less than 12", does not allow you to be in a good position, or use longer tools with more leverage. Sometimes, reach and access is limited when you're trying to use power tools. When you have the vehicle up on a lift, you can stand under it. This allows you to plant your feet in a wide stance, get your body behind the tool, or maybe use power tools. Think about an impact tool. You may also need some sort of universal joint to give you the correct angle.
I would also worry about the condition of the threads after you get the drain plug out.
Page 2 of 2 1 2
