Originally Posted by oil_film_movies
Originally Posted by LEADED
As it was explained to me B1 was implemented to address Timming chain wear issues. Ford PCMO on most , uses a semi synthetic blend only API SN .
No. -B1 just has the SN+ LSPI test, thats all, as timing chain wear is still a year or two away when the upcoming GF-6 happens.
The WSS Ford spec family has never been much to write home about.
Originally Posted by tiger862
Originally Posted by dave1251
No the B1 is API SN+ and DEXOS 1G2 is a more stringent spec .
According to who.
According to anybody that knows this stuff.
If GM spec is toughest one to meet don't you think Ford or any major automaker would say in manual ok to use GM Dexos spec for warranty.
No, Ford avoids the GM dexos1 and dexos2 specs due to proprietary intellectual property legal issues and corporate rivalry. Ford
should unify on GM's better dexos specs, but won't for obvious reasons.
Educate yourself by reading this:
https://www.aftonchemical.com/Afton/media/PdfFiles/Afton-Chemical-Spec-Handbook-September-2019.pdf
So what you are saying is an oil that is GM Ford, Chrysler specs as well as any other spec is just GM spec? No it is an universal oil intended to be used in multiple vehicles. If GM spec oil is so good why not get AC Delco oil as this is true Dexos with not having to meet other manufacturers spec.
