NAPA Presents: A Concert Behind Prison Walls
by GumbyJarvis. 07/15/19 11:35 PM
2019 Dodge Ram Warlock
by buster. 07/15/19 11:04 PM
2014 VW Jetta - transmission service
by gregk24. 07/15/19 10:09 PM
I wish my Camaro was this color!
by clinebarger. 07/15/19 09:19 PM
2019 Crosstrek 2500 Mile Review
by Al. 07/15/19 09:00 PM
Panasonic Cockpit Radio
by dishdude. 07/15/19 08:36 PM
97 Honda Civic won't crank
by Merek. 07/15/19 08:22 PM
Farmall alternator
by chilson450. 07/15/19 08:19 PM
30K and Hyundai ATF?
by flinter. 07/15/19 07:43 PM
'03 Suburban Quirks
by A_Spruce. 07/15/19 06:51 PM
new clutch shop $1500
by sirgerman. 07/15/19 06:45 PM
Pain in the rear transmission service...
by 14Accent. 07/15/19 06:38 PM
Longer Canister Fram Ultra Part #?
by gwarrior4u. 07/15/19 06:27 PM
Rats! I need bodywork
by PeterGreen. 07/15/19 06:15 PM
ATF-4?
by WillB. 07/15/19 05:58 PM
Rotunda AOD Transmission Rebuild Tool Kit
by TooManyWheels. 07/15/19 04:44 PM
No more Champion plugs for me LOOK!
by bchannell. 07/15/19 04:11 PM
Lucas_Jones, cobb_cruiser, robinjeter, SpicySenpai, Weatherdriver77
68669 Registered Users
30 registered members (AdRock, Astro14, Bailes1992, c502cid, burla, BlueOvalFitter, 5 invisible), 758 guests, and 27 spiders.
Topics291,925
Posts5,013,440
Members68,669
Most Online2,967
Mar 10th, 2019
Hydro Gear G730 trans shudder #5112165
05/22/19 09:22 AM
05/22/19 09:22 AM
Franklin, TN
Fastzntn Offline OP
Fastzntn  Offline OP
Franklin, TN
Checking to see if anyone ran into a similar problem as I’m having.
Last weekend I mowed with my Craftsman Garden Tractor (G5000 series with 24 hp Briggs, hydro gear g730 trans). Very hilly yard, about 215 hours on the tractor.
Problem I’m noticing- full power, blades engaged, going up steep hills, the tractor will vibrate/shudder and lose forward speed. If I nurse the pedal slowly it happens less but still happens. Engine pitch/speed stay the same, so I believe it’s something after that.
Anyone have something similar happen? I’m on the road but want to start diagnosing as soon as I get home. The grass is growing fast in TN!
Re: Hydro Gear G730 trans shudder [Re: Fastzntn] #5112233
05/22/19 10:21 AM
05/22/19 10:21 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Is there enough oil in the trans?
2015 F150 2.7
2018 F350 6.2
Re: Hydro Gear G730 trans shudder [Re: CT8] #5112241
05/22/19 10:26 AM
05/22/19 10:26 AM
Franklin, TN
Fastzntn Offline OP
Fastzntn  Offline OP
Franklin, TN
It’s one of those sealed “never needs maintenance” deals (not that I agree with never needs maintenance). I can attempt to check via the plate that I assume the factory uses to fill through. Have not noticed oil drips or evidence of seepage on the trans case.
Re: Hydro Gear G730 trans shudder [Re: Fastzntn] #5112265
05/22/19 10:46 AM
05/22/19 10:46 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
I would try changing the oil. Seems like the G730 is serviceable:
https://www.youtube.com/watch?v=3u97bb-GKFA
2000 Jeep Cherokee 4.0L (182k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (43k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Hydro Gear G730 trans shudder [Re: Fastzntn] #5112397
05/22/19 01:19 PM
05/22/19 01:19 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Could it be the drive belt slipping? Cooling fan intact? The G730 is the Cadillac of HydroGear's lineup for garden tractors. Like said, it should have a spin on filter and a relatively easy means to drain/fill the oil. I'd check the belt, tensioner/idler first, then make sure the transaxle isn't caked with debris and the fan is good. The oil shouldn't be horrible at ~200hrs, but this would be a good time to change it and the filter.
2017 Ram 1500 4x4, 3.6L.
2016 Nissan Quest SV (Babe magnet IV)
2015 Nissan Versa 1.6 S
Re: Hydro Gear G730 trans shudder [Re: Fastzntn] #5112520
05/22/19 03:22 PM
05/22/19 03:22 PM
Prospect, KY
spk2000 Offline
spk2000  Offline
Prospect, KY
Just changed mine out in my Snapper GT300 which is a 22HP Briggs and has a K57 transmission. Most say not serviceable but you can pop top vent cap off and vacuum fluid out. I was replacing with Mobil 1 15W50. Works great for a while but if you have a steep hill will likely break down. My hill is really too steep for the mower but it works so I use it. Had a guy with commercial mower tell me he would not try it on his zero turn. Main issue is not getting it out but getting the new fluid back in. I would ride it around a little bit to mix and heat fluid up a little maybe 5-10 minutes. I can always tell when the Mobil 1 breaks down because my mower starts climbing slower and eventually will not go up the hill. I can then back up and go other direction which is a much gentler slope. I am trying the Amsoil Hyrdostatic 20W50 fluid and have heard great things about it. Just mowed today for the first time and so far could not tell a difference which may not be a bad thing. At some point I will post something on BITOG about the durability vs Mobil1 but not enough time on it yet.
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Hydro Gear G730 trans shudder [Re: Fastzntn] #5114726
05/24/19 04:34 PM
05/24/19 04:34 PM
Franklin, TN
Fastzntn Offline OP
Fastzntn  Offline OP
Franklin, TN
Not great news on the mower......
Changed fluid and filter (GTX 20w50/OEM filter). Added 3 quarts per spec. Started mowing and it seemed to be doing ok. Hit the hills again and now it’s worse. Lots of jerking and shudder, vibration, and it sounds like rattling coming from the trans. Barely made it back up the driveway and it’s pretty much unusable for mowing.
I did check the belt tension, linkages, etc while I was changing fluid. Pretty sure the trans is toast at this point.
Re: Hydro Gear G730 trans shudder [Re: Fastzntn] #5115393
05/25/19 01:16 PM
05/25/19 01:16 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Sorry to hear that! When you changed the oil, how did the drained oil look? I've not heard of one of these G730s failing. 215hrs is nothing. Just for reference, I looked up replacement units online. $1000. I'd email hydrogear just to see if they could help or have suggestions. I know there's various youtube videos on rebuilding hydro transaxles. Doesn't look too bad.
Re: Hydro Gear G730 trans shudder [Re: JTK] #5115727
05/25/19 07:06 PM
05/25/19 07:06 PM
Franklin, TN
Fastzntn Offline OP
Fastzntn  Offline OP
Franklin, TN
The oil was brown when it came out, didn’t appear sparkly and didn’t smell burned.
I just did the same thing on a replacement and saw $1k as well. If it came down to that I’d lean towards buying a replacement mower. Simply because this one has been marginal for my hilly yard. But if I missed something or there’s an easier fix I’d be ok with keeping this one going.
Good call on contacting hydro-gear, I’ll do that and see what they say.
Re: Hydro Gear G730 trans shudder [Re: Fastzntn] #5120968
05/31/19 07:10 AM
05/31/19 07:10 AM
MI
anthonym6 Offline
anthonym6  Offline
MI
Check to make sure none of the mounting bolts are broken. Might not be the issue, but my zero turn had broken a bolt allowing one of the Hydro Gears to move excessively which made it shudder and cause the mower to buck under the right conditions. Normal mowing it wasn't an issue.
Re: Hydro Gear G730 trans shudder [Re: Fastzntn] #5123999
06/03/19 12:20 PM
06/03/19 12:20 PM
Franklin, TN
Fastzntn Offline OP
Fastzntn  Offline OP
Franklin, TN
Everything led back to an internal transaxle problem unfortunately. Could not justify putting more money into a tractor that’s not designed to tackle my yard (6 acres, half of it cleared, slopes, ruts, etc). While it had enough power, the frame flexed a lot, it got stuck several times due to being traction limited even in seemingly easy to navigate sections of the yard. A small portion of exposed root was enough to cause a problem if there was any slope.
So I bought a John Deere 1023E grin
Spent about 4 hours working with it over the weekend, and I should have had something like this from the start.
Re: Hydro Gear G730 trans shudder [Re: Fastzntn] #5124076
06/03/19 01:23 PM
06/03/19 01:23 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
JD 1023E!!!
Talk about movin' on up in the world! Congrats on that. I'd be looking forward to using it.
Sounds like the right move if you toasted about the best transaxle HG makes in that short of time, you needed a machine built entirely better.
Re: Hydro Gear G730 trans shudder [Re: Fastzntn] #5124384
06/03/19 06:11 PM
06/03/19 06:11 PM
Central US
bobdoo Offline
bobdoo  Offline
Central US
For everyone who owns a hydrostatic transmission, here's some tips.
Go SLOW up steeper hills. There's a LOT more heat and wear generated when the swash plate is at a high angle (giving high ground speed).
Keep the transmission CLEAN. Grass, straw, dust and dirt insulate the tranny. High heat breaks down the oil
Change the oil (as much as you can). In non-servicable trannies, you can remove the whole rear axle, and turn it upside down to drain it. Make sure you get an accurate measure of what came out. There are videos out there to help. The small tractor forums are a fount of knowledge. Drain from the top if you can, using a small diameter tube. Check diagrams online to find out how to snake the tube lower in the tranny, if that's possible. (Along those lines, I wonder if it would be useful to overfill, operate at low ground speed to mix old and new, then drain more out?)
I have put Liqui Moly in my transmisson, in the hopes that there's some added protection from all the sliding parts.
Re: Hydro Gear G730 trans shudder [Re: Fastzntn] #5125224
06/04/19 03:33 PM
06/04/19 03:33 PM
Southeast
meep Offline
meep  Offline
Southeast
^^^ an oil extractor made easy work removing used fluid from my entry level Ariens ZTR. IIRC is was around a quart each?
2018 F150
2015 crv (wifey!)
Re: Hydro Gear G730 trans shudder [Re: Fastzntn] #5125267
06/04/19 05:01 PM
06/04/19 05:01 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
That's the thing with this G730 drive. It's easy to do a D/F on and has a spin on filter.
