Pennzoil GF-6 & Low Viscosity Q&A
Click here to participate in the Pennzoil Q&A
Donaldson 550794, 3.81$ Each SALE
by GumbyJarvis. 06/26/19 03:38 AM
2019 JD Power Initial Quality
by wemay. 06/26/19 01:42 AM
Legal matter stormwater pipe, no easment
by expat. 06/26/19 12:08 AM
2019 Yamaha FX Cruiser HO
by jtwrace. 06/25/19 11:14 PM
The Mysterious Mopar SAE 5W-20?
by John344. 06/25/19 10:24 PM
90915-YZZD3 particle count - ISO code 24/23/15
by newtoncd8. 06/25/19 10:12 PM
Pep Boys syn oil sale. . . $15.98 after rebate
by Robster. 06/25/19 09:47 PM
How to contact Amazon customer service?
by mjk. 06/25/19 09:10 PM
Leupold screws
by buck91. 06/25/19 08:51 PM
2004 Lexus RX330, 5659mi, Pennzoil Platinum HM 5W30
by newtoncd8. 06/25/19 07:38 PM
Milesyn 5w/20, 5500 miles, 2007 Mazda6 2.3L
by RayCJ. 06/25/19 07:12 PM
Mystik JT-6 Green tube @ Tractor Supply
by K20FA5. 06/25/19 06:58 PM
Saw a '53 Chevy this morning
by fdcg27. 06/25/19 06:20 PM
Motorcraft Mercon V opinions?
by Vigilant. 06/25/19 05:28 PM
New Personal Best MPG
by Kjmack. 06/25/19 05:01 PM
DuraMAX Synthetic Oil?
by Torino117. 06/25/19 04:54 PM
Battery Cables!
by NYEngineer. 06/25/19 04:35 PM
Brake Rotors
by WyrTwister. 06/25/19 04:00 PM
Beason, Toddstephens22, Macky, javadog, giwatcher
68488 Registered Users
36 registered members (2015Corolla, 2105stgvh, Bjornviken, Bailes1992, 53' Stude, 5 invisible), 645 guests, and 22 spiders.
Topics290,978
Posts4,996,271
Members68,488
Most Online2,967
Mar 10th, 2019
Redlines equivalent to RP HPS #5114537
05/24/19 12:23 PM
05/24/19 12:23 PM
Omaha
Ivoidwarranties Offline OP
Omaha
Long long story short, I know just enough about oil to come to BITOG to ask questions. Does Redline Oils have a line of oil that would be the equivalent to Royal Purples HPS line. I know it probably has mostly to do with additives but I don't know how to read the information about the oils.
I have used Redline in the past and would like to continue but my engine builder had me set up initially with RP HPS because he "liked the additives." If there was a Redline product that was similar, I'd switch to that.
Please and thank you. Any info will be appreciated.
Re: Redlines equivalent to RP HPS [Re: Ivoidwarranties] #5114543
05/24/19 12:27 PM
05/24/19 12:27 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Just use regular white bottle Redline if you are looking to use their products.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: Redlines equivalent to RP HPS [Re: Ivoidwarranties] #5114564
05/24/19 12:47 PM
05/24/19 12:47 PM
pa
benjy Offline
benjy  Offline
pa
Redline high performance oils are prolly better than any RP oils, use with confidence for sure
Re: Redlines equivalent to RP HPS [Re: Ivoidwarranties] #5114602
05/24/19 01:24 PM
05/24/19 01:24 PM
Des Moines, IA
Loi Offline
Loi  Offline
Des Moines, IA
I would use the Redline over RP. Redline has a good dose of molybdenum and they use ester base stocks. RP is known to shear easily.
'05 GDB STI
'16 VAB STI
Re: Redlines equivalent to RP HPS [Re: Ivoidwarranties] #5114622
05/24/19 01:41 PM
05/24/19 01:41 PM
WY
sloinker Offline
sloinker  Offline
WY
Red Line white bottle as noted or possibly Ravenol. It seems, and I may be wrong, that RP went away from high performance and is more a mainstream generic style oil nowadays.
https://www.ravenol.de/en/products/usage/d/Product/show/p/ravenol-rup-sae-5w-40.html
Re: Redlines equivalent to RP HPS [Re: Ivoidwarranties] #5114650
05/24/19 02:50 PM
05/24/19 02:50 PM
sonoma
burla Offline
burla  Offline
sonoma
What NOT to use in Redline ever, Professional-Series or Racing oil. Just two things that shouldn't be in your passenger car, Professional-Series is nothing special and racing oils are for race vehicles eventhough they have increased CA lrvrls over time to make them more user friendly. Just avoid those two.
What to use, High Performance line. I say that because they have had some bottle drama from time to time and sometimes Professional-Series and High Performance had the same bottle, in fact if you are somewhere that has old stock it would be either in a white bottle. Just make sure it if High Performance.
If your mechanic likes RP HPS additive package, he would like Redline's even more. The only thing that HPS has in higher concentration is mag, but redline has more calcium, so unless it is a di turbo there is literally no downside from HPS to Redline unless you think 2002 level zinc will harm your cats, which really doesn't happen. Redline has more aw/ep additives like zinc and moly and the base oil doesn't get any better then group 4/5, good for cold starts and high heat.
[Linked Image]
Re: Redlines equivalent to RP HPS [Re: Ivoidwarranties] #5114703
05/24/19 03:50 PM
05/24/19 03:50 PM
California
Direct_Rejection Offline
California
OP said HPS.
This has Synerlec.
White Bottle RL > Purple Bottle HPS RP.
2018 Tacoma 2.7L
PP 0W20
"GF-6 Ready"
@ 120k miles
Re: Redlines equivalent to RP HPS [Re: Direct_Rejection] #5114717
05/24/19 04:06 PM
05/24/19 04:06 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Originally Posted by Direct_Rejection
OP said HPS.
This has Synerlec.
How would you know that, technically? I mean a serious question, no one knows the exact base oil composition, and even if you did how would you compare them? From what little we do know they are completely different oils.
Plus neither one has any approvals or certifications so what basis do you use to compare the two?
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 418K
2000 Toyota ECHO, 281K
Re: Redlines equivalent to RP HPS [Re: kschachn] #5114736
05/24/19 04:44 PM
05/24/19 04:44 PM
California
California
OP said HPS.
This has Synerlec.
Technically, I would not know, so you are correct on that, Sir.
I would just say that in my humble opinion,
and in looking at the engine in OP's picture,
my personal preference would be Red Line.
I have used RP HPS 5W20 and found it to be a fine oil,
albeit with no data. Also, sidenote, I am currently using RP gear oil in my rear axle.
Regarding RL, I have used everything from 0W20 to 20W50,
in various applications, going back 35 years, and am a fanboy.
smile
2018 Tacoma 2.7L
PP 0W20
"GF-6 Ready"
@ 120k miles
Re: Redlines equivalent to RP HPS [Re: burla] #5114747
05/24/19 05:13 PM
05/24/19 05:13 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
This. I'd suggest HPS is a fine lube, but Red Line's mainstream line is already competing with HPS, not Royal Purple's API line, in the first place. In Red Line's product line, the ordinary white bottle would be the most suitable choice. There's no need to switch.
Plain, simple Garak.
Re: Redlines equivalent to RP HPS [Re: Direct_Rejection] #5114925
05/24/19 08:57 PM
05/24/19 08:57 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
I would completely agree with that, at least their website is a bit more technical and less bro truck than the other.
1994 BMW 530i, 242K
Re: Redlines equivalent to RP HPS [Re: Ivoidwarranties] #5115004
05/24/19 10:26 PM
05/24/19 10:26 PM
Omaha
Omaha
Thank you all for the input.
Re: Redlines equivalent to RP HPS [Re: Ivoidwarranties] #5115013
05/24/19 10:35 PM
05/24/19 10:35 PM
California
OnTheRocks Offline
OnTheRocks  Offline
California
You should call Redline. Tell them about your engine, and ask if they have something formulated. Then discuss the recommendation with your engine builder.
