ZF HP8 Transmission Servicing
by Joel_MD. 06/19/19 08:50 AM
HF flashlight recall = 5 dollar gift card
by 1978elcamino. 06/19/19 08:41 AM
Cam pics of 2007 Fusion
by tig1. 06/19/19 08:27 AM
LS Diff gear oil
by WyrTwister. 06/19/19 07:55 AM
2005 BMW 325i, 12,065 miles, Mobil 1 0W-40
by Toto. 06/19/19 07:50 AM
Mortgage Lenders, FHA Guidelines Question
by diyjake. 06/19/19 07:15 AM
rare AWD comparison test of CUVs on same tires
by madRiver. 06/19/19 07:08 AM
195/65R Yokohama Avid Ascend GT
by Marco620. 06/19/19 01:01 AM
New frontier 4.0 V6
by passgas55. 06/19/19 12:14 AM
Top 5 reliable, affordable car makers?
by Elkins45. 06/18/19 10:16 PM
Rear positive camber
by wing0. 06/18/19 09:44 PM
Odd vehicle / tags on I-70
by Marco620. 06/18/19 09:43 PM
Repainted bumper cover vs OEM
by DTS419. 06/18/19 09:37 PM
Sweet Ice Tea
by BlueOvalFitter. 06/18/19 09:30 PM
17 F150 6R80 ATF oil change
by MagneticFX. 06/18/19 08:49 PM
DTS419, chakir, 9J460, Petethedog, RenewableLubeBen
68429 Registered Users
83 registered members (1978elcamino, beanoil, atikovi, AlaskaMike, ad_infinitum, a2gtinut, 10 invisible), 1,933 guests, and 25 spiders.
Topics290,653
Posts4,990,397
Members68,429
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Need a high zinc oil #5114430
05/24/19 10:50 AM
05/24/19 10:50 AM
TN
tutermoe Offline OP
tutermoe  Offline OP
TN
Something for my 1977 350 flat tappet
thanks
Re: Need a high zinc oil [Re: tutermoe] #5114442
05/24/19 11:02 AM
05/24/19 11:02 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Is it a stock engine or has it been built ?
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Need a high zinc oil [Re: Char Baby] #5114451
05/24/19 11:12 AM
05/24/19 11:12 AM
TN
tutermoe Offline OP
tutermoe  Offline OP
TN
Mostly stock, a little bump in the cam
Re: Need a high zinc oil [Re: tutermoe] #5114470
05/24/19 11:25 AM
05/24/19 11:25 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Then it doesn't need a high ZDDP oil. Something like a Euro 5w-40/0w-40 would be more than adequate.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: Need a high zinc oil [Re: tutermoe] #5114474
05/24/19 11:26 AM
05/24/19 11:26 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
is there any technical evidence that a flat tappet engine requires elevated ZDDP after break-in?
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 418K
2000 Toyota ECHO, 281K
Re: Need a high zinc oil [Re: tutermoe] #5114478
05/24/19 11:28 AM
05/24/19 11:28 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I have heard Penn or Gibbs ( I think ) break in oil , recommended ?
Wyr
God bless
Re: Need a high zinc oil [Re: tutermoe] #5114483
05/24/19 11:30 AM
05/24/19 11:30 AM
Michigan
Buzzinhalfdozen Offline
Michigan
Grab some rotella and call it a day if you want increased zinc.
1999 Jeep Cherokee sport 4.0L
2015 Jeep Cherokee 3.2
2015 Ford F150 5.0
Re: Need a high zinc oil [Re: tutermoe] #5114529
05/24/19 12:14 PM
05/24/19 12:14 PM
Ohio
Dave Sherman Offline
Ohio
Rotella or Valvoline VR-1 would probably be fine.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: Need a high zinc oil [Re: tutermoe] #5114609
05/24/19 01:28 PM
05/24/19 01:28 PM
Balearic Islands , Spain
FordCapriDriver Offline
Valvoline VR1 10W-30 just to be on the safe side of things.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40
G40 Si-OAT coolant in both
Re: Need a high zinc oil [Re: tutermoe] #5114611
05/24/19 01:30 PM
05/24/19 01:30 PM
Los Gatos, CA
JeffKeryk Online content
JeffKeryk  Online Content
Los Gatos, CA
I use Rotella T 15w40 in my classics.
There are also speciality oils out there which are top notch.
I understand the Euro blends are a good choice as well.
Unless you have really high valve spring pressure, you should be fine.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Need a high zinc oil [Re: kschachn] #5114612
05/24/19 01:32 PM
05/24/19 01:32 PM
Some engines have high valve spring pressures even stock and will need a good dose of Zddp even after break in.
For example the engine in my Ford Escort, it's a SOHC flat tappet Hemi engine, the stock valve springs are 235lbs at peak lift, i therefore refuse to run anythign with less than 1000ppm of Zinc in it, preferably 1100-1300.
Re: Need a high zinc oil [Re: tutermoe] #5114668
05/24/19 03:15 PM
05/24/19 03:15 PM
Ceciltucky
Oldtom Offline
Oldtom  Offline
Ceciltucky
How about Amsoil Z-Rod? Pricey, but contains a lot of zinc and corrosion inhibitors for seldom driven classics.
Re: Need a high zinc oil [Re: tutermoe] #5114681
05/24/19 03:22 PM
05/24/19 03:22 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
An SB Chevy (unless radically built) shouldn’t need super high levels of zinc-a decent HDEO, combined with some Comp Cams break-in additive, or even Rislone zinc additive, should be plenty high enough. Hopefully you have a good aftermarket cam & lifters!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Need a high zinc oil [Re: tutermoe] #5114683
05/24/19 03:32 PM
05/24/19 03:32 PM
Brighton MI,
Rudy1999 250 Offline
Brighton MI,
TRC 15W40 PROSPEC III WITH MOLLY 1400 PPM OF ZINC
ALSO CEN-PE-CO HAVE HEARD IS GOOD STUFF.
A Salesperson/Problem Solver
Re: Need a high zinc oil [Re: tutermoe] #5114696
05/24/19 03:45 PM
05/24/19 03:45 PM
Georgia
RDY4WAR Offline
RDY4WAR  Offline
Georgia
Driven HR 10w-40 has 1400 ppm zinc, 1250 ppm phosphorus, a nice dose of moly, and a starting TBN of 10. It's $7.99/qt.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Page 1 of 3 1 2 3
