I got 1989 chevy 2500 it has RPO code G80. Is it a limited slip,posi traction, or a Locker? If it is one of those what is the difference between them?
What gear oil should I be using?
The Eaton Lockerquote:
The Eaton Locker…When the Three Most Important Words Are Traction, Traction, Traction
You ever had your drive wheel slip off the road and into some mud? Or maybe snow or ice? Makes it hard to keep it going in a straight line, doesn't it? Traction just disappears…
What about a boat ramp? Ever been in a situation where one side of the ramp is all wet and slippery while the other side is dry as a bone? With an open differential, all you'll do is spin the wheels. And, even 4-wheel drive doesn't do much good in that situation.
Well - surprise - there's a solution. The Locker. The Eaton G80 Locking Rear Differential. This automatic unit, available for rear drive and 4-wheel drive vehicles, makes traction problems a thing of the past. The Locker makes towing large boats and campers a breeze.
It gives you the freedom to wander far from the beaten path in search of the perfect fishing hole, campsite or picnic area. It delivers traction and inspires confidence even in the nastiest off-road terrain.
A Quick Look At How It Works...
We'll start by pointing out that the Locker is a speed sensitive design. That is, it reacts to wheel slip by sensing when one wheel is spinning substantially faster than the other.
So, when you're cruising along on clean dry pavement, the locker operates like any regular open differential.
But, as soon as wheel slip happens, going forward or reverse, the locker immediately kicks in. Here's how.
The differential is set up with a flyweight governor that responds to differences in wheel speeds, and disc packs that are mounted between the side gear and the case.
Whenever one wheel is spinning substantially faster than the other, the governor spins rapidly, causing the flyweight to open. That flyweight then catches on a latching bracket and the lockup process begins.
During lockup, a self-energized clutch system causes a cam plate to ramp against a side gear. This ramping action compresses those disc packs mentioned earlier. The ramping continues until both axles - and therefore both wheels - are spinning at the same speed. This is full lock, and it prevents any further wheel slip. (Note: Axle lockup can only occur at speeds below 20 mph.)
The entire lockup process takes about a split second, and is virtually unnoticeable by the average driver. When both wheels regain traction, unlocking occurs and things go back to normal.
Want to see it work from the inside? Click here
Where can I buy a mechanical locker?
The Eaton Locker is option code G80 Locking Differential on GM light trucks and SUV's. Go to Chevrolet, GMC, Cadillac or Oldsmobile websites for more information.
So, what could make it better?
How about giving the driver complete control of when and what gets locked? The ability to lock the front axle, the rear axle or both axles with the touch of a button? OK, now you're talking ELocker™ Differential, the Electronic Locking front and/or rear differential…
Yeah right! A friend of mine has a 95 K2500 (6.5TD) and his locker is anything but unnoticable. It SLAMS when it locks, which can suddenly kick the rear end of the truck out around a wet corner. I'll take Eaton's regular clutch-type limited slip any day...quote:
