Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
Another SCORE !!!
by GMguy84 - 06/06/20 02:24 AM
Is it just me...
by daves87rs - 06/06/20 01:26 AM
Total Repair Costs over 200,000 miles
by Palut - 06/06/20 12:08 AM
Vredestein will start making American-market specific tires
by slacktide_bitog - 06/05/20 11:33 PM
Fried plantain question
by aquariuscsm - 06/05/20 11:08 PM
Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
3Dperf, LouK2, Michael328i, tyman, Knot_A_Mekanik
71616 Registered Users
51 registered members (BeerCan, bernardch, BigGeo, 2009Edge, Amkeer, Best F100, 5 invisible), 1,072 guests, and 59 spiders.
Topics306,279
Posts5,289,455
Members71,616
Our Camry is back! #5114349 05/24/19 09:12 AM
T
tomcat27 Offline OP
T
Last summer my daughter drove our 2001 Camry 50 miles with a stuck thermostat. with poor judgement and bad advice, I pulled the head, had it planed, and re-assembled. yes, it was still blowing exhaust into the cooling system. I finally found some time and installed a reman engine in the car over the last week. It was almost easier to pull the engine than it was to pull the cylinder head. anyway, the car lives! only two problems: one of the core plugs, aka freeze plugs; was leaking. easy to fix. and now the car has a vibration/buzzing noise in either the engine or first half of the transmission. not sure what the cause is. did the remanufacturer fail to balance the rotating assembly? is there something askew with the balance shafts?? The remanufacturer used top quality parts: aisin/Toyota water pump and oil pump, OEM timing belt. not sure on the pistons, bearings, etc.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Our Camry is back! [Re: tomcat27] #5114395 05/24/19 10:12 AM
W
WyrTwister Offline
W
Sounds like you are going to have to seperate the engine & transmission . Manual or automatic ?
Wyr
God bless
Re: Our Camry is back! [Re: tomcat27] #5114409 05/24/19 10:27 AM
CT8 Offline
What is the Camry worth?
2015 F150 2.7
2018 F350 6.2
Re: Our Camry is back! [Re: CT8] #5114424 05/24/19 10:47 AM
T
tomcat27 Offline OP
T
It cost me less than $2k for the engine. The car belonged to mom originally. I don't mind spending more than it is "worth". the rest of the car is in great shape with no rust. what other options are available for $2k?
Re: Our Camry is back! [Re: WyrTwister] #5114427 05/24/19 10:48 AM
T
tomcat27 Offline OP
T
automatic. I could probably pull the engine with my eyes closed at this point.
Re: Our Camry is back! [Re: CT8] #5114444 05/24/19 11:05 AM
B
bubbatime Offline
B
About $500 scrap value. Not worth the time or effort to rebuild the engine, then pull the engine and put a reman engine in. Then have a wierd vibration that requires the engine to come out AGAIN. Should have sold the Camry and moved on to a newer used car. It almost never makes sense to put a new engine into a 18 year old car.
I have a 2010 Acura TSX that's reliable as all get out and could be purchased used for $2500 if I was selling it.
Re: Our Camry is back! [Re: tomcat27] #5114461 05/24/19 11:19 AM
K
KGMtech Offline
K
I would be checking the motor and transmission mounts. First try loosening the mount bolts, then drive the car forward 3-4 feet, then stop and go in reverse the same distance. This might shift the mounts back to their "preferred" resting position.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Our Camry is back! [Re: bubbatime] #5114464 05/24/19 11:21 AM
I
Imp4 Online Content
Online Content
I
Correct, but OP clearly stated that the vehicle had sentimental value because it belonged to his mother.
Here is the rare instance where it does make sense.
It is no longer a financial decision.
Re: Our Camry is back! [Re: bubbatime] #5114495 05/24/19 11:41 AM
The Critic Offline
That seems very low. I just did a check on craigslist and most of the 2010 TSX's were selling for between $6-$9K. Is your market really that much different?
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Our Camry is back! [Re: KGMtech] #5114510 05/24/19 11:50 AM
T
tomcat27 Offline OP
T
good suggestion. will do. I do actually recall that the rear mount was not in the same location, and someone else handled the trans mount. as far as was it "worth it" to fix the car? - I suggested to my wife multiple times that we scrap it. nope. no dice. sigh.
Re: Our Camry is back! [Re: tomcat27] #5114524 05/24/19 12:06 PM
Chris142 Offline
Sounds like the cooling system in the replacement was not well maintained.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Our Camry is back! [Re: tomcat27] #5114559 05/24/19 12:45 PM
E
eljefino Online Content
Online Content
E
The motor mounts are a good idea and also look underneath to see if, say, an exhaust flexpipe stiffened up (with rust) while the car was sitting. Or an exhaust hanger is overextended, rubbing, etc. Take the thing for a spirited drive to redline, may need cobwebs blown out.
Re: Our Camry is back! [Re: eljefino] #5114591 05/24/19 01:16 PM
AZjeff Offline
Or not. The next engine might not have the buzz!
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Our Camry is back! [Re: tomcat27] #5114728 05/24/19 04:35 PM
T
The_Eric Offline
T
Who did the re-man?
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Our Camry is back! [Re: The Critic] #5117864 05/28/19 07:00 AM
B
bubbatime Offline
B
My TSX has 250k miles, the kids drew pictures in the paint with a rock. It’s definitely worth less than an average 2010 TSX. That being said, I would drive it to Alaska tomorrow. Very reliable Honda car.
