New seafoam oil stabilizer at AZ
by Chesterr - 01/25/20 08:13 PM
In 3 hours - 730 days and counting
by OVERKILL - 01/25/20 08:12 PM
Pig Parker!
by dishdude - 01/25/20 07:58 PM
NGK Conventional vs. Ruthenium Plugs
by doitmyself - 01/25/20 07:58 PM
Container or funnel?
by Philthy_Phil - 01/25/20 07:24 PM
AC Delco filters at Amazon as little as $1.07
by jayjr1105 - 01/25/20 06:22 PM
Excessive moisture in oil
by mb32 - 01/25/20 05:47 PM
Cover for Jeep + Trailer
by kehyler - 01/25/20 05:34 PM
Low VI gear oils
by dparm - 01/25/20 05:28 PM
Removed valve cover, need to move car change oil?
by mazdamonky - 01/25/20 05:23 PM
Lucas UCL and turbos?
by K20FA5 - 01/25/20 05:01 PM
Another reminder why I always change my own oil
by DreamerGT - 01/25/20 04:52 PM
Oil for my 65 mustang.
by old1 - 01/25/20 04:12 PM
Carburetor Tuning with Wide Band O2 Sensor
by Oldswagon - 01/25/20 03:16 PM
Software fix for blown headgasket?
by CaptainHazelwood - 01/25/20 02:01 PM
EB Oil Drain Plug
by BlueOvalFitter - 01/25/20 01:59 PM
Grease for Blend Door Actuator
by TheLawnRanger - 01/25/20 01:05 PM
waterpump fan clutch and thermostat now overheating
by HyundaiAbuser - 01/25/20 12:43 PM
kwashabcp, ronster, BackToReality, Scopeman, M635_Guy
70527 Registered Users
100 registered members (53' Stude, 4WD, 55hambone, 73guna, aleneros, 69GTX, 9 invisible), 2,741 guests, and 20 spiders.
Topics300,557
Posts5,178,325
Members70,527
Raptor liner/1995 Tahoe/Before & After #5114364 05/24/19 08:30 AM
V
Vladiator Offline OP
V
1995 Chevy Tahoe 4WD. It looked pretty rough when I got it. Mechanically great though. So I spend 2 days sanding it and 1 hour spraying it with U-Pol Raptor Bedliner. All in it costed me $250, prep materials and paint.
Did everything in my backyard, very pleased with the result. Already getting tons of compliments. So if you got an old beater and debating if you should bedline it - go for it.
Just make sure to go with a good Bedliner like Raptor or Line-X. Harbor freight sells bedliner too, but from what I've seen - it fades in less than a year. Not an issue with Raptor or Line-X as far as I know. I went with Raptor because it's cheaper than Line-X. Raptor sends you a spray gun with the kit. Just need an air compressor. And lots of patience for the prep portion.
[Linked Image]
Re: Raptor liner/1995 Tahoe/Before & After [Re: Vladiator] #5114382 05/24/19 08:53 AM
M
maxdustington Offline
M
How big of a compressor do you have? Did you do the entire truck in one session or did you break it up into sections?
99 Toyota Tercel CE 5EFE/C151
Re: Raptor liner/1995 Tahoe/Before & After [Re: Vladiator] #5114733 05/24/19 03:42 PM
V
V
I got that exact 21 gal, 2.5hp compressor. I had the exit pressure set to 60psi on the compressor, and on the gun I set the gauge at 45psi. Raptor recommends 40-60 psi. 40psi is more textured than 60psi, so I went with that.
[Linked Image]
Re: Raptor liner/1995 Tahoe/Before & After [Re: Vladiator] #5114739 05/24/19 03:52 PM
V
V
And I went in sections. Roof first, and then 1-2 panels at a time. Took about an hour. The whole time compressor kept up no problem. It took longer swapping the bottles on the gun than actually painting. You will need a second person to shake the new bottles after they're mixed with the hardner.
If I had to do it again I would just do it like a normal paint job - single pass front-back-front-back until fully covered.
